Question about Kenmore HE2 Plus Front Load Washer
Bellow/Seal sucked into washer during wash cycle
The bellow/seal was ripped out and sucked into the washer. The clamp (round metal band with spring holding ends together) was entangle with a shirt in the washer. Clamp is not damaged. Bellow/seal is somewhat distorted. Sears site does not show the bellow/seal in the explosion views so I'm not sure how to put this thing back together and should I purchase a bellow/seal?
Anybody experience same issue with this front loader? Thanks
  • JP Savich Mar 13, 2009
    After putting seal/bellow back in place, I observed seal/bellow was not damaged nor was the clamp. I worked the seal back into place (easy). The clamp was somewhat difficult. As someone noted, you need three hands. Its like putting a bike tire back on the rim. I worked clamp on to about 5 & 8 o'clock and had my wife hold it there. I then used a small blade screw driver and slipped clamp down at 6 oclock position. It worked. I looked over the seal/bellow to make sure it did not move and I did notice at 2 oclock position about 1/2 in roled in on itself. I worked it out gentle and washer is back in action.
  • 15,935 Answers
A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn’t cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
Step 6--Removing the door. After you remove the three screws in Step 5, there is only one screw to remove in step 6 on my model. It was hidden behind a plastic cover that makes the hinge look pretty. You'll see on the inside of the door that two plastic prongs/tabs extend into holes in the hinge. If you push on them laterally and pull out, the tabs will pop out. Outside the door on the left side of the machine, you'll see the plastic cover that is connected to those plastic tabs and is hiding the hinge. On the outside cover piece, there is a flat tab that extends up into the plastic housing above it. If you gently pull the cover downward and out the whole plastic cover will come off revealing the one screw that needs to be removed to take the door off.
Step 7--Removing the Kick Panel. The middle screw is more difficult to reach than the sides. You may need an extension for your screwdriver and/or shims or a helper to prop up the washer while you remove the middle screw.
Step 8--Removing the washer casing. The step says to remove the screws and set the casing aside. My model (2005-ish) has wires connected to it. Rather than being able to remove it, it swings open like a door with the wires as the hinge. I simply used a box to prop up the outside part of the door so it did not sag and stress the wires.
Step 9--After you remove the old rubber bellow, you will likely see a lot of dirt, mold, and junk where the bellow was. Clean that stuff off with a cloth sprayed with a gentle cleanser before installing the new bellow. We replaced our bellow because of mold and mildew and bad smelling stuff. That dirt and junk is part of the problem. Clean it up before you install the new clean bellow.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
How do I change the Bellow seal?
You really don't want to know, but since you asked......... Remove spring clamp around front of seal by prying under it and peeling it off. The easy part is now done. Peel away seal and stuff it inside drum. Look or feel for screw on clamp around seal thats still attached and loosen clamp screw. Peel seal off and remove. Wipe away any crud on flange. Install new seal starting at the top. Make sure top and bottom of it are perfectly centered. Push seal onto flange all the way around, feeling your way around. Once on and its centered properly reinstall clamp and tighten. If its the flat metal type of clamp do not overtighten or it may come off in wash cycle. Install outer seal to front and reinstall clamp by putting spring on first, wrapping rest of clamp around as much as you can, then holding one end of spring ( I use my knee or you can use small screwdriver) and using needle nose pliers grab other end of spring and stretch it while putting rest of clamp on. Have fun!
Sep 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Amana NFW7200TW washer - door seal ring has detached
The ring is a clamp that keeps the rubber part, called the bellow, attached to the front panel of the washer. To reinstall hook the edge of the bellow around the lip of the opening in the front panel (the hole through which you put your laundry). Then take the clamp and seat it in the groove of the bellow behind the lip of the front panel. The spring on the clamp should pull the bellow tight to the opening of the panel.
Like so:
Jun 11, 2010 | Maytag NFW7200TW Front Load Washer
The seal is ripped and i need to replace it --the model is 110.4751
The part number for the bellow (name for the front seal) is W10189283 it should run about $40.00. It is held on by a spring ring in the front and a screw clamp from the bellow to tub connection. Here is a link to a parts breakdown picture that should help. The bellow is part #1 in this image.
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fK0801002-00002.png
Apr 20, 2010 | Kenmore 44102 Front Load Washer
I goofed up the front tube seal bellow with an oversized comforter.Its not ripped but is not seating correctlycan it be realigned or do i need to replace?
As long as there on rips, tears or holes, you can realign it by removing the wire hoop clamp that affixes the bellow to the door frame opening. With the clamp removed, pull the bellow free of the door frame, realign and reattach. To get the wire hoop front bellow clamp back in place, follow step 12 in the link below:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Let me know if you have any questions. I hope this helps you.
NOTE: If the bellow leaks after you reattach it, you may have to inspect the rear bellow clamp and retighten. This is the clamp that affixes the bellow to the wash tub front.
Feb 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The Rubber seal came out and a metal ring came out with it. I got the rubber seal back in,but the I'm not sure about the metal ring. It looks like it's got a little spring thing on the bottom of it.
The rubber seal you are referring to is called the bellow. It seals the front of the wash tub to the door frame. The wire hoop is the front bellow clamp. If the bellow is not damaged, you can reinsert the clamp by following these steps:
1. Install the bellow back over the frame of the door opening ensure you fit it snugly all the way around the opening.
2. Beginning at the top of the door, start inserting the wire hoop back into the groove that is in the rubber fold of the bellow behind the door opening.
3. Make sure to wire spring points towards the 6 o'clock position and begin inserting the wire hoop into the bellow groove.
4. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place.
It may be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
If you inspect the bellow and it is ripped or torn, you will need to replace it or the washer will leak. The following link explains how:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Read through the link provided and let me know if you have any questions.
NOTE: There is another method you may try as well. Although I do not prefer this next method because these washing machines are very heavy, an alternative way of replacing the door bellow is to remove the lower toe panel and tilt the washer back at a 45 degree angle instead of removing the washer front panel. If you use this method, make sure it rests against the wall and will not tip forward. This allows the wash tub to drop down and away from the front panel and gives you access to the the rear bellow clamp through the bottom. This can save you some time. Thanks to user DGBG for the helpful tip.
If you would like some helpful exploded view diagrams of your washer that you can reference, you can use any of these web sites:
appliancepartspros.com
pcappliancerepair.com
Just use your model number to begin your search criteria.
If you have any questions, please let me know. I hope this helps you.
NOTE: These door seals do wear out and require replacement from time to time. However, overloading the washer to the point where items get caught in the door area can contribute to premature wear and tear.
Nov 18, 2009 | Kenmore Elite 45986 Front Load Washer
Bellow came off during wash cycle
You may need to replace the bellow and the band that holds it on they don't usually just fall off.
 Here is a link to the repair manual.
  https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Sep 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer leaking water
If the washer is leaking around the door area, more than likely the bellow (rubber seal) is ripped or torn. If you pull back the rubber folds in the bellow and inspect, you may find a rip or tear causing your leak.
Another cause can be the rear bellow clamp (clamp that is affixed to the front of the wash tub) can come loose causing a leak between the bellow and tub. All you may have to do is tighten the clamp if this is the case.
The dispenser tube on the left hand side of the door, if not seated through the rubber correctly, can also leak during the fill or rinse cycles. The tube should be inserted through the rubber in the bellow to the flange on the tube. If not, water can fill behind the rubber and drip into the bottom washer casing.
The following link explains how to access and/or replace the the door bellow on a Whirpool Duet:
Searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com and repairclinic.com carry the bellow. All these sites offer competitive pricing, so shop all of them for the best deal.
If you have any questions, or require addtional assistance, please let me know. I hope this helps you. NOTE: The bellow can also become mishapened over time after frequent use. This can also cause leaks around the door. Look to make sure the bellow is sealing around the door glass. If not, it should also be repalced.
Jul 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer leaking from door area
Jul 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite Front Load Washer
The rubber boot is called the "door bellow". The following link explains how to replace one:
If the bellow is not ripped or torn, you probably will NOT have to replace it. If the front bellow clamp (wire hoop) is the only thing that came loose, you will need to reseat the bellow around the door frame opening and reinsert the bellow clamp. The link explains this in Step 12 (I suggest you use a second set of hands to assist you). Now...if the bellow is torn, or if the clamp is damaged, you will need replacment parts. Let me know if you require additional assistance. I hope this helps you.
Oct 10, 2008 | Washing Machines
Kenmore HE2 Washing Machine Leaking
Have you looked behind the bellow under the folds to make sure there's no rips or tears? The bellow could appear okay on the outside, but still could have a tear somewhere out of plain view. I had this happen to me before.
The inner seal from the bellow to the tub could also be loose now. If you said a garment got stuck and the washer continued through the cycle, this could have loosen the seal where it attaches to the wash tub. You would need to tighten the band clamp around the facing of the tub if this is the case.
A good way in determining where the leak may be coming from is to remove the lower panel under the door. Start a wash cycle and watch to see where the water is coming out.
Now...if the tub seal is loose it may require some disassembly to get to. If you're going to go the route of disassembling the washer front, and have never replaced the bellow before, it probably wouldn't hurt to replace it anyway. My rationale: It's better to disassemble the washer once, rather than possibly having to do it all over again in the near future.
You can get a replacement bellow at searspartsdirect.com. Just type in your model number and look under the "Door and Latch Parts" section for item number 1 (part #8540952). It only costs about $32.
If you need instructions on how to replace the bellow, just go to my profile and look under my "Tips and Tricks". There is a write I posted there giving step-by-step instructions. If you cannot find it, or have any further questions, please post back and let me know. I hope this helps answer some of your questions.
May 04, 2008 | Washing Machines
Kenmore HE2 Plus Front Load Washer Logo
779 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
