Question about Westinghouse L2410NM 24 in. LCD TV
Westinghouse L2410NM replacement LCD panel
Can someone tell me where I can find a replacement panel for my L2410NM Westinghouse monitor? Thank you so much!
  • seoul_ite Mar 21, 2009
    Can you tell me how to get the front Bezel off so I can see what died in my L2410NM? Came hiome - plugged it in (gone for three weeks) and tried to turn it on.NOTHING DEAD - checked power cord and source - both GOOD.
    Thanks
    Seoulite
WDE may or may not have parts for our dead monitors. They gave me the following phone number: (562) 236-9800. I have no idea if they can look up part numbers for us if we can't locate them somehow ourselves. I don't see a service manual anywhere...
To the guy who wants to get the front bezel off: it just snaps off once you unscrew the 3 screws from the bottom on the back. I succeeded in getting all of the plastic case off, but then I was looking at potentially destroying the foil shields before getting it further apart.
Posted on Jun 24, 2009
  • TheKrell Oct 18, 2014
    By the way, I successfully replaced the power supply on my monitor and I'm using it right now.
Westinghouse monitor l2410nm display comes on then dissapears
you must check the power supply board, look for a bulging electrolytic capacitor which may cause of voltage drop.
Mar 29, 2013 | Westinghouse 24" L2410nm 1920x1200 16:10...
I'm trying to hook up my Westinghouse L2410NM 24 inch monitor to my MacBook Pro. I'm using the DVI adaptor for my mac to connect to the monitor via an DVI-HDMI cable. My mac seems to detect the L2410NM,...
You need to change the refresh rate, some monitors operate on 60 Hertz, and others on 70 or 72 Hertz, try changing the refresh next to the resolution choices.
Nov 13, 2010 | Apple MacBook Pro Notebook
I got the westinghouse LCD monitor model L2140NM several years ago. Yesterday the monitor got hit on the screen and it does not work. How much would it cost to repair? the screen is cracked and needed to...
hi, i'm actually looking for a broken westinghouse l2410nm monitor to fix mine. if you're interested in selling yours shoot me an email at mymaries1806@gmail.com. parts are hard to find for this monitor especially the screen itself. thanks for you consideration.
Sep 04, 2010 | Westinghouse L2410NM 24 in. LCD TV
24" monitor fails to turn on.
problem with the connector form motherboard to monitor
just remove all connections from ur monitor then only connect power cord. switch on the monitor, if it on or off reply me to my id i'll sure to correct ur problem prajwal_yes@yahoo.com
Jun 17, 2010 | Westinghouse L2410NM 24 in. LCD TV
Out of focus 22"LCD Monitor
Since you have your reciept you should be able to get a refund repair or replacement from Best Buy.
If it's past the warrenty date then you could ring a repair shop and get a quote on the cost to fix but would probobly cost more than the monitor is worth
Feb 06, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
AS soon as I Turn On computer screen comees on for 2 seconds then shuts off immediately
i've repaired three LCD monitors with that issue before. it involves taking it apart and replacing all the capacitors that have failed. you can tell which ones have failed as the top of it will be swelled up.
robert
Sep 07, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
I need instructions to install L2410NM monitor came with no instructions
Here is the link to install your monitor:
http://www.westinghousedigital.com/pdf/105_User_Manual.pdf
Jul 03, 2009 | Westinghouse Computers & Internet
Computer monitor wont turn on
Hi there :
You may want to want to check with the manufacture but some of these have a i fusable link in them my triton had the same thing happen and i called the manufactue and got the location for it and and replaced it my self .. hope this is of some help regards mike
Feb 16, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
The screen comes on fine but then dims????
Hi there, I have the same monitor, but mine has a broken screen. It's probably the inverter chip, that makes your contrast bright.
Jan 03, 2009 | Westinghouse L2410NM 24 in. LCD TV
Westinghouse L2410NM monitor dead
What about the fuse? Sometimes there is a fuse on the circuit board.
Jul 03, 2008 | Sceptre X9G-NagaIV 19" LCD Monitor
Westinghouse L2410NM 24 in. LCD TV Logo
606 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
