Question about Sony VAIO SZ Series Notebook VGN-SZ780EB
Sony vaio VGN SZ780 unable to use vpn
Sony vaio VGN SZ780 connects to the internet just fine through a Dlink Dir625 router. But unable to use Cisco 3000 vpn. All other systems on the same network work fine. vpn can be used elsewhere. Issue with the vaio and Dlink router? Any suggestions?
  • Anonymous Apr 06, 2009
    dsertertb teztz z etz
I am unable to access my company's vpn server.
You may have some needed firewall ports blocked on your router. Turn off the firewall temporally and see if your able to connect. Your company IT folks should be able to tell you what ports they need open.
Oct 20, 2017 | Arris SURFboard SBG900 (49402201900) Modem
Can i set vpn bby using cisco 2513 routers, i am trying to type crypto commands but it is not accepting
You probably have the wrong feature set on the IOS. You would need to download a new IOS image that has the security feature set.
Aug 21, 2017 | Cisco Computers & Internet
Belkin n150 cisco vpn
hi - I just had a tough day trying to connect N150 to my company's VPN, and after a long struggle found out that Belkin N150 does not support the VPN connections. simply upgrade it to N300 and you would be fine.
Jun 08, 2012 | Belkin Connect N150 Wireless Router...
I can access internet but cannot get in via cisco vpn(intermitent
Look at the number of users you have enabled in the router. If you only have 3 and you are using 4 computers, you could be getting the kind of behavior you are describing based on how many computers you have connected at the time.
Jun 18, 2009 | Belkin (F5D5231-4) Router
Disable nat in dir625
I don't think you can with that model.
Mar 30, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Cisco VPN not working
please call dlink tech support at 877-453-5465. just an advise on how to handle the call when you reach dlink tech support (agent); do not agree to call back after you troubleshoot with them (they'll be giving you a case id reference# and be advising you to check your pc or call "who" and call them back to continue the troubleshooting). insist to the agent that he need to resolve the problem asap (by the way, agents are not allowed to drop the call or they'll be dead-history!). and if the agent still insisted you to call back, ask for a "senior level technician" to finish the job (escalate the problem).
fyi: dlink tech support handling time to resolve a call is 15 to 18 minutes only. if you reach that 15-18 minutes (max) time the agent will think of a way for you to call back (advising you to check with your pc manufacturer, check with your ISP, call microsoft to update your software, etc... non-sense!) they need to do this in order to reach their handling time (agents need to reach 21 to 25 billable calls, and billable calls are "solution provided", "resolved", and "dropped call"). ---- believe me, i was one of them and repented.
Jan 27, 2009 | D-Link DI-624M Router (DI624MRE)
Printing with Dlink DI-624S and VPN connection
I am guessing this VPN is something work related and not a VPN you setup yourself?? If that is the case your company's VPN access will not allow you to pass from there network back to yours which is why you are unable to print to your local home printer when connected to VPN. You might could run it by your IT staff and see if they will allow connection and help you set it up. If not then simply email the docs to yourself and then print them out after you are finished using VPN connection.
Hope this Helps
TankMurdock
Jan 24, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
VPN problem with Dlink DIR-300
Update your firmware to the latest. I had the same issue and the issue is gone after the upgrade.
Dec 31, 2008 | D-Link / RangeBooster N 650 / DIR-635 /...
DLink DI-624s - can't get Cisco VPN Client to connect.
The "Virtual Server" setting is designed to give the general public access to a network resrouce (web/ftp/media server) on your internal network. If your the VPN concentrator is external to your network (meaning you'll have to use the internet to connect to it), then you won't need to define a virtual server on the DI-624.
You'll just need to enable the IPSEC and PPTP VPN Passthrough which it sounds like you've already done this. I've run into some ISP's that block VPN connections out of their network. If you have the ability, try to directly connect your laptop into your cable/DSL modem in place of your router and see if you can make a VPN connection, if not contact your ISP, if you can then verify you enabled the VPN passthroughs because your router is blocking them.
GIve it a shot and let us know your results.
Apr 26, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
D-link dir625
What kind of problems are you having? Once the router is connected to your modem and the router is configured and working properly you should be able to connect it to your PS3.
Mar 15, 2008 | Computers & Internet
Sony VAIO SZ Series Notebook VGN-SZ780EB Logo
192 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
