Question about Lexmark X3470 All-In-One InkJet Printer
Cover Open message I changed the ink cartridge and closed the cover. Cover Open message is displayed. Unit does not function, nor turn off.
  • Lexmark Master
  • 6,487 Answers
Unplug the printer from the power outlet for 5 minutes and then after that plug it back in and check if that will correct the problem...
Posted on Mar 10, 2009
  • Lexmark Master
  • 13,433 Answers
Unplug the unit for a few minutes. Plug it back in. Try turning it on again.
  • Ekse Mar 10, 2009
    Also you can try reseating the cartridges on the printer. ones you have first unpluged it and tried the above, if that doesn't solve the problem ,reseat the cartridges, open up the cover, remove the cartridges and place them back in. Close the cover and if there is a error message on the screen or a question click on OK or enter to accept it and it should function normally. If not, then please confirm is your printer x3470 lexmark? Thank you.
Hi, my canon MP250 is displaying the error P08 and error 5200 on the computer. Can you help me please
Start with printer powered off
1. Open cover of printer and verify that the ink cartridge carriage is not in the center of the printer. Leave cover open.
2. Unplug the electrical cord from the printer and wait 30 seconds.
3. Plug electrical cord back in, when ink cartridge carriage moves to the center of the printer quickly unplug the electrical cord again. This should leave the ink cartridge carriage in the center of the printer so you can get to it.
4. Lift up the gray arm that surrounds the ink cartridges.
5. Remove the entire ink cartridge holder (not just the ink cartridges). It will lift out easily as a unit. Lower the gray arm that you lifted to remove the cartridge holder.
6. Close printer cover. Plug electricity back in.
7. There should be a message about checking the ink cartridge on the display (I can't remember exactly what it said but it was something like that).
8. Open printer, lift the gray arm that surrounds the ink cartridge area and reinsert the ink cartridge holder (with the ink cartridges in it). Lower the gray arm.
9. Close printer cover.
10. The display should appear normal now, and you should be able to print again.
Jul 21, 2011 | Office Equipment & Supplies
How do I load the ink cartridges into the Canon Pixma printer MX320?
1. Make sure that the power is turned on, and open the Paper Output Tray.
2. Lift the Scanning Unit (Cover), then hold it open with the Scanning Unit Support on the right side.
The FINE Cartridge Holder moves to the replacement position.
3. FINE Cartridge.
(1) Pinch the tabs and open the Ink Cartridge Locking Cover.
(2) Remove the FINE Cartridge.
4. Prepare the new FINE Cartridge.
(1) Take a new FINE Cartridge out of its package and remove the orange protective tape gently.
5. Install the FINE Cartridge.
(1) Put a new FINE Cartridge in the FINE Cartridge Holder.
The Color FINE Cartridge should be installed into the left slot and the Black FINE Cartridge should be into the right slot.
(2) Close the Ink Cartridge Locking Cover to lock the FINE Cartridge into place.
Push down the Ink Cartridge Locking Cover until it clicks.
(3) Confirm that the Ink Cartridge Locking Cover is closed correctly.
(E) Closed correctly
(F) Not closed correctly (the cover is tilted)
6. Lift the Scanning Unit (Cover) slightly to set the Scanning Unit Support back to its original position, and gently close the Scanning Unit (Cover).
Oct 05, 2010 | Canon Office Equipment & Supplies
How do i replace the ink on my canon mx340
These are the steps originally from the http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx340#ServiceAndSupport
Install the FINE Cartridges
1. Lift the Scanning Unit (Cover) (A) and fix it with the Scanning Unit Support (D).
Close the Document Cover (E) and lift it with the Scanning Unit (Cover).
important:
  • Do not touch the buttons or LCD (F) on the Operation Panel (G). May result in unintended operation.
  • When opening the Scanning Unit (Cover), the FINE Cartridge Holder moves automatically.
  • If the FINE Cartridge Holder does not move, make sure that the machine is turned on.
  • If the Scanning Unit (Cover) is left open for more than 10 minutes, the FINE Cartridge Holder moves to the right. In this case, close and reopen the Scanning Unit (Cover).
2. Make sure that the FINE Cartridge Holder (H) moves to the installation position.
3. Follow the next procedure to insert the Black g0070683.png and Color g0070684.png FINE Cartridges into their corresponding slots g0070683.png and g0070684.png.
4. Open the Ink Cartridge Locking Cover g0070683.png on the right side.
Pinch (I) firmly and pull up the cover.
5. Remove the Black FINE Cartridge g0070683.png from its package.
important:
  • Handle the FINE Cartridges carefully. Do not drop or apply excessive pressure to them.
  • Be sure to use the supplied FINE Cartridges.
  • Be careful not to stain your hands or surrounding work area with ink on the removed protective tape.
  • Do not touch the Electrical Contacts (K) or Print Head Nozzles (L) on a FINE Cartridge. The machine may not print properly if you touch them.
6. Pull the orange protective tape (J) in the direction of the arrow and remove it carefully.
7. Place the Black FINE Cartridge g0070683.png into the right slot g0070683.png.
important:
  • Do not knock the FINE Cartridge against the sides of the holder.
  • Install in a well-lit environment.
  • Install the Black FINE Cartridge g0070683.png into the right slot g0070683.png, and the Color FINE Cartridge g0070684.png into the left slot g0070684.png.
8. Push down g0070683.png of the Ink Cartridge Locking Cover until you hear a click to close it completely.
View the Ink Cartridge Locking Cover g0070683.png straight on and check that it is locked correctly (not at an angle).
9. Insert the Color FINE Cartridge g0070684.png into the left FINE Cartridge Holder g0070684.png in the same way as the Black FINE Cartridge.
10. Lift the Scanning Unit (Cover) slightly (1) and fold the Scanning Unit Support (2), then gently close the Scanning Unit (Cover) (3).
important: Do not touch the buttons or LCD on the Operation Panel. May result in unintended operation.
11. Make sure that the LCD changes as shown in the illustration and go to the next step.
  • It takes about 1 - 2 minutes before the LCD changes.
important:
  • Once you have installed the FINE Cartridges, do not remove them unnecessarily.
  • If an error message is displayed on the LCD, make sure that the FINE Cartridges are correctly installed.
note: The LCD will turn off if the machine is not operated for about 5 minutes. To restore the display, press any button except the ON button.
Aug 12, 2010 | Canon PIXMA MX310 All-In-One Printer
Message no cartridge when installing new cartridge. I have installed new ink cartridges but the printer keeps coming up with the message 'No Cartridge' Reinstall the cartridge. I have done this three or...
Hello ,
Start by opening your ink cover and read the LCD screen; this will alert you as to which ink cartridge is not being recognized; make sure the cartridge that it is telling you is empty has been changed.
If the unit is still not recognizing the cartridge you have changed, follow the steps below.
  1. Unplug the power cord for the printer unit.
  2. Open the ink cartridge cover and remove all ink cartridges.
  3. Close the ink cartridge cover.
  4. Plug the power cord back in.
  5. Reinstall the ink cartridges.
Thank you,
Pat
Mar 28, 2010 | Office Equipment & Supplies
Hp photosmart C6188 ink system has failed OXC19a002
1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
2. Open the cover of the product and remove the print cartridges.
3. Close the cover and wait for the Insert Ink Cartridges message to display.
4. Disconnect the power cord from the back of the product and the wall socket, then wait for one minute.
5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
6. Open the cover and reinsert the print cartridges.
7. Close the cover. If prompted, print a calibration page.
8. Print a Self Test to verify product is functional.
9. Reconnect the USB cable, and try to print from the computer.
10. If the error is still there replace the unit.
Dec 16, 2009 | HP Photosmart 3210 Printer
Ink sys failure error message
Try the following steps and check if it resolves the above error.
Wish
Aug 01, 2009 | HP Photosmart D7160 InkJet Printer
I recently replaced the magenta cartridge in my HP 3210 Photosmart printer because the light indicated it needed to be replaced. However, the printer still won't print, and the message still says that I...
If you turned the machine off and replaced the cartridge, you can get this error.
Could you try the following procedure below please to clear the error, thanks.
  1. Turn on the unit.
  2. Open the top cover to access the print cartridges.
  3. Remove the new cartridge that is causing the message.
  4. Reinsert the cartridge and close the cover. The following message will appear on the front panel: "Press 1 for new cartridge or press 2 for a used cartridge."
  5. Press the 1 on the numeric keypad of the HP product.
If the message, press 1 for new cartridge or press 2 for a used cartridge, "does not appear after removing and reinstalling the new cartridge, and the low ink warning message still displays,
follow the steps below:
  2. Open the top cover to access the ink cartridges.
  3. After the cartridges stop moving, unplug the power cord.
  4. Remove both cartridges and close the top cover.
  5. Plug the power back in. The unit will reinitialize and a message will appear to insert the cartridges.
  6. Open the top cover and reinsert the ink cartridges. Close the top cover. The message,
  7. Press 1 for new cartridge or press 2 for a used cartridge," should appear.
Hope this helps
Regards.
Apr 18, 2009 | HP Photosmart 3310 Printer
I HAVE NO INSTRUCTIONS FOR OPENING THE CARTRIDGE COVER ON MY EPSON rx595 PRINTER AND CHANGING THE CARTRIDGES.
Make sure you have a new ink cartridge before you begin. You must install new cartridges immediately after removing the old ones.
Follow the steps below to replace one or more ink cartridges that are expended:
  1. Turn on the printer.
  2. If a cartridge is low or expended, you see a message on the display screen. Note which cartridges need to be replaced and press OK.
  3. Open the scanner, then open the cartridge cover.
  4. Squeeze the tab on the cartridge and lift it up. Dispose of it carefully. Do not take the used cartridge apart or try to refill it.
  5. Remove the cartridge from the package, but be careful not to touch the green chip on the edge.
  6. Remove the yellow tape from the bottom of the ink cartridge.
    Caution: Do not remove any other labels or seals, or ink will leak.
  7. Insert the new ink cartridge into the holder and push it down until it clicks into place.
  8. Once you replace all the cartridges that need replacing, close the cartridge cover and push it down until it clicks into place.
  9. Close the scanner.
  10. Press OK to begin charging the ink. This takes about 2 minutes. When you see a completion message on the display screen, ink charging is finished.
Caution: To conserve ink, never turn off the printer while ink is charging. If you see an ink replacement message on the display screen, press OK and press down all the cartridges securely
Jan 08, 2009 | Epson RX595 Photo All-In-One Printer
PRINTERS
Please perform the folllowing steps:
Regards,
Sagarjd
Jul 26, 2008 | HP Photosmart C6180 All-In-One InkJet...
OXC18a0205
Perform the following steps :
1. Get the unit into the “Support Menu” by following the steps below
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
Display should say “Support” and display the FW rev (something like R0631R)
2. Press and release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
3. Press and release the “OK” button.
4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
5. Press and release the “OK” button.
6. Display should say “Hardware failure status: Clear. Press OK to clear”.
7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
13. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
14. If the error is still there, or reoccurs replace the unit.
Oct 27, 2007 | HP Photosmart C7180 All-In-One InkJet...
Lexmark X3470 All-In-One InkJet Printer Logo
21 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
