Question about Kitchen Appliances - Others
Ran out of heating oil, resupplied, won't start
Ran out of heating oil (kero), got resupplied and furnace won't restart.
  • 139 Answers
YOU NEED TO BLEED IT,ITS AIRLOCKED,OPEN THE NUT ON THE BOTTOM OF THE BOLIER AND LET IT SLOWLY FLOW OUT UNTIL IT STOPS BUBBLING,THERE WILL PROBABLY BE ABOUT 50-60 ML COME OUT,THEN PUT NUT BACK ON AND WIPE UP AROUND.IF NOT TRY BLEEDING THE RADS
Posted on Mar 10, 2009
    Guru:
  • 462 Answers
Most likely air in the lines. you'll ahve to bleed off the air to make full of fluid then it should restart. Look around the pump area for a bleed valve and keep a rag handy to wipe any splatter or spill. Your pump may also have a hand pump actuator to pull in fuel but it may require priming in either kind of application.
You may be able to get some tips and help from the people you bought the fuel from.
My advise is if you cant see or understand this or any advise they give you its time to be safe and call out a qualified repairman and watch what he does.
Heat Pump / Furnace Issue (Emergency)
Hi David. I'm Roger. For some reason your picture is blocking half of your message from sight. Could you please send me all you can in information but no picture. Your message is blocked from " I put in 20L of diesel for emerg, and now it works," -----That's all I can see. Tell me what you can and we will get started on for you.
Mar 16, 2014 | Heating & Cooling
Questions about a dual energy heating furnace
If you have a heat pump the electric heat is the emergency heat. Short explanation of a heat pump is it switches the jobs of the indoor and outdoor coils. So instead of taking heat from inside and moving it outside it works backwards picking up heat from outside and moving it indoors. Probably an electrical problem. 7_7_2014_5_33_51_pm.png
Mar 14, 2014 | Heating & Cooling
Lampoil Ultra-Pure
It will burn but it is way too expensive. Clear K1 Kero from a "locked" pump is what I would recommend, performance vs price. 2nd is the 5 gallon cans of K1 Kero in Big Box stores. 3rd. is Kleen Heat, Kerosene alternative.
Jan 04, 2014 | Heating & Cooling
Rv furnace stopped working
Quick call the installer to see if it is still under warranty. There is something wrong if the motor is being replaced every other year. Most of the motors should be lubed with fan turbine oil and not 3 in 1, nor detergent containing oils. If the wrong oil is used, the bearings will go south in 1 to 2 years.
Nov 23, 2013 | Heating & Cooling
Furnace wont run after running
There are a few posibilities:
1) the oilfilter needs cleaning
2) your pressure reduction bore needs to be changed
3) there is still some air left in the oil-tubes coming from the tank and leads to your burner
The best solution is to call a technician, he'll fix the problem in no time and while he is at it, perhaps he could perform a maintenance
May 29, 2013 | Heating & Cooling
Location of fuel pump filter on a Beckett oil furnace
Normally in the flue line someplace between the tank and the furnace .look near the floor as you follow the pipe
Jan 17, 2018 | Heating & Cooling
Furnace ran out of oil,got oil for the furnace,started furnace ran for 10 secends then switched off
On the oil pump there should be a bleed screw. Attach a tube to it and the other end to a can and 3/8" wrench, restart burner by depressing red button on Honeywell control and open up bleed screw. Oil will start flowing into can. When full stream of oil coming out of hose, tighten bleed screw. You have less than a minute to do this or the Honeywell control will shut off burner for a minute. It may take more than one try.
Jan 18, 2011 | Heating & Cooling
Furnace wont start when thermostat sends signal
by restart button you mean reset i believe,its located on top of oil burner and says only push one time .if thats the button your pushing it is the reset button or retry for oil burner if you are pushing this there is a problem with burner
Jan 04, 2009 | Honeywell Electronic Programmable...
Kitchen Appliances - Others Logo
106 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
