Question about LG Computers & Internet
Hi have a LG laptop and the Number LK is always automatically unlocked when i turned on the computer... so everytime i type on letters like U,I,O,J,K... it all turn out to be numbers. How do you turn off the Number Lk on a permanent basis?
  • teresa_305 Mar 10, 2009
    That what I have to physically do everytime i turn on the my computer. I think I should be doing this, because the primary fucntion of my keyboard is for typing alphabets and not numbers. But now, the computer system is turning on the number pad by default.. I wonder if there is any other ways of resolving this problem.
    Thank you very much for your help.
Hi all
pree Fn button plus scroo num lk button you will fix it
Posted on Jun 27, 2009
Try FN + NUM LOCK
Posted on Mar 10, 2009
How to turn on numlk for gateway NE56R31u
You may have hit a certain combination of keys on your Gateway laptop and turned on the NumLock function accidentally. The result is that the rectangle of keys from the 7 key down to the question mark key have become a number-entry keypad. Worse, Gateway manuals don't discuss this function.
Hold down the "Fn" key on the bottom row of the keyboard, and press the "NumLk" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "F11" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the F11 key and "Scroll Lk" key simultaneously. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "F9" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "Scroll Lk" key. Type the letters UIO. They should come up as letters. If none of these help, then it's probably a keyboard malfunction and you'll need to get it repaired.
Feb 17, 2013 | Computers & Internet
How i can enble function key
HP laptops have the ability to lock the blue special function keys on, making numerical data entry easier on laptop models that do not have the room for dedicated numerical keypads. Because the key combination to lock the function keys is so simple, however, it is easy for those who wouldn't normally use this ability to do so accidentally. When the function keys are locked, pressing certain keys will result in numbers being typed rather than letters. Unlock the function keys to alleviate this issue.
Press the "Fn" and "Num Lk" keys on the keyboard simultaneously. The "Number Lock" indicator light should turn off, indicating that the letter keys will once again type letters when pressed. This combination should work on the majority of recent HP laptops. If it does not, try one of the alternate key combinations in this article's remaining steps. Press the "Fn" and "F11" keys simultaneously, then attempt to type a letter. If the combination does not work, continue to the next step. Press the "Fn" and "Scroll Lock" keys simultaneously, then attempt to type a letter. Continue to the next step if this does not work. Press the "Fn," "Scroll Lock" and "F11" keys simultaneously.
Jan 16, 2013 | HP 4440s Probook
For some reason the number lock is on my keyboard - i can*t figure out howto unlock it. i have to keep the fn key down in order to type the letters on the right hand side. how do i unlock/ thanks in...
Please follow the below instruction to fix your problem.
Press 2 keys at the same time: "FN" (next to the CTRL key, lower-left of the keyboard) and "num lk", which is the upper-right of the keyboard (it is on the same key as "scroll", and is next to "F12"). This will either turn on or turn off the "Num Lock" function. Both the "FN" and "num lk" are enclosed in a small rectangle. They are easy to see.
Hope the above information will be helpful to you. Thank you. Have a good day.
Aug 11, 2011 | Fujitsu Computers & Internet
Laptop types numbers instead of letters
Hi!
You have enabled NUM LOCK. Press button "fn" and find another button with blue tag "Num Lock". Pres both buttons at once.
Hope it helps
Jul 10, 2011 | Dell Inspiron Mini 10 Notebook
In my key board m button tyed show 0 why
You probably have Number-lock active, test and see; u = 4, i = 5, o = 6, j = 1, k = 2 and l = 3.
On the bottom left of your keyboard you should find a key marked Fn. On the top right of your keyboard you should find a key marked Num LK. While pressing the Fn key, press the Num LK key once. this should unlock the number keys and allow you to type letters again.
Good luck ;)
Feb 02, 2011 | Computers & Internet
I have HP 510 note book. some keys, e.g. U, I, O, P, K etc are stuck in numbers. i cannot write a sentence. what should i do to make it function normally?
Good luck ;)
My keyboard asks like a number pad. How do i
Hit the Num Lk key and that should allow your keyboard to act normal.
If you have the Num Lk on then that means the letter keys that correspond with the numbers on a keypad will act like a keypad.
Make sure the Num Lk symbol is turned off by pressing the Num Lk key.
Aug 09, 2009 | IBM ThinkPad G41 Notebook
Keyboard types the number 6 when i type the letter o, and the number 2 for k, number 3 for l.
I assume this is a laptop? hold down the fn key and tap the NUM LK key. the NUM LK key is probably on the top row of keys, somewhere on the right, combined with SCROLL or PAUSE or one of those other utility keys. I don't know for sure how a Toshiba keyboard is laid out.
Jun 30, 2009 | Toshiba Satellite L15-S104 Notebook
Keyboard
Okay, if I am reading this right, you type but get numbers where there should be some letters? There should be a NUM LK key or such on your laptop keyboard. It may be sharing a key. Check around, its there (or something very very similar). Once you find it, you will have to hold down your "fn" key and then tap the NUM LK key. Now type a sentence that includes the letters that show up as numbers and see if there is a change. It could be that your Number Lock key is on. Let me know if this does not work so we can try something else.
May 24, 2008 | Compaq Presario 2100U Notebook
Computers & Internet Logo
230 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
