Question about SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive
Heating up, light not coming on
When I plug the flashdrive into my computer it is not showing up. I also tried on my wife's Mac and it does not show up there either. This is an 8 gb cruzer.
  • Jo Finch Mar 20, 2009
    Have the same problem with a brand new 8gb--the older 1 gb works fine.
    I suspect bad hardware
  • loneoak Mar 24, 2009
    Will not read files on MacBookPro
Cruzer micro 4GB, loaded with data. works perfectly in all systems except my xp. Problem didn't originate until after ghosting system to correct different problem. Now, error message states flashdrive not recognized. must then get behind pc, and gently work with it until i can hear the shift in the duo core processors and the orange light on the flashdrive comes on. Please help.
Posted on Mar 13, 2009
Whenever I insert my flashdrive it doesnt show up in the desktop on my mac. How can I fix it?
Have you tried a different computer? It may be the flash drive has gone dud.
Apr 18, 2016 | Computers & Internet
How do I show the embroidery pattern from the flashdrive on my ellure plus?
Sounds like you have .dst files on your flashdrive. That is not the native language of this machine. If you convert files to .PES files then you will see the image
May 13, 2014 | Baby Lock Ellure
I have a PNY USB 4GB Flashdrive, and when i plug it in, it shows that it isn't plugged in. I try to look for it, but it shows nothing is plugged in. Please Help!
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with this or if i have missed the problem post a reply
hope it helps
May 13, 2012 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
After copying 3.4 Gbyte or about 600 jpeg's to my Imation flashdrive 2.0 (4Gbyte) using my Apple Mac OS 10.5.8, I formally ejected the drive and inserted it into our Vista Windows machine. The Vista...
Plug the flash drive into the windows PC first and open "Computer". Find the drive and format it to Fat32 or NTFS. Now plug it into the mac and copy the pictures too it. Now your Windows computer should see the files. Mac will default to making the flash drive use HFS+ filesystem. Windows doesn't recognize this format at all. Mac will see fat32 and ntfs just fine though.
Aug 28, 2011 | Computers & Internet
Hi. my flash drive light comes on as i put it in. it stays on momentarily but after three seconds or so th ligh goes off. it doen't even show up on my computer
Flashing light means your flashdrive is being read. Try it on another computer, if it still can not be detected then it is broken.
Hope this helped! =)
May 19, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
The drive is not recognized by Windows or Mac
You should give Test Disk a try. It's a little complicated at first but if you read the tutorial it's easy.
Here's a link to their wiki page.
Nov 24, 2009 | Memorex Mega Travel Drive HDD 12GB 12 GB...
SanDisk 8GB lights up but wont register
This one is just a hunch. The drive might be bad but this is worth a try. Its possible the drive letter somehow changed on the flashdrive. Plug in the drive, RIGHT click on "My Computer" and select "Manage" from the drop down menu. Now select "Disk Management" from the list. If you see your flash drive on the list, right click on it and select "Change drive letter and paths", then click on "change", now assign it a new letter like "F" for example. Click ok, ok, ok. If it showed up the the list and it's still not registering, unplug it and plug it back in. Hope that helps.
Feb 15, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Problem
Hello!
Hopefully I can try to walk you through a process that I would use.  First check to see if the flashdrive is damaged.  Usually the cases don't break, but the USB connector itself takes a lot of hits/damage/wear.  You should be able to see 4 metallic contacts on the USB connector and they should be in good shape.  Blow out any dirt/garbage in the connector as well.
Next is to see when you plug it in if the LED on it lights up at all.  If there is no light whatsoever, it is one of two things, either the flashdrive is totally broken or you have a failled USB port.  Either one is possible.  If possible, take the flashdrive and test it on another system, or at least another USB port.  That will give you some important information.
Assuming that the LED lights, then it is a question of getting Windows to recognize the drive.  If there is nothing important on the drive, fdisk the drive in DOS, then format it, and then Windows should recognize it, allowing it to be used.
If you have no LED lighting on the flashdrive, after testing on another system as well, get another flashdrive (or return this one if under warranty), since there are no real parts to service/fix.
Hope this helps out!
Ken
Jan 06, 2009 | Computers & Internet
Toshiba 4mb jump drive
try to jump from one usb slot to another until your computer recognizes your flashdrive.
Mar 25, 2008 | Computers & Internet
SanDisk Malfunction
unfortunately the files cannot be recovered immediately, macs a are compatible with PC flash drives but not the other way around. you need to format the disk. go to start>my computer> then right click on the flash drive and then left click on format, then click ok. when it is done bring the flash drive back to the mac and put the files back on. now try putting the flash drive into the pc again
Jan 23, 2008 | SanDisk 1GB Cruzer Titanium USB Flash...
SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive Logo
481 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
