Question about Samsung Washing Machines
Samsung Q1235S coming up with error code De1 - Samsung Washing Machines
4 Suggested Answers
Maanita
  • 1142 Answers
SOURCE: Spin cycle wont work and
It doesn't pump or spinIf it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • Posted on Aug 05, 2008
    • 327 Answers
    SOURCE: de1 error message on Samsung front load washer
    Hello,De error refers to "Door Error".
    You do not need to buy a new machine. You can fix this.
    Look at the below mentioned link
    http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=799
    No doubt the above page is for "LG", However it's the basic and would remain the same for all models and machines whether that's GE, LG, Samsung etc....
    Thanks
    Posted on May 31, 2010
    theytsg
    gsjkdjd jskkkd jskdlkx jxkdghx xkoxb zjxknjxj
    Posted on May 23, 2014
    DE1 on the screen of my washer. Did a load of laundry & when I went to open the door, it wouldn't open! Saw the dE1& found out it was for the door. So how would I get rid of the error code
    You deleted your post as I was posting my answer to you!
    Disconnect from the wall socket for 10 minutes and plug it back in. If that doesn't reset it, hold the ON button for 10 seconds.
    That fixed my Whirlpool Duet.
    Feb 07, 2016 | Washing Machines
    I KEEP GETTING A DE MESSAGE AFTER A FEW MINUTES
    My washing machine is displaying an error code ... - Samsung
    www.samsung.com/my/support/skp/faq/1033803
    Samsung ElectronicsFeb 19, 2014 - ... your Samsung washing machine and the solution needed to resolve the .... If problem persists please call Customer Careline. *. dE. dE1. Ed.
    Aug 06, 2015 | Washing Machines
    Code de will not go away
    You have not included the Make and model of your washer. Below is a google search for Washing machine error code de
    This refers to a Samsung washing machine.
    I suggest that you edit your question to include both the Make and model number. This question has been answered before on FIXYA for a samsung washing machine. Link included below. dE
    dE1 Ed Door issue ·Check that the door is closed fully.
    ·Check nothing is trapping in the door.
    ·Check unit is not overloaded.
    · If problem persists please call the customer support team.
    Samsung washer machine error code dE
    Aug 16, 2014 | Washing Machines
    De1
    check the door lock or the catch on the door
    Feb 11, 2014 | Samsung Washing Machines
    Samsung error code de1
    meand a door error sounds like the lid lock assay is bad
    Jan 28, 2014 | Kenmore Elite 45986 Front Load Washer
    Hi! Error dE1. Dear, Boris From Russia
    Code de1 came up, on my big wash. DE1 means door error code 1, which I think is door not locking. (Judgeing by previous posts). The door didn't electronically lock (clunck), so me and the wife took the top off to have a look inside. Could see the door locking mechanism, (brown plastic) and the orange override manual opener. Turned off power at plug (don't want to electrocute myself) Pulled the orange cord about, that didn't do anything, still error code de1. My wife with slender arms got her arms down there and a connector came off. She could get it back on, so she pulled the drum outof the way, and I got my arm in and put the connector back into its point. (It can only go in one way. So if you have problems, you may be putting it back round the wrong way.) Power back on at plug and it started straight away, door locked and everything seems to be fine, it is now washing away merrily. So it turned out to be a loose connection. Lastly the orange manual override pull, took us ages to put it back, idea, tie a long bit of string to the pull at the bottom, so you can easily retrieve it back down the hole.
    Apr 02, 2011 | Washing Machines
    De1 error message on Samsung front load washer
    Thanks
    May 30, 2010 | Samsung WF419AA Front Load Washer / Dryer
    Spin cycle wont work and error code 8E comes on display on Samsung Q1235S
  • Aug 05, 2008 | Samsung Washing Machines
    Washing Machines Logo
    141 people viewed this question
    Top Samsung Washing Machines Experts
    Jaime Hernandez
    shaun taylor
    Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
