Question about Whirlpool GEQ9800L Electric Dryer
Cant find the Fuse on Whirlpool GEQ9800L
I heard it is on the blower but not sure which one is the fuse
  • Whirlpool Master
  • 3,361 Answers
1 and 1/2 inches long by 1/2 inch wide and white in color.
Posted on Mar 10, 2009
Pull jb power fuse15 stop drain no fan controls or radio
i cant under stand any of that.,i get JAB, and fuse 15
  • is this ?
  • battery drains over night? why did you say drain,if not.?
  • fuse 15 is ok. wild guess, sure, lots of loads, only a few fuse.
  • Hvac blower dead,
  • Radio dead
  • yes, the FSm does cover all that. sure.
id do the radio,so simple. 1 wire. for power, one fuse,
toss coin
03 GC WJ jeep it is zzzzz, slow internet on the beach
cant open free FSm. grrrrr
got it
jb f5 and 30 is Radio
f5 is only memory so fuse 30 is blown, why not test all fuses, keyon, 12v on both sides, and forget books. this works.
the blower is more complex. (controls)'
blower is pdc f1
and jb 20
looks yourself
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
free,posted over 100times now under GC
Jan 17, 2015 | 2003 Jeep Grand Cherokee
Wont start, is there a fuse? and where is it
There's a thermal fuse located on the blower housing along with the cycling thermostat and is wired in series with the motor. This thermal fuse blows when the lint duct and vent are blocked or when the cycling thermostat is stuck closed or not cycling properly. Power to the motor is terminated and the dryer will not start once the thermal fuse blows and no dryer function works. Make sure the lint duct and vent are clear. Click on the link below for the detailed troubleshooting instructions but make sure first that the dryer is getting power.
Troubleshooting Whirlpool and Kenmore Dryers
Not Starting
Mar 09, 2011 | Whirlpool LER5636P Electric Dryer
My Whirlpool dryer(supreme) does not start. The timer switch, door switch, start switch can all be heard to electronically switch on and off when I turn the timer around and open and close the door....
the thermal fuse may be faulty. Remove the outer back of the dryer. the thermal fuse is located on the blower assy with 2 wires connected to it. It is white plastic. connect the wires together, then try to start the unit again. If the unit starts, clean the exhaust duct after replacing the thermal fuse.
Jul 20, 2010 | Whirlpool LEQ8000JQ Electric Dryer
Dryer has power but nothing happens when you press the start button.
First check the door switch to make sure it is clicking when depressed. Open door and depress the door switch with your finger, should hear a click. If you do not replace the door switch. Other problem will be the thermal fuse located on the blower housing. Small white plastic piece with 2 wires going to it. Hope this helps.
Mar 09, 2010 | Whirlpool GEQ9800L Electric Dryer
Dryer will not run
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down
Sep 27, 2009 | Whirlpool GEQ9800L Electric Dryer
Whirlpooldryer
The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
Had a power cut and now the fridge doesnt work - model is a Whirlpool 470, cant find any obvious fault, but fridge is not getting full power, only reaches 140v instead of the normal 220v.
Never heard of 220v refrigerators, but half voltage means that either L1 or L2 is defective. Is it fed from fuses or circuit breaker? Make sure that your incoming power line has 220v from L1 to L2.
Check the fuse or circuit breaker with volt meter, make sure you have 220v from L1 to L2
Apr 15, 2009 | American Standard Colony 1583.470.020...
Cant find the fuse on my ultimate care II dryer?
The thermal fuse is usually white plastic about 3/8" wide and about 1 1/4" long
Mar 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LEQ9858PW0 Buzzes But Won't Start.
sounds as if wither you have a bad motor assy, or something haas fallen down into the "blower assy" preventing the motor form spinning.. in the back wher eyou tested your fuse, just to the left of that you see a large tubular housing (rounded on bottom", thats the cover for the blower , i believe its 3-4 screw holding it on, nad also the 2 screws visable when you remove the filter assy, the housing will pull off( you may need to wiggle it abit) and hopefully youll find a sock or something jammed in the blower assy
Jan 16, 2009 | Whirlpool LEQ9858P Electric Dryer
Blower motor
the fuse should be located in the fuse panel under the dash on the drivers side. the relay will be located in the junction box under the hood. if you have a owners manual it will show which fuse is what and amprage. if these are good it could be a bad switch, however if you turned it on and heard a click i would say that your relay is bad. please rate this
Sep 03, 2008 | 1991 Eagle Talon
Whirlpool GEQ9800L Electric Dryer Logo
101 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
