Question about Kenmore 15208 Mechanical Sewing Machine
Needle doesn't move
I was sewing cotton fabric. After rewinding and replacing a bobbin I tried to sew again and the needle wouldn’t move at all. Machine is making a “starting noise” but it is just stuck. I tried to manually turn the wheel on the right but it is also stuck and doesn’t move either way. Do you know what might be the problem? Thanks.
  • NEAL
    NEAL Apr 08, 2014
    SEE IF THERE IS ANY THREAD HUNG IN THE BOBBI CASING SMALLEST PIECE OF THREAD WILL STOP IT FROM MOVING .IF YOU SEE SOME ROTATE THE WHEEL IF YOU CAN IF NOT TRY AND REMOV ETHE THREAD EVEN ADDING A LITTLE OIL TO THE THREAD TO HELP REMOVE IT
  • 98 Answers
The problem is some fabric, dust or thread is stuck behide the plate that holds the sewing needle and foot.
Posted on Mar 10, 2009
Iam sewing seats. but the threed stared braking at the needle & it want saw.
Most likely, it has to do with incompatibility of the needle, thread, and fabric. The force of the needle penetrating the fabric multiple times is actually causing the thread to (wear &) fray and eventually break. There are needles with larger grooves that tend to protect the thread during stitching. Some may recommend a Top Stitch Needle (Home Machine Needles Superior Threads Why Topstitch? The Topstitch needle is the most common needle type used and recommended by professionals and educators. We recommend the Topstitch for piecing, quilting, embroidery, appliqu?, and construction. These needles are available in four sizes to accommodate all thread types, including metallic threads. The Topstitch needle has a larger eye and deeper groove. It is often referred as the MAGIC NEEDLE. It really does make a difference in your sewing experience.)
Why Use Topstitching Needle
Also, if the thread is a tight fit through the needle eye, it will also tear the thread. Make sure that the thread will slip easily through the eye. Go to a larger needle, instead of 90, try a 100.
Be sure to use a brand-new needle.
All About Needles
The Parts of Sewing Machine Needle
You may also consider changing the type of thread you are using. Go with a stronger thread, ie polyester, rather than cotton. Cotton will shred and break easier.
You will probably need to re-adjust the thread tension. If it is too tight, it will also break the thread. If you are using a heavier weight of thread, you will need to adjust both the upper and bobbin tension to accommodate the heavier thread.
Bobbin Tension How and Why Tension is Adjusted
If you sewing fabric that is sticky, ie vinyl, oilcloth, you should try to use a roller presser foot, a teflon presser foot, or a walking foot to help the fabric move with the feed dogs.
Sewing Heavy Fabric with NON Heavy Duty Sewing Machine SEWING IN GENERAL
Tips
Sewing through many thick layers of fabric Sactin
http://www.kollabora.com/q-a/sewing-denim-and-thick-fabric
14 Fantastic Sewing Tricks and Tips Making the World Cuter
How to Sew Upholstery DoItYourself com
Apr 22, 2016 | Sewing Machines
What makes stitches skip?
Skipping stitches is usually the needle choice. OR if could be blunt (needles are supposed to be changed every 8 - 10 hours of sewing) There are needles to be only used for sewing stretch fabrics, these are the "blue needles" of ball point needles, then there are the Universal needles for sewing woven fabrics cotton etc. then there are needles only for sewing denim.
You will need to identify which fabric you are sewing and use the appropriate needle.
Then there are the sizes #12 #14 #16 or 75 80 or 90 I'm not sure which numbering system you are using the smaller the number the finer the fabric is the usual way to go..
Also check that the needle is in the correct way. The scarf (the flat side of the needle is to be facing the back of the machine) also check the bobbin as it too can be put in the wrong way and will even try to sew..
Check that your threads are suitable for the fabric If possible try and match the thread in the bobbin with the top thread type.
If all else fails go and have a cuppa and come back to the machine change the needle change the bobbin change the threads and most times it will be ok. cheers Dot
Sep 23, 2015 | Sewing Machines
Forgot to pull wheel out to stop needle moving when rewinding bobbin. Since then the bobbin sews one stitch then jams. Was working spot on until then.
Try a new needle. The needle may have gotten bent and that would cause those problems. Also, make sure your bobbin thread is threaded properly.
Mar 17, 2013 | Janome Harmony 2039 Mechanical Sewing...
Singer model 620 sewing machine needle pokes holes in fabric but doesn't sew with the thread?
try changing the needle--make sure it's the right needle for the
fabric being sewed
rethread the machine top and bobbin
make sure the bobbin is inserted into the bobbin case
it's also possible that the machine could have a timing problem
and needs to be checked
Feb 12, 2013 | Sewing Machines
I needle comes unthreaded whenever we try to sew. We've both tried numerous times and it doesn't make a sitch. The bobbin seems to be done correctly b/c the bottom thread comes up with no problem....
first let's deal with the needle becoming unthreaded, Keeping the needle threaded is easy, always keep thread tails of 3 to 6 inches on the top thread & bobbin at all times, & make sure the thread tail are pulled behind the needle before you start to sew,, this will ensure that the thread will not come out of the needle when you start to sew.
you mention the fabric is thin,, do you have a needle that's right for the fabric your sewing?
thin fabric needs a different needle than blue jeans fabric, check your top tension & see what the setting is on, usually 3 to 5 is good.
when the needle & thread are right for the fabric then the sewing is good.
also clean under the needle plate & bobbin area for loose threads or lint
also it's a possibility that the machine could be out of time & would need to be serviced by a sewing machine repair shop-as they have the tools for the job
Sep 22, 2011 | Brother LS-2125 Mechanical Sewing Machine
I am sewing a cotton piece of fabric for a dress and i do not know how to set the tension for cotton
The tension for cotton is set the same way tension is set for any fabric:
1. The thread should pull freely with a small resistance before/after it goes through the needle, on many machines that's half way on the tension adjustment.
2. The bobbin thread when dangled by the thread with the bobbin inside the case should drop down a bit when slightly flicking your wrist like you do with a yo-yo. If it reels out to the floor the tension is too loose. If it doesn't drop at all it is too tight.
3. Now make sure you use the right type of needle. For cotton you want a "sharp" and for reg. weight cotton about a size 10 maybe 12.
Now take a piece of strap cotton material like you're going to sew a seem and sew with a wide zig zag. Example the top side and then the bottom. They should appear identical, flat with needle holes at each side where the thread disappears to the other side. You should see no loop where the threads over lap each other and the material should not be puckering in the middle.
If that is not what you see then think this way:
The TOP side of the stitch is effected by the BOTTOM thread. the bobbin tension.
The BOTTOM side of the stitch is effected by the TOP /needle tension.
Adjust the responding tensions until the stitch looks the same on both sides. Now you are ready to sew your cotton! :)
Apr 26, 2011 | White Sewing Sewing Machines
JANOME RX18S
If it was sewing correctly BEFORE the needle break...why did the needle break in the first place?...and what fixes did you make?
If it sewed properly...what changed?
Cut your upper thread close to the spool...make sure the presser foot is raised and pull the cut off thread section through/out of the machine from the needle area (sewing direction...do not pull the thread backwards!)
Clean out the bobbin area...remove any traces of lint or pieces of thread...look for any broken off needle pieces... brush the bobbin area out....then add a drop of sewing machine oil (but only if your manual says to oil that area).
Remove the needle plate to expose the feed dogs...brush/clean out that area too and add a drop of sewing machine oil...then secure the needle plate back on.
Replace the needle...do it again...yup...some needles arrive bad from the factory. Make sure the needle is inserted and positioned properly. Then thread the machine WITH the presser foot in raised position. (The thread needs to get seated into the upper tensions.)
..with the.presser foot down...thread the new needle.
Oh...and use the correct needle for the thread. (a universal 80/12 is standard).
Thread can cause issues too. Try a different bobbin, or maybe a different spool of thread to see if that makes a difference.
Mar 25, 2017 | Janome Memory Craft 9500 Computerized...
Needle jams and breaks off
Needle jams....Thread is caught in the hook...solution...Remove the upper thread and bobbin case,turn the handwheel backwards and forwards by hand and remove the thread remands.
Needles breaks
1. Needles is damaged..Insert new needle
2. The needle is not correctly inserted....insert flat side towards the back
3. Wrong needle size for the fabric...Choose a needle to suit the thread and fabric.
Mar 24, 2008 | Singer 1116 Mechanical Sewing Machine
Kenmore 15208 Mechanical Sewing Machine Logo
372 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
