Question about Whirlpool Duet GHW9150P Front Load Washer
After the wash cycle is complete the clothes are still wet.
Even though the cycle says it's complete the clothes are still sopping wet, i put them thru the spin/drain cycle, it helps a little, but not completely.
  • kristi312 Mar 10, 2009
    do you mean the panel right under the door? how do i get that off of there?
    ok, i did that. there was some nasty stuff in there. we also cleaned out the long tube in the back of the washer. again, yuck. so we've washed another load, and still, the sogginess continues. any other options? thanks.
  • Whirlpool Master
  • 3,361 Answers
Open the machine and remove the drain pump. Clean out any debris and try again.
Remove the front panel.
The pump should be directly in front of you. Open it and clean it.
This procedure will have to be done occasionally.
Posted on Mar 10, 2009
  • steve
    steve Mar 10, 2009
    Yes. Should be 3 screws across the bottom of the panel.
  • steve
    steve Mar 10, 2009
    Remove the pump motor and bench test it with a 120 volt jumper wire.
Maytag washer is sometimes out of balance and clothes are sopping wet when spin cycle ends. Washer is balanced on the floor.
1ST thing put less clothes in washer each time
second ck to see that drain hose is not obstructed from draining out the chamber , ive seen fabric lint get stuck inside the drain valves and slow and eventually block them off
last thing to look at
temp defeat the lid lock switch and or watch it spin thru window , your looking for the speed it spins at (should be a blur !!) , if its slow and not steady in rate but instead sort of gets slow/fast/slow/fast this could be an indication that your tub drive system isn't working well , this depends on a large bit of things working properly , but could be as simple as a worn out drive belt too.
Feb 03, 2017 | Maytag Washing Machines
Spin cycle not working.
would make one think perhaps the timer or control board needs serviceman to fix
May 11, 2015 | Washing Machines
Clothes are sopping wet even after doing the spin cycle 3 and 4 times, water is going through hose fine it seems, it a front loader
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 27, 2011 | Kenmore Energy Star 44092 Front Load...
Frigidaire model # GLMV167OAS Makes a loud buzzing noise during the spin cycle. Completes the cycle but clothes are still sopping wet. What to do???????
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 22, 2011 | Frigidaire ATF6000ES Front Load Washer
Hi, my neptune washer will not spin clothes dry they come out sopping wet. can you help? thanks
if there is water standing in your washer your pump is clogged clear it out and will correct the problem ; if there is no water in the machine when you complete the cycle but the clothes are wet it did not spin more than likely your door switch is probably bad replace it
Aug 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
Clothes sopping wet at end of all cycles
Here is a tip that I wrote a bout front load washer spinning and draining problems...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 16, 2010 | Frigidaire ATF6000ES Front Load Washer
Spin cycle weak
The pump either got some old sock in it, or the pump cold be clogging up with left over sop,
Nov 26, 2009 | Kenmore 27032
Whirlpool Duet GHW9150P Front Load Washer Logo
585 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
