Question about Tappan Ovens
Tappan gas stove take long to light then theres a boom
Serial vf 34501364
    Sergeant:
    Champion:
  • 338 Answers
You need a new ignitor.. the ignitor isnt getting hot enough to ignite the gas
Posted on Mar 10, 2009
My tappan oven won't work. stove and broiler work fine. ignighter glows but it seems like there is no gas.
I would check with your manufacturer and see if a professional can diagnose the regulator and even the gas valve itself.
Jul 17, 2012 | Tappan Ovens
Stoves 900GTF oven sparks but won't light
You may have problems with the gas valve, but check the wiresgoing to it first see anything came disconected
Dec 08, 2011 | Tappan Ovens
My oven is not working. At the bottom of the stove the ignitor light comes on, but gas doesn't come on. I would like to fix the problem, can you instruct me on how to fix my oven. I want to bake...
The ignitor is probably weak. You have a good circuit because the oven control is trying to light burner. The gas valve is alo fine because it is allowing current to flow. The ignitor with age does not draw enough current to light off the stove.
Aug 23, 2011 | Tappan Ovens
I have a 6 yr old Tappan stove, model TGF657BFW5. the burners work fine, but the oven and/or broiler take 5 to 10 minutes to light. when the oven and/or broiler do light, the flame is only about 1/8 to 1/4...
that ignitor should lite the flame within 40 to 60 seconds if not the ignitor is bad.even though it glows red it doesn't mean it's good it works with amps change the ignitor
Nov 06, 2017 | Tappan Ovens
Burners and oven will not heat
Something is stopping the gas flow. Turn off gas. Disconnect line from the stove have someone turn on and off the the gas just for a second.(make sure no flame in room). See if gas is available.If not it is the gas line leading into the house somewhere,not the stove.  Follow the piping to the first thng it comes to. Disconnect that line and see if it is open from there back to the connection. If you finally get to the valve,which I dont think you will . You will have to disassemble  or replace it.
Dec 10, 2008 | Tappan 30IN ELEC IGNa Oven
Tappan self cleaning gas stove and oven
Sounds like an problem with the ignition system.  You probably ought to get help on this.  GAS IS DANGEROUS.
Nov 21, 2008 | Ovens
Installed a new Tappan stove electric
check if there are links on the mains connector block and if so, make sure they are tight
Aug 10, 2008 | Tappan 30IN ELEC IGNa Oven
Tappan Gas Range Pilot light went out.
throw the piece of **** out! nobody seems to know how to do this, and there is zero customer service or help available. there are problems like this all over the net with no answers.
Jul 28, 2008 | Tappan 30IN ELEC IGNa Oven
Tappan gas stove,oven not lighting
yes replace the lower oven ig nighter you can do this from inside the oven pull the racks out then locate two screws in the bottom oven pan take the out pull the bottom plate then pull the flame spredder pan and you will see the glow bar replace that most common for you compliant
Jun 03, 2008 | Ovens
Ovens Logo
117 people viewed this question
Top Tappan Ovens Experts
Dan Webster
Dan Webster
ashburton
Craig Butler
Craig Butler
Are you a Tappan Oven Expert? Answer questions, earn points and help others
