Question about Teac Audio Players & Recorders
Teac AG-V8525 Stopped producing sound. Has legend says "protect"
My Teac AG-V8525 was working fine. Then all of the sudden one day, I turned it on and the display showed "PROTECT" and no sound from anything. It is like the unit is frozen. I called Teac and they told me it is the speakers, and/or the speaker wires. I checked both and they are fine. Nothing wrong with the speakers or the wires. Any assistnce would be greatly appreciated. Thanks!Tony
Hit reset button back of receiver
Posted on Dec 02, 2009
  • ntack Aug 24, 2011
    I had volume up too loud when I switched from an input with no sound to FM. The speakers took the sound less than a second and then no sound. Of course, I can't find the manual. The speakers checked out OK. But, the reset button did the trick. Thanks.
  • Lexicop
    Lexicop Oct 09, 2017
    Didn't do the trick for me. Still "Protect" after several resets. It happened without apparent cause; same speakers and wires for over a decade, and nothing has been moved nor changed.
Why does my Teac ag h500 keep saying protect?
Hi. Unfortunately the protection circuit is saving your speakers from a fault, most likely one side of the amplifier in the unit is defective.
This needs an engineer.
Service manual is here if you need it. TEAC AG H500 Manual AM FM Stereo Receiver HiFi Engine
Oct 02, 2016 | Teac Audio Players & Recorders
Not switching on!
A short has transpired before the fuse. Now in protect mode. See a tech.
Mar 22, 2014 | Teac AG-980 4 Channels Receiver
My teac ag-790a 'protect' error message on display. When I brought it to the audio shop for repair it worked fine; at home again the same problem? What is the problem? Tx.
Hello
Check the putput wirings to speakers. If any of them has short circuit, the set will go to protection mode. You can understand it well, as it did worked fine at the repair shope. The set has no fault at all, but the wirings, connects to it have.
Just power ON the set at your home, without connection any output or input to it. See, it will not show any protection mode display. Switch it OFF. Connect the output to speakers, one at a time, and switch ON the set. Just do it for all other speakers. This way, you can find out, which speaker line causes the set to go to protection mode. Fine out the reason.
Never connect any input to the system, until works fine with out showing any protection display.
I helped you somewhat fine, I assumes.
Ok.
Jan 31, 2012 | Teac Audio Players & Recorders
I just want to know the wattage on the Teac AG-V3050
Teac AG-V3050 and Teac AG-V8050 are very compatiable to help with this question the total watts per channel are 100 watts. Hope this answers or at least helps. Excellent unit, great power to supply great sound for the unit at its time.
Jan 24, 2011 | Teac AG-V3050 Receiver
Teac ag-d9100 center and surround speakers are not working , very very low volume.. the others all work fine. Anybody know where to start troubleshooting. Its not a fuse that I can see , at least that i...
You have to enable them and turn the volume on them up separately with the speaker config, level trim, and up/down select buttons on the remote. You can also adjust the rear speaker delay time or just hit the test tone button and adjust the volume on each speaker separately as it goes through them one at a time...
Jun 01, 2010 | Teac AG-D9100 Receiver
The stereo plays for a few minutes and then turns itself off
hello it sound like the output transistor has blown or a capacitor has swelled up
shaun
Sep 16, 2009 | Teac AG-D8900 Receiver
My TEAC AG-7D turns on for about a second but then turns off
There is a problem in the final stages of the amplifier section that the protection circuits are detecting. They then shutdown the unit to prevent further damage. The most likely candidates are the output transistors. This is a relatively simple repair for an audio shop. Expect a parts cost between $20-$45.
Dan
Jul 15, 2009 | Teac Audio Players & Recorders
Keeps blowing fuse.
Dissconnect ALL speakers from back of unit then try to turn on.
If it works you have a speaker short.
If not, you have a more serious problem.
DO NOT replace the fuse with anything else but what was specified, as it can cause a fire!
Jun 14, 2009 | Teac AG-V8600
Protect displaying
Protect on any reciever usually means that it has reached its maximum capacity of volume (known as clipping) and at the reciever is now automatically reducing the volume to avoid damage. This some times is triggered if the reciever was used hard and is now damaged so you would need to bring it to a repair shop. Sometimes its caused by a bad wire to the speakers, a short to say. Check all your wiring, make sure its not overheating and getting plenty of air. Some where its recieving a signal telling it to go into protect mode.
Joe
May 28, 2009 | Audio Players & Recorders
1,253 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
