Question about Samsung RB2155SH Bottom Freezer Refrigerator
Samsung RL39WBMS fridge/freezer
My fridge freezer is 4 years old and both packed in.If you switch off at mains,and switch back on,it reaches the working temperature then cuts out.but does not come back on.a Had Samsung repair technician and he pressed fridge and freezer buttons at same time which put it into a forced start.out.It reaches the working temperature and works perfect for 28 hours and then cuts out.It bleeps continually and is driving us up the wall.This has been like this for 10 weeks.Its had a new circuit board on technicians first visit,made no difference,on his second visit the sensors were replaced and made no difference.The samsung technician cannot getan answer from samsung to help us.This is not acceptable.Has anyone experienced the same problems and can assist us in any way before we give up and buy a new one.
2 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: Samsung RS2555SL evaporator is icing
If refrigerator is not cooling properly it can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer is bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
Hope this helps...please post back for further assistance.
Posted on Sep 10, 2011
My Samsung RL39WBMS fridge on m fridge freezer keeps freezing food. Why is this happening all the time and how can I prevent it?
maybe the fridge is set on a colder setting and if that's not it then stick it on the lower shelves and that might help from not freezing because are fridge is the same way when it is stuck by the coolant fan
Nov 02, 2014 | Refrigerators
Have to slam freezer door to clear 88 error codes on samsung refrigerator
I am not certain on this, but my guess is that you have a problem with the door closed sensor, which should be attached to the door/ light actuating button. It may be faulty, or just out of adjustment. I assume that you have contacted Samsung about what error code 88 is. Do they have any other input? What doesn't make sense is that the fridge turns off. You would think that if the door sensor read "Open door" it would continuously run, rather than shutting off, unless it is causing an overload, or overheating condition. I have had good luck w/ Samsung tech dept., but they can be a little hard to reach. Hope this helps.
Mar 10, 2014 | Refrigerators
I have a Samsung refrigerator Model RT52EAMS which is 5 years old. It is working fine except that the light in the refrigerator is no longer working. The light in the freezer is still working well. How...
Please check the door switch and the bulb holders, in some cases it can be due to loose connection or a faulty switch on the door, The failure of the bulb is another issue but the main subject is how you can check and remove the bulb.
Please check on the link below for tips and spares:
Jul 19, 2011 | Samsung Refrigerators
Samsung side by side not as cold as it should be all fans sound like they are working what to look for fridge only 4 years old pulled out back cleaned coil pack with compressor please help
We had a similar problem. SAMSUNG said to not set the freezer to the top range and the fridge to top range. If you set the freezer to the top range there is not enough cold air funneled to the fridge. We usually set the freezer to about 3 dots and the fridge to 4 or 5. Try that and see if it helps
Dec 04, 2009 | Samsung RS2630WW Side by Side Refrigerator
Ice block forms bottom of freezer then leaks on 2 floor
This is usually because the self defrost hose has become clogged. Turn the unit off long enough to defrost the unit and get the ice out of the tube and blow out the tube and turn the fridge or freezer back on.
This should solve it for you.
Sep 11, 2009 | Samsung RB2155SH Bottom Freezer...
Samsung fridge freezer
hey gordon is this model 4 drawer electronic control with the display in the ice door
Feb 16, 2008 | Refrigerators
Fridge freezer not reaching operating temperature
maybe its time your fridge to go to the service center. 5 years is a long time yaknow. have them check for the freon as it might have runned out.
Jan 14, 2008 | Candy CPCA240FFK Bottom Freezer...
Fridge not cold enough and build up of ice at back of fridge
May be your damper switch not closing your damper when it reaches tempature setting.
Dec 13, 2007 | Smeg FA311X Top Freezer Refrigerator
Candy fridge freezer
i have candy fridge freezer which the thermostat is on high setting but not cold as it should be. There is build up of ice around thermostat at the back of fridge inside. What is needed to repair?. Any ideas? Cheers!
Nov 02, 2007 | Candy CPCA240FFK Bottom Freezer...
Samsung RB2155SH Bottom Freezer Refrigerator Logo
734 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
