Question about HP OfficeJet 6110 All-In-One InkJet Printer
When printing or faxing from the top tray of my HP OfficeJet 6310 all in one I get a line that runs down the entire page on the copy or fax to the recipient. I have tried cleaning the glass and rollers under the left top panel but that doesn't help.
  • melscooking Mar 11, 2009
    No, its not when I lay my paper on the glass under the lid, its when I run the paper thru the top part of the machine-a black line appears on the fax and/or copy.
  • Leroy Elliott
    Leroy Elliott May 11, 2010
    It's a dirty galss.
    Problem Solver:
  • 15 Answers
The key to solving this problem lies in what you observed. It only happens when you use the document feeder. As you noted, when you place it on the glass, there is no line.
When you use the feed, your machine does not pull the document onto the main glass to scan it with a moving bar. Instead, the bar parks itself under the roller section, and the document gets scanned as it rolls past the stationary bar. A spot or speck that blocks the light bar as the document rolls past manifests itself as a vertical line.
Lift up the left cover and the roller carriage and you will see a narrow pane of glass about 1-1/2" wide. This is what you clean. I cleaned mine twice, unsuccessfully, with a glass wipe. Then I decided to align the streak on my copy with the glass, and saw the faintest speck.You may have to look VERY VERY hard under a bright light, but it will be there. A third, more vigorous and direct scrub and the speck was gone--so was the streak.
If the vertical line appears in both modes (document-fed and manual) then there is something on the light bar, or the bar has a broken scan pixel. If the main glass were dirty, you would not see a line, but random spots, and then only when fed manually. Dirty feed rollers can make lines, but not usually the clean, precise lines that are created by a blocked scan bar.
Posted on Apr 06, 2009
HP 6310 print problem-prints first 10 lines OK then next 10 are on a new page etc. Re-booting PC fixes problem.
Please check the Page selecton
check the page setup click on file -click on pagesetup
Press Ctrl+P
Check the layout settings
Check print priver if print privew is ok then its software issue
Check the printer drivers
DRIVERS HP Officejet 6310 All-in-One Printer
Jan 05, 2010 | HP OfficeJet 6310 All-in-One Printer...
HP officejet 6310 All-in-One When I try to print a copy of an airline reservation, from the ticket, or selected "print" on computer, it doesn't run off the ticket. It prints Page 1 of 1 on top of the page...
Make sure you're using the website's printer-friendly option when printing the ticket. Look for an option on the webpage (not in the pull-down file menu) that will correctly format the information for printing.
Aug 10, 2009 | HP Office Equipment & Supplies
When faxing does paper face uup or down
You load the originals print side uo on the document feeder tray or print side down on the glass.
To send a single page fax you can either load the original on document feeder tray or on the glass; to send a multi-page fax you must use the document feeder tray.
The position of the paper is the same either you copy, fax or scan.
All this is clearly explained in the user's manual, that you should read and you can download from HP support pages for you printer:
Aug 09, 2009 | HP Officejet 6310 All-In-One InkJet...
When copying or printing a fax, a vertical black line 2-3 mm line
try cleaning the rollers with water in the feeder at the top check the glass too too see if it's dirty
Jun 27, 2009 | HP Officejet 6310 All-In-One InkJet...
Hp officejet 6310 all-in-one send fax configure
1. Press Setup on the front panel of the All-in-One.
2. Press 2 to enter in to Print Report.
3. Press 1 to enter in to Fax Confirmation.
4. Press 1 to turn on Fax confirmation
5. Press 2 to enter in to Image on Fax Send Report
6. Press 1 to turn on Image on Fax Send Report
Jun 03, 2009 | HP Officejet 6310 All-In-One InkJet...
Black lines when you fax and copy
Open up the document feeder and clean the small scanner glass.
Feb 18, 2009 | HP Officejet 6310 All-In-One InkJet...
6310 has a fine black line down the entire length of the page
Need the clean the pinch rollers on the top of the unit. Use a small amout of alcohol on a piece of paper towel. Clean all the pinch rollers and then let unit sit for about 15 to 30 minutes.
HP Officejet 6310 wont copy or fax from top loader. To send a multipage fax I have to send each page separately
When you slide the pages into the top loader you reach a small plastic tab and probably stop there. Push pages in another 1/2 inch or so and you should hear a beep indicating the paper now is in far enough.
Dec 05, 2008 | HP Officejet 6310 All-In-One InkJet...
Black line on my fax copies!
You sure can - the issue is that there is something on the thin strip of glass where the copy goes through from the feeder at the top - follow these directions and you should clear the problem right up.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00671260&cc=us&lc=en&dlc=en&product=1119598&dlc=en&lang=en
Jan 22, 2008 | HP OfficeJet 6310 All-in-One Printer...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
197 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
