Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Red and Green double lines
I posted this before, however it fits your situation so here are my suggestions:
This is not a bad tube it is a convergence problem. Your convergence amplifiers are malfunctioning, and need to be replaced. If you have a background in electronics, you can remove the back of the TV locate the Convergence ICs (using the schematic or service manual) and the order the parts you will need which are the two convergence ICs and the biasing resistors (you will see these on the schematic). To remove them unsolder the pins, unscrew the screws holding them on the heat sink and remove them carefully, if they stick use a solvent to break down the adhesion of the heat sink paste. Once loose, take them out and then unsolder the biasing resistors and replace them with the ones you ordered along with the ICs.
To install the new ICs put heat sink paste on the back of the ICs and insert the pins into the proper holes in the circuit board. Screw the screws back in securely, and solder the connections back.
After doing this you will need to perform a convergence adjustment, using the cross hair adjustment screen (access this from your TV menu). and the you will need to do an advance adjustment using the crosshatch pattern (also accessed from your TV menu).
Once these are done use you service manual to follow the procedures on locking the adjustments into the TVs memory.
I hope this helps,
Thank you,
Shuttle83
Posted on Mar 23, 2009
Mar 05, 2010 | Sony KP-51WS520 51" Rear Projection...
Jan 25, 2010 | Panasonic 52LCX1516 52 in. Television
Jun 26, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Jan 14, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Jan 04, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Jun 27, 2017 | Hitachi 50SBX78B 50" Rear Projection...
Oct 27, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Aug 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Nov 16, 2007 | Samsung HCN653W 65" Rear Projection...
Jul 31, 2006 | Samsung HCM5525W 55" Rear Projection...
Mar 09, 2014 | JVC AV-56WP74 56" Rear Projection...
Jan 09, 2014 | JVC AV-56WP74 56" Rear Projection...
221 people viewed this question
I have the red and white double lines
red blue lines will not aline
