My audio is disconnect
My audio not hear anything.the audio icon at text bar also missing.so what i must do?is that i must change the audio from xp to vista programme/ I have a problem with not being able to record properly using microphone. connected to the mic jack of my advent laptop. I used vista voice recorder and avs4u; both give this problem
I used call corder with the phone and the mic only records me not the other person who is faint to inaudible. I suspect this problem may not be the one of the call corder but that of the sound settings of laptop because this problem (one way recording only) is not present when I do analog recording with a conventional tape recorder and analog dictaphone.
I have tried setting Bitrate>= 64 Kbs and sampling rate >22k following an internet recommendation for human voices, but it is of no avail.
Go to "start", "Control panel", "Sound and audio devices", check "place volume icon in the task bar" (you may have to uncheck it (apply), re-check it (apply) for it to show up (mine sometimes disappears as well for no reason.
Check that volume (s) are not on "mute"
Posted on Mar 11, 2009
Speaker icon missing from task bar
Click on the Start button, then click on Control Panel from the right-hand side to delve into your computer's settings. From the Control Panel, click on Sound and Audio Devices to bring up your audio settings. Check the Place volume icon in the taskbar and then click Apply. You should now be able to see your volume icon from the taskbar again.
Jun 12, 2014 | Microsoft Windows XP Professional
Tip
Get back the Quick Launch bar Windows 7's new taskbar functions as a program...
Get back the Quick Launch bar Windows 7's new taskbar functions as a program launcher as well as task switcher. As a result, the old Quick Launch bar, the area on the left side of the taskbar that contained shortcuts for frequently used programs, has been banished. However, if you really miss the little applet, you can add it back. Here's how to do it:
1. Right-click the taskbar and choose Toolbars --> New Toolbar.
2 . You'll be asked to select a folder for where the new toolbar should live. In the Folder text box at the bottom of the dialog box, enter this text:
%userprofile%\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch
After you do that, click Select Folder. A link for the Quick Launch bar will be added to the taskbar. It will be on the right of the taskbar, just to the left of the Notification area.
It's not particularly useful docked all the way to the right with no application icons showing, so we're going to have to do a bit of work on it to make it useful. Right-click the taskbar and, in the pop-up menu, remove the check next to "Lock the taskbar." Now right-click Quick Launch and remove the checks next to Show Text and Show Title.
Once you've done that, drag the vertical triple dotted line next to the Quick Launch bar to the left until you expose its icons. To prevent further changes, right-click the taskbar and check Lock the taskbar.
You can now use the Quick Launch bar as you could in Windows XP and Vista, including adding icons to it and deleting them.
on Jan 12, 2010 | Computers & Internet
I have aproblem in audio definition of my laptop 5315 acer aspire,i visit the web site and download the proper driver for my laptop and operating system which is windows xp with service pack 3,but the...
You are missing this fix called "Microsoft UAA Bus Driver for High Definition Audio", below is the download link
http://america.giga-byte.com/FileList/Driver/motherboard_driver_audio_realtek_azalia.exe
Just download the Microsoft UAA Bus Driver for High Definition Audio driver and install it and installed the Audio driver you have downloaded earlier.
It will solve your problem.
That's it.
Jan 13, 2010 | Acer Aspire 5315 Notebook
I have installed the xp in my pc but now i cannot see the audio icon button en i cannot hear anything on my speakers .
You probabily don't have the correct audio drivers installed. Go to the Compaq website and download the XP drivers.
If you can't find them post the PC model and number here
Sep 02, 2009 | Compaq Computers & Internet
Asus M2V Audio problem
in the bios because you set HD audio to audio it may be that you need to download the HD Audio driver from microsoft
Apr 14, 2009 | ASUS SiS Chipset TUSI-M Motherboard
MIssing video audio after exporting
check the editing bar if it plays there fine. I think the location where that bit of video or audio changed or is missing, you need to be more specific
Mar 03, 2009 | Adobe Premiere Elements 4
Laptop w/ windows xp won't transmit sound to viewsonic wpg-150
Plug a set of head phones in to the WPG-150 Gateway and play something through the gateway. If you can hear it through the headphones you have a cable or stereo problem.
If you can't hear anything: On the sending computer, double click on the speaker icon in the system tray and make sure the volume is turned up on everything and nothing is 'muted.'
Jan 13, 2009 | Computers & Internet
put your hand on chip of your sound card on board if its hot so sure you need to disable and buy sound card or replace this chip also check audio jumper on board and try to install windows again and install the driver if u see on task bar sound volume icon check by tested headphone if there is out sound or no i wish i helped u
Jan 02, 2009 | ASUS M2V Motherboard
Audio driver
Go to Start>Settings>Control Panel.
Double click system.
Then device manager.
Look for a yellow sign with !. If you have one of these your sound card is not installed or driver is corrupt. What is the make/model of your computer.
Thanks,
Lee
Jun 17, 2008 | Microsoft Windows XP Professional With...
Sound problem
If you're talking about Windows XP, the volume control is available from the Control Panel under Sounds and Audio Devices; place a check-mark by the Place Volume in Task bar.
If you don't have Win XP, you can try to reinstall your sound icon by going to Control Panel -> Add / Remove Programs, Windows Setup tab and then double click the Multimedia icon and place a checkmark on Volume Control. If it's already there, take the checkmark off, then click OK. Then go back in again and place the check mark on.
This will hopefully reset it.
Mar 24, 2008 | Computers & Internet
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
