Question about Panasonic DVD-S53
Panasonic dvd player drawer will not open
Suddenly, when my DVD player is powered on, everything seems fine, but when I press the 'Open' button to insert a DVD, the drawer will not open. the display panel says 'Open' but nothing happens. There is no DVD in, so nothing is stuck in there.
5 Suggested Answers
Altoire
  • 24 Answers
SOURCE: DVD Stuck
Unplug it, take the main cover off the unit and remove any disc stuck inside. Put the lid back on power it up and try again.
Posted on Dec 31, 2006
  • 12 Answers
SOURCE: Panasonic DMR-ES15
Just unplug it and let it sit for half an hour. Then try playing the lens cleaner disc, the problem would be fixed....
Posted on Sep 28, 2007
  • 28 Answers
SOURCE: Dvd model DMR-E55
Hi
IC001 STRG6353 on power board may be faulty, mentioned also in several other threads.
Available from various suppliers.
Capital98
Posted on Nov 21, 2007
SOURCE: DVD Tray will not open
I purchased this unit back in Mid November to make DVD's of my kids old VHS tapes. To date I have probably have made 400 DVD's. Sunday we came home from being gone all day and the unit was locked up. I tried the reset button, unplugged the unit etc to no avail. I unplugged the unit all Sunday night and looked at it again on Monday morning. I was ready to take the unit back to Best Buy and the unit ejected the DVD and has worked for 2 days (Recorded another dozen DVD's). Tonight while reading the paper a message came on my monitor that there was a problem with the disk and instructed me to push the "enter" button which shut the unit off and was suppose to recover the disc. The recorder is now locked up again. A number of 000000's flashes accross the display and the unit constantly cycles off/on. So it is trying to recover but is obviously not being successful. I am going to try the same thing tonight. I am not sure if I have a bad set of blank DVD's. They are Sony -DVD R, same ones I have been using all along. I do remember having this "Error" message when I first started this project and I had to unplug the unit to resolve but it didn't lock up and I haven't had any issues until Sunday. Seems like something in the software is screwed up. It is frustrating that there doesn't seem to be a manual way to eject the disk??!!
Posted on Jan 16, 2008
  • 1003 Answers
SOURCE: Toshiba SD420e player won't play -drawer keeps ejecting
Have laser lens cleaned
Posted on Jan 17, 2008
Dvd tray on MDR537H will not open
"...DVD tray won't open until it's set up - clock set and channels scanned..."
Nov 22, 2013 | Magnavox Mdr537h Blk Dvd Hdd Recorder With...
Unlock Toshiba DVD player SDP93S bought in America to play Australian DVD's
Thanks for understanding. Please let me know if you require any clarifications.
Jul 09, 2011 | Toshiba SDP93S Portable DVD Player
MY MEMOREX DVD PLAYER suddenly WONT TURN ON?
Unplug power cord, wait 30 sec. Plug back in. Worked 4 me
Mar 20, 2011 | Memorex MVD2042 DVD Player
The DVD door will not open when the button is pressed
Please check the bellow instructions:-
Turn off your DVD player. Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.
Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs.
Please get back to us if you have any further query or else accept the solution.
Nov 01, 2010 | Panasonic NVVHD1BS DVD Player / VCR Combo
DVD drawer won't stay closed
the open button could be shorted meaning the unit is constantly being told to open its tray i think its worth having looked at and i think your sons off the hook dvds are pritty hard for kids to muck up unlike the older vcr you would no belive the things kids would put in them best one i ever saw was a weat bix and a slice of toast.
good luck
May 15, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
DISC DRAWER WILL NOT OPEN
First, start with power cycling the player. Turn off the player and disconnect the power cord from the wall socket. Leave it unplug for about 5 minutes. Turn the player back on and try to open the drawer.
If same problem occur, then follow the steps below:
1. Turn off your DVD player. You do not want to risk electrical shock while working with it.
2. Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
3. Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
4. Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.
5. Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs.
Mar 21, 2010 | Panasonic DMR-ES10 DVD Recorder
Panasonic dmres30v unable to open dvd drawer led displaying u99 and cant remove
Press the power button on the main unit to switch the unit to standby. When the unit is in standby , press the power button again on the main unit to turn it on. If the unit doesn’t switch to standby, press and hold the power button on the main unit for about 10 seconds to forcibly switch it to standby.
To open the drawer, press and hold STOP and CH UP buttons on the main unit at the same time for about 5 seconds.
Nov 27, 2009 | Panasonic DVD-S35 DVD Player
The Open/close does not work. Power is on and it
First try resetting the player. Unplug for 1/2 hour-1hr., press and hold power button for 3 seconds, wait 1/2 hour, plug back in and it should work. Otherwise you can pry open the door with a paper clip. Slowly pull door as far back as it will go, then press eject button and see if everything aligns itself back on track.
Nov 23, 2009 | Panasonic DVD-RV31 DVD Player
Dvd tray will not open
If you press the open key and it say open on the display then yu have a cut belt / blowm loading motor or power preoblem insdie the set. If it does not say open/close on the display then you could have a faultt button or processor.
May 12, 2009 | Televison & Video
Toshiba sd-3990 Disc-drawer won't open
I was given one of these the other day. I was told the drawer wouldn't open yet the machine seemed to function fine. I removed the six screws holding the top on the box and then removed the four screws holding the drawer assembly in place. As you lift the drawer assembly out of the box, make sure you release the two pieces of black retaining tape holding the data cable to the box floor. Turn the drawer over and you will see that there is a little sideways bar mounted on the front underside of the drawer assembly. This is sticking. As you press the OPEN button, jiggle this bar and the drawer will open. You may have to manually move the drawer cogwheel a little to help free it up. Hope this helps.
May 22, 2008 | Toshiba SD-3990 DVD Player
Panasonic DVD-S53 Logo
165 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
