Question about Nikon Coolpix 3200 Digital Camera
MEMORY CARD I have a NIKON COOLPIX 3200. I have been useing a JESSOPS 256mb memory card since i got the camera 5 years ago,now the camera has a on screen message saying-THIS CARD CANNOT BE USED.PLEASE CAN U HELP, THANKS
  • 423 Answers
Hi there.
This may be easier than you think.<grin>
SD cards can become accidentally locked. Double check your card. Take a look at the side of it. There will be a little switch. Make sure the switch is in the unlocked postion and see if that's your problem. Let me know if that doesn't help.
Rob
Posted on Mar 10, 2009
  • Rob
    Rob Mar 16, 2009
    Did this solution not work for you?
  • Rob
    Rob Mar 25, 2009
    Please leave me a comment so I can better help you with your problem. If not, you can rate my solution a fixya.
    rob
Have a nikon coolpix 3200 installed the picture project onto computer but doesn't open when camera is hooked up to computer like it says it's supposed to. even when I open it, it will not transfer pictures...
Picture Project was retired years ago, replaced by Nikon Transfer and Nikon ViewNX. You can download the current versions of all (free) Nikon software from
http://support.nikontech.com/app/answers/detail/a_id/61
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Apr 16, 2011 | Nikon Coolpix 3200 Digital Camera
I have a 256MB compactflash memory card for the coolpix 4300 that was bought over 7 years ago. I went to Radio Shack and Walmart looking for another. The salesperson told me that the SandDisk 8GB...
According your camera specs listed on dpreview.com:
http://www.dpreview.com/reviews/specs/Nikon/nikon_cp4300.asp
your camera must support the FAT 32 file format in order to use a compact flash card that exceeds 2.2 Gb. I question whether a camera 7 years old supports an 8Mb card, but I haven't found any specific upper limit listed online anywhere.
Oct 22, 2010 | Nikon Coolpix 4300 Digital Camera
Nikkon coolpix L1 After downloading memory card .. then putting back into camera. Reading says "cannot read memory card." Checked card out at store verified that it is good. Why does it not work in my...
A couple things you might try.. remove the card carefully and check the position of the "lock" tab. Make sure it is fully in the unlocked position - not locked or a point between the two positions. Reinsert and try again.
It sounds lie you're using a card reader to download the pictures - try formatting the card while in the card reader via computer. The card should be completely empty when the format is complete. You can even try copying files to and from the card to make sure its ok and format again. When complete, try again in camera.
If the problem persists, check to make sure the card is on Nikon approved memory card list for use with the Coolpix L1 (provided below):
The following is a list of approved memory cards for the Coolpix L1 digital still camera. These cards have been tested and approved for use with the Coolpix L1.
The L1 uses SD (Secure Digital) memory. Sandisk:
  • 64MB, 128 MB, 256MB, 512MB, 1 GB, 256MB*, 512MB*, 1GB*
Toshiba:
  • 64MB, 128MB, 256MB, 512MB, 1 GB, 128 MB*, 256MB*, 512MB
Panasonic:
  • 64MB, 128MB, 256MB, 1 GB, 256MB*, 512MB*, 1GB*
* - Cards rated for 10MB/s (high speed) Other cards have not been tested. For more details on the memory cards listed above, please contact the manufacturer.
The list came direct from Nikon Support. Other cards may work, but only those on the list are approved. Successful use of other cards can not be guaranteed.
I hope this helps!
Sep 30, 2010 | Nikon D60 Digital Camera with 18-55mm lens
Nikon coolpix 5700 shows no memory left after purchasing a new card & batteries
The largest CompactFlash card that Nikon approved for the 5700 is 256MB, which is what I'm using in my 5700. That's small by today's standards and you probably won't even find it in stores. I see some web sellers have 256MB cards for only $6 or so. Other commercial card sellers on the web claim that the 5700 will handle CF cards up to 1GB capacity. That's what I might try since online they're selling for as little as $8 plus shipping. Given that the 5700 was introduced in 2002, any cards bigger than 1GB probably won't work.
Jul 21, 2008 | Nikon Coolpix 5700 Digital Camera
System error showing up on Nikon coolpix 3200
A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. Before sending the camera in, check these:
1. Use the memory card that originally came with the camera (or a Nikon approved card)
2. Remove and replace the battery
If the error is still displayed, contact Nikon's Service Department (below). If the above tips do not help the camera must be sent to Nikon Service, there are no user serviceable parts on Nikon Coolpix cameras.
Jun 13, 2008 | Nikon Coolpix 3200 Digital Camera
Memory stick
The 3200 uses SD cards. It will not work with SDHC cards.
May 30, 2008 | Nikon Coolpix 3200 Digital Camera
No memory card will work in my Coolpix camera
Nikon has tested the following cards and approved their use in the Coolpix 3200:
SD memory cards:
SanDisk 16/32/64/128/256MB
Panasonic 16/32/64/128/256/512
Toshiba 16/32/64/128/256MB
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
Multi Media cards (MMC) are not recommended and should not be used.
Jan 23, 2008 | Nikon Coolpix 3200 Digital Camera
Switch on - Switch off! Coolpix3100
Coolpix uses SD cards, not CF. Anyway, try using the camera without memory card, only with internal memory. If it works, then replace memory card.
Oct 01, 2007 | Nikon Coolpix 3200 Digital Camera
Out of memory
Try Reformatting the card in the camera . Then come back
Jun 18, 2007 | Nikon Coolpix 4200 Digital Camera
Nikon Coolpix 3200 Digital Camera Logo
175 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
