Question about Uniden BC72XLT Handheld Scanner
Wont get any transmissons
I have my scanner and i programmed it to the frequency i wanted and its scan and keeps going across the screen so i know for sure it is scanning. it wont pick up any tranmissions.
    President:
  • 2,976 Answers
Turn the squelch back until it screams at you and then turn it forward until the radio JUST gets quiet. If you have over squelched, you will also block the signals.
Posted on Mar 10, 2009
How do I program a uniden BC 145xl base scanner
  • Press the power button to turn the scanner on.
  • Press "MAN" (for manual)
  • Now pick a channel where you want to store a frequency at and enter it on the keypad.
  • Now press the "MAN" button again to go to that channel.
  • Now enter the frequency you want into that channel and don't forget to include the decimal point.
  • Now press the "E" button (for enter) and you have programmed one frequency.
  • Repeat these steps until your scanner is programmed.
  • Now you can press the up and down arrow buttons to scroll manually through the channels or just press "scan" to scan through them.
  • Make sure to keep your squelch just above the noise so you pick up stations well.
  • Hope this helps.
Nov 24, 2011 | Uniden Radio Communications
I would like to somehow w/out cost of any kind,to get scannercodes for my bearcat scanner that i bought sometime ago,i had them programmed at one time "got the codes from a neighbor and it was nice...
Hi,my name is John. Welcome to FixYa. Get your frequency,s here www.RadioReference.com To program your unit, press the PGM button, enter the channel you want to store it in from the key pad, then press PGM button, then enter the frequency you want including the decimal point, then press E button to enter. To program another frequency use the arrow up or down. When your are done, press SCAN and that's it....good luck and thanks for choosing FixYa....John
Nov 02, 2010 | Uniden BC340CRS Base Scanner
I have a Uniden Bearcat 140 10 channel scanning radio and need to know how to program it. Can you help? The Model is BC 140 and the serial # 73061234 It was my dads and he passed on and I want to...
Your scanner is a basic 10-channel "oldie" and it's fairly simple to program and operate. To enter/program a known frequency:
- Power the scanner On
- Press MANUAL to stop scanning
- Press MANUAL repeatedly to advance to the channel that you wish to program
- Enter the desired frequency, including the decimal point (e.g., 156.225).
- Press E to enter the frequency into memory
Press the MANUAL key to advance through the channels, and press SCAN when you're ready to listen.
For a comprehensive database of active frequencies in your area, visit:
Bill B.
Listening in since the 60's
Oct 20, 2010 | Uniden BC244CLT Base Scanner
Wont pick up any frequencies
Hi, my name is John. Try to program some frequency,s in it. Get them here. <a href="http://www.RadioFreq.com">www.RadioFreq.com</a> or <a href="http://www.RadioReference.com">www.RadioReference.com</a> ...instructions are #1. Press the E/PGM button. #2. Enter the frequency you want. Press the E/PGM button. #3. To program frequency, press the up- down arrow. #4. To exit, press the HOLD or SCAN button...... hope this was helpful....
Aug 27, 2010 | Uniden BC340CRS Base Scanner
Wanted to program frequencies into the scanner but it is frozen where i cannot go inot manual and scan. All other functions work such as weather channel lock, light, etc. Capitol P on the left side of...
This is a new one on me. Press the review key to see if there is a frequency programmed on what could be channel 8 (P missing a segment of the display). Press the manual button then the period twice. If all else fails, open the case and push the reset button.
Jun 15, 2010 | Uniden BC60XLT-1 Handheld Scanner
I want to know what the mega hearts nos are for the town of zimmerman is so i can program my scanner in or the frequencies are for my scanner
You can get you frequency you want at www.RadioReference.com ...To program.. Press E/PGM, enter the channel you want, enter the frequency you want including the decimal point, then E/PGM, then SCAN....hope this helps...
May 28, 2010 | Uniden BC340CRS Base Scanner
Lost manual and cannot program scanner bc145xl
Try these instructions from Wiki.answers
Turn on unit.
Press MANUAL button.
Press MANUAL button again to select the channel you want to program. Note the channel in the display. If there is a hyphenated symbol in the upper left corner the channel has been locked out. Press the LOCKOUT button once to remove the symbol or press the LOCKOUT button to lock a channel out. To find out if there is a frequency programed into that channel, press the PREVIEW button. Each digit of the frequency that is stored in memory will be displayed in the LED display. To program a new frequency into that channel, simply press the digits of the frequency you want, including the decimal point. Press the "E" keypad key to enter it into memory. If you get a "E" displayed in the LED display, the frequency was entered wrong, is not a valid frequency or is out of range for the scanner. Last but least, the scanner is not working properly. If the channel is active, (communications going over it) set SQUELCH to higher number, until you hear the communications or just noise. To set the SQUELCH, select a channel that has only noise and turn it down to the point the noise disappears. You make have to readjust it to your liking. Once you have the channels programed you can select the SCAN button to listen to all the channels or select the MANUAL button to listen to just one channel. If there are channels that you don't want to hear during the scan mode, go to MANUAL and select the channel you don't want to hear and press LOCKOUT button. Then press SCAN again it will only scan channels you want to hear.
Hope this helps.
Sep 07, 2009 | Radio Communications
Need to know how to program a radio shack pro-94 handheld scanner
press the "prog" key followed by the "Trunk" key then the number "1" key.
Press the "down arrow" key until you see the initials Ed on the screen
Press the "E" key.
Enter the frequencies (including the decimals)
you must press the E key and the Prog key after each frequency, after you finish entering your frequencies, press the scan key.
If you need to clear your scanner, turn it off, press and hold down the number 2 and number 9 keys, while holding them down turn the scanner back on, "clear" should start flashing on the screen, once "clear" stops flashing you can enter the frequencies.
Jan 03, 2009 | Radio Shack Pro-94 Scanner
Programming scanner
go to www.radioreference.com and find the forums page, then go to the radio shack scanner forum and you will find anything you need to know there.
Sep 15, 2008 | Radio Communications
Scanning programmed channels
Not exactly. You can program channels however into the Private bank. To do so though you must search for the channel first...This may simply mean going to a channel you already know by using the band button to start searching...Push the hold button to stop it close to the frequency and then use the arrow keys to get to the exact frequency. then push the Prog button. After pushing it, push the Private button (you will see CH next to the frequency) using the arrow keys select the channel you want to store on and push Prog again. To scan the stored channels simply push the private button...Done! It can be a tedious process...expecially with 50 channels....but It's the only way I know how to do it...Good luck!
May 11, 2008 | Uniden BC350C Base Scanner
Uniden BC72XLT Handheld Scanner Logo
130 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
