Question about Vacuums
Roller brush doesn't turn
I thought the problem was just that the belt broke. But I replaced the belt and turned on the sweeper and the roller brush would not turn and the belt broke. It is my daughter's sweeper and I was using it and feel responsible for the problem. It is a Bissell Bagless upright.Thank you, Karen Todd
  • 716 Answers
Sounds like the belt is maybe slipping did it brake the new belt as well?
Posted on Mar 10, 2009
When we changed the belt the new belt broke right away and the brush roller wouldn't spin. My husband cleaned off the roller and got it moving slowly again, but when we went to re-attach everythin
the thing you call wheels are actually called roller bearings that fit at both ends of the brush-roll there probably seized up you can get a new brush-roll with bearings from the link below.
http://dirtdevil.com/parts/category/brushrolls-uprights/
Oct 30, 2012 | Dirt Devil Breeze Bagged Upright
Sweeper brushes not rotating
I would say that your drive belt has broke or your brush roller bearing have stuck
Dec 11, 2011 | Vacuums
How do you check to see if you need to replace the belt on a Orick Commerical XLPRO14T Vaccum.
you can tip the vacume on it's side and turn it on and if the roller/sweeper is turning then the belt is good -- but if it is not turning then the belt is broke and needs to be replaced.
also at the same time as you replace the belt -- remove and clean the filter so the vacume is restored to normal operation.
c...
Dec 31, 2010 | Oreck Vacuums
Roller brush on Kenmore model: 116.31199100 won't turn
Refer to Larryclare1's solution at http://www.fixya.com/support/t1095798-kenmore_model_116_powermate_jr_stopped It worked great for me. Replace the belt, which you can get at Sears Parts store/online and clean out the hair as per Larryclare's instructions.
Feb 27, 2010 | Kenmore Vacuums
Sweeper Brush doesn't turn.
Could be that too much hair, string, or long fibers have been collecting around the roller. Remove it and clean it off. Also check the duct behind roller that goes up into the connection hose. Ther most likely is some sort of blockage.
Nov 20, 2009 | Dyson DC14 All floors Bagless Upright...
Roller does not turn; I was vacuuming a rug and a string got stuck in roller-took it off but now the roller will not turn. suction is fine.
The roller drive belt may be stripped, worn partway through where it goes around the motor shaft, thrown off the motor shaft, or broken. Take the bottom plate off the carpet sweeper and have a look.
If the belt was damaged when the roller brush got stuck, then you get to replace it. On most of these, the easiest way is to put the new belt around the roller pulley, reinstall the roller, stretch the belt around the end of the motor shaft, then turn the motor by hand while pushing the belt on. If the motor also has a pulley on it, you may have to remove the motor screws to get enough slack on the belt, then pull the motor into place and put the screws back in.
Aug 28, 2009 | Kenmore 25512/ 25513 Progressive Canister...
My vacuum has good suction but i can hardly push it across my carpet. any answers????
is your brush roller turning,that would cause it to be hard to push .the brush roller helps it walk across the floor.if your brush roller isn't turning then your belt is broke or the brush itself siezed up.unplug the vacuum and try to turn the brush roller .if it turns real free then your belt is broke.before you replace the belt always clean the motor shaft ,the old rubber from the old belt melts onto the motor shaft .if you don't clean it your new belt won't last very long.please leave feedback
May 04, 2009 | Kenmore Vacuums
Brush roller will not turn when I star to sweep.
maybee there is hair in it, do u know how to fix a psp that doesnt read games
Jan 15, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Vacuums Logo
264 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
