Question about GE Ovens
Is the compartment on the bottom of my oven the broiler?
I inherited this GE gas free standing oven with the house I purchased. There is a door on the bottom of the oven with a broiler pan in it. Is that the area that I use to broil? Do I actually cook the meat in there if I want to broil as opposed to the actual oven itself?
  • GE Master
  • 3,361 Answers
Yes, that is your broiling area.
Posted on Mar 10, 2009
My GE upper oven (Model # J KP27G002BG) just stopped working. No power light when turned on. The door light works. The lower oven works. Any ideas?
The lower burner in the top oven does not work, although the broiler does work. The broiler and lower burner in the bottom over both work. Could it be the burner element or would it be the relay board ?
Sep 10, 2009 | GE Ovens
Broiler on top works but oven wont ignite
OK, it is likley that the oven ignitor isn't working and needs to be replaced. To verify if this is the problem, when you turn on the oven to BAKE and set the temp at say, 350. Watch through the window, (or you can have the door open). Look at the bottom, back, center and see if you see a bright orange glow appearing under the bottom panel.
If you don't, that is why the oven won't lit the gas. There is an ignitor for both the broiler burner at the top and for the bake burner in the oven compartment.
It might be possible that your oven uses the same ignitor for both the broiler and bake burner tubes, so you could swap them if you wish to confirm that is the problem before you go and order/buy a new one.
Sometimes the ignitor burns out half way through but because it still lits/glows, people think it's OK, but it won't get hot enough to signal the gas valve to open and allow gas to ignite and get the oven cooking.
If you want to see a line drawing and a parts list showing the ignitor(s), go to and enter in the model number of your oven and click on the links shown.
Hope this helps and best regards!
Jul 31, 2009 | Ovens
I need to change my oven ignitor and I need a diagram to show where it is located. I have a Frigidaire model FGF353BADB. Free standing gas stove/oven.
Here's a diagram of the oven along with the Oven Ignitor (Part #19 on the diagram) and the Broiler Ignitor, (Part #26 on the diagram). They are located behind the gas deflectors located at the top and bottom inside the oven compartment, accessible from inside the oven, but you'll need to remove the rear panel at the outside back of the stove to disconnect the terminals tha supply voltage to the ignitors.
Be sure to turn the breaker off and/or unplug the range from the 220V-AC outlet first.
Hope this helps you complete your repair. Best Regards!
Jul 31, 2009 | Frigidaire FGB24S5A Gas Single Oven
GE True Temp Profile Oven, Locked Door Light stuck on
there should be some type of button that the door hits to turn it on and off
Mar 24, 2009 | GE Profile JTP18 Electric Single Oven
XL44 Gas Range will not light
Kinda sounds like the hot surface igniter is out. It is located under the oven section under the bottom panel. They are relatively easy to replace except you need that oven today I'm sure. Let me know how it turned out.
To replace the hot surface you need to take the bottom panel off and access the assy you need a 1/4 nut runner and remove couple small screws unplug the igniter take it to a parts house and 12 to 20 dollars later you're good as gold. When I say parts house appliance parts.
Nov 27, 2008 | GE Ovens
GE Oven does not ignite, bute Broiler does.
Your problem is with the oven igniter. You have the stove MODEL# so you should have no problem finding the part you need.Shop around to get your best price. Good Luck Friend.
Oct 14, 2017 | GE JGRP20 Gas Single Oven
Sf195lehz5 free standing gas oven,
Check both gas valve solonoids for 216 ohms [blue broiler wire to the orange common and red oven wire to orange common] both must be ok.
Check oven temp sensor for 1080 ohms.
If above are ok then the problem is either the spark module or the control board.
Since the gas valve was not opening and there was not ignitor sound I replaced the spark module for about $90. You have a 50-50 chance of being right.
My range is relitively new and I'm haveing an oven light problem which I traced to the control board so I may replaced this board to for about $200.
Oct 05, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
Ovens Logo
100 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
