F 21 indicates a drain problem.... mostly due to a clog. Google
washing machine F 21 code. There are many links including
repair videos. Good luck to you.
Jeff: Go to "Allpar dot com" website and look for a complete list of codes for the older Chryslers. From mine I remember code 34 as having at least two posible meanings: a) EGR Solenoid circuit problema, and b) Speed control problema. Code 21 means a problema in the Oxygen sensor. Amclaussen.
Well, the code 12 is telling you the battery or the computer has been disconnected in the last 50 starts, code 21 is a problem with the O2 sensor, and code 55 is telling you there are no more trouble codes stored in memory. Code 21 means the O2 sensor is not switching from rich to lean, which can be a faulty sensor or a fuel problem.
This means the air intake cover problem. 21 Malfunction of
Air Intake Filter SwitchEnsure air
filter door is properly seated.Ensure front
panel is properly installed. Error codes here: http://www.palomastore.com/paloma_error_codes.html
Code 21 the check engine light will flash 21 times cycle the ignition key ON-OFF-ON-OFF-ON within 5 seconds. To cycle the
ignition key ON means to turn it only as far as it takes to get the
radio to come on. It does not mean to turn the engine on.
I don't have a dodge ram but the codes for the dodge vehicles where pretty much the same. For my intrepid the codes read for the following numbers
12 - Problem with battery connection (This usually happens if you disconnect the battery)
21 - Problem with the oxygen sensor circuit
52 - Oxygen Sensor signal input indicates rich mixture during engine operation.
It sounds like you may need to change an oxygen sensor. Hope this helps.
