Question about Casio Watches
Battery in my wrist watch is dead.
I opened the case in the back of the watch but found a large clip holding it down. I was unable to get the clip off. I didn't want to force it off. Help
  • 2,334 Answers
Take an eyeglass and examine that contact (you say clip) all the way around till you find where it is going into the movement. You will notice that the ends of the contact is cliped on the small plastic knobs. Take fine pointed tweezers and undo the contact ends by pulling them outwards. That should release the battery.
Do not forget to rate,please.
Posted on Mar 11, 2009
How do you take the back of a wrist watch off so you can change the battery
The Proper way is with a "watch case wrench". They can be purchased for a few dollars on Amazon and E-bay. In most cases unless you are changing many watch batteries the best option is to call around to local jewelers and pawn shops and ask how much to replace a watch battery. In my town it ranges from $30 to as little as $5.99 battery included.
Dec 14, 2013 | Meco 2PCS Watch Case Back Opening Tool...
I got the cover off my Coleman 40-727 wrist watch. I tried to slip the battery cover off as the previous expert suggested. Easier said than done. I was not able to slide the cover off. There appear to...
You can slide a thin metal strip(like a paper cutter or something) and lift the back cover of the case..Watches do not have clips. It just clicks into place thats all.
Jul 06, 2010 | Watches
Watch indicated "low battery" Jeweler replaced the battery but the watch did not respond and remains blank. The watch goes through 2 to 3 batteries per year and light remains on too long and cannot be...
Hi
Try resetting it - it worked for me. First, orient your watch face down (with the watch belt buckle opposite you), the new battery in and latched. Second, on the right side battery hold-down latch you will see a small metal circle (~1 mm diameter) with a black dot in the center. Take a small paper clip and touch this metal pad to the metal battery hold-down latch for about 1 second. This will reset the watch.
Rotate the tiny donut that clips over the battery so it touches the brass spring that is next to the battery, replace the back plate. you can use a small tool to carefully lift the metal contact back up off the contact plate. Also make sure the back of the case is on tight as this also plays a role the electro mechanics of this watch.
Let us know if you want to know something else accept the suggestion.
Thanks for contacting fixya.com
May 27, 2010 | Timex Ironman Data Link 5C291 Wrist Watch
Dead battery, how do I open?
I believe a local watch repairer will replace the battery for around 5$ that should include the battery, depends on the person.
Generally the battery is replaced by opening the back cover of the watch, in some cases special tools might be required.
the details of the battery read on top the one currently inside it.
Jan 30, 2010 | Watches
How do you unlatch the battery of a timex ironman watch. I have the back open now
You will need to look for any screws holding down a plate over the battery. Sometimes these only need to be loosened and sometimes they have to be removed. Sometimes the plate can be lifter slightly and the battery slide out from underneath. I hope this helps you. Best luck
Nov 19, 2009 | Timex 50-Lap Ironman Triathlon 59221 Wrist...
For Casio F-91W how do I replace battery? I see 4
Most of these resin-case F-series Casio sport watches use a fairly large lithium coin cell battery. Once the four screws holding the watch back are removed, you should be able to just pop off the stainless steel spring clip that holds the cell in place and pull it out, without having to remove any more screws. Be careful when replacing the clip, because it is asymmetrical and goes in only one way. Also be careful not to lose the tiny spring contact that connects the watch movement to the piezoelectric sound element glued to the watch back. If you lose the spring, the watch will still run, but the alarm won't sound anymore.
May 11, 2009 | Casio F91W-1 Wrist Watch
Casio Pathfinder PAG-50 battery replacement
ensure all three of the springs are present
the 2 at the top confirm that the case is closed the on at the bottom sends the sound signal.
ensure the metal casing on the back of the movement is not touching the back. and check the movement is correctly seated
Mar 28, 2009 | Casio Watches
Trying to replace battery in Kenneth Cole C275-04-KC3522
You need a watchmakers knife or caseback opening tool to open your watch.
1)If your watch has screwdown back, there should be grooves in caseback where you have to put in opener and unscrew that caseback.
2)If your watch has a 'clip-on' caseback, you have to carefuly examine the caseback and find the groove between caseback and watch case (it is called 'the lip'). This is the right point where to insert the blade of wtchmakers knife and open it using pressure and lever action.
3)The safest, but dearest way is to visit your nearest watch repair shop and ask for battery replacement. You may ask the watchmaker to show you how to do that, so, in future you can do that yourself.
Do not forget to rate, please.
Jan 13, 2009 | Kenneth Cole KC1104 Wrist Watch
Batterry replacement for Skagen-355LSSM
Without a Case Closing Plier ($15 to $20) or a Case Closing Press ($15 to $50) you will not easily be able to get the back to snap back in - see WikiAnswers
Nov 04, 2007 | Skagen 355LSSM Wrist Watch
Changing battery
Generally, there's a small clip that can be held out of the way with a screw. You may need to hold it back, and tighten the screw in order to insert the battery. It may be enough to hold the clip out of the way.
Nov 01, 2007 | Fossil ES9825 Wrist Watch
Watches Logo
50 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
