Question about Canon PIXMA MP150 All-In-One InkJet Printer
My printer won't catch the paper feed-PIXMA MP150
The printer works as if it is about to print but the paper does not connect andgo through the printer. We tried to use the air to blow it out, butit still does not catch thepaper.
  • Anonymous May 22, 2009
    the paper wont catch and go through then i get an Error 2 flash
SOURCE: service error 5010
errore code 5010
Posted on Dec 25, 2007
SOURCE: Canon Pixma MP160 paper will not feed
Dont buy a cannon ever again
Posted on Mar 15, 2008
  • 29 Answers
SOURCE: printer will not feed paper / message E2 ...cannon pixma mp 160
don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
someone replied to my problem, i tried it and its fixed 1st time, for others its taken a few attempts and then worked..
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving PUSH it through! and hey presto it worked for me, everything printing fine now. hope this helps, let me know how you get on. Garty
Posted on May 08, 2008
SOURCE: Canon Pixma MP150
I would like to know how to download the software for the Pixma MP150 printer so that I can print documents
Posted on Nov 28, 2008
onyeredson
  • 404 Answers
SOURCE: CANON PIXMA MP150 Error E3
Hi! Have you checked the correct source for paper feed? you can use either sheet fed paper tray at base of printer and from top loose sheet feed. Make sure selection is correct, button below/to right of pwere switch.
Hope this sorts it, it did this on mine.
Paul 'W'
Onyer~EDson(:0)~[><
Posted on Dec 02, 2008
How to Fix Epson Printer Error code e-01.
Unfortunately the E-01 error can indicate a hardware failure with the unit that requires repair. Either a paper sensor has failed or the printer board has gone bad, please try these hard reset steps:
Sharply unplug the printer from the wall outlet while it is still on, and disconnect it from the pc if connected there
Remove all paper from the paper feed and blow it out with compressed air a few times > With a flashlight look in the paper feed
Make sure there is no foreign object like a paper clip > Blow some compressed air inside the printer as well to remove excess dust > Very carefully double check on the far left and right sides of the printer (Where the printhead moves back and forth) to make sure no paper has jammed up in there as it often does.
Still have issues, feel free to contact Epson Printer Customer Support +1800-243-0019...
Apr 13, 2017 | Epson Office Equipment & Supplies
Error message says "Paper tray
If printer is connectedto a network, type the printer IP address into the address field of your Webbrowser. Click on Configuration and select on paper menu and make you have thecorrect settings. Make sure you selected the correct paper source and papertype. Make sure on yourapplication, the print settings matches with the printer. Check the printsettings of the application that you are using. For example if you are usingMicrosoft Word, you need to click on print and click the properties button andgo to the paper tab. From the Paper Tab windowyou can modify the Input options like paper and the source (paper tray).You may click on the drop down and select "Automatically select" for paper trayand select "Use printer settings on paper type and then click OK. For further assistance,please contact Lexmark Technical Support.
Apr 08, 2011 | Lexmark X500n Color Laser All-in-One...
My kodak printer says there is a paper jam but there is no paper in it, also i bought new ink andit is not printing black
Get a syringe, remove the needle, remove the ink cartridge and use the syringe to blow air GENTLY through the hole the cartridge connects to. Make sure you have a cleaning cloth to remove ink dislodged from pipe connected at the print head, do this gently to remove any obstruction and there should not be too much mess and can easily be cleaned up. THIS WAS FOR YOUR BLACK INK NOT PRINTING.
Feb 19, 2010 | Kodak ESP 5 Printer
My duplex printer prints the second page(inside) of a half- fold card upside down. The printer wizard from orintmaster and printshop is designed for single- pass printers si that doesn't work... In fact,...
actually the gears in the printer are got worn out or some thing is blocking the gears so its not able to turn the paper internally to print on the right part of paper.and its printing upside down.remove the cartridge from the printer.and apply air blower in the inner area of printer.remove all the dust collected in the printer by blowing air everywhere in the printer.then check out if still the same problem the paper sliding gears needs to be replaced.you can get the gear assembly for local printer repair shop.they also help if replacing the gear assembly.
This will help. Thanks please keep updated.please do rate the solution if helped.thank you for using fixya
Oct 02, 2009 | Brother HL 5250DN Laser Printer
Printer will not recognize new blk ink cartridge.
1) Please do not use RE-FILLED cartridges as they will clog the heads terribly.
2) Turn off printer, Remove all cartridges, Gently move the printer head to the RIGHT with short thrusts. It is not necessary to move it completely to the right hand home position just simply away from the obvious jam.
3) With a flashlight and tweezers try to locate paper jam in the print head track. Best to also blow out paper chafe with a weak air bulb. WARNING: Do not let your male friend or relative use extremely strong air pump for tires or air blower at corner gasoline station. (Do not purchase the cheapest paper the future)
4) Unplug the printer to allow it to completely re-initialize the internal electronics..... about 10 minutes should be fine.
5) Replace all cartridges.
6) Power up printer, then re-boot your computer with the activated printer connected, then print a test page. Everything should be fine.
May 17, 2009 | HP PhotoSmart C4280 Laser Printer
I have plain paper in machine and haved used this paper at least 2 cases (not reams)without problem. The message on the printer states Paper mismatch. Replace transparacy paper with plain paper, Then press...
If you have the install disk, go to the program for your printer and uninstall it. Then restart the computer, it should recognize it again. Re-install the printer and it's program. That usually solves most problems when a gadget goes nuts.
Also keep a can of air around, blow out insides; sometimes there's a photocell with dust on it.
Nov 24, 2008 | Office Equipment & Supplies
Jammed paper -
try useing a can of air. lift te cover and blow it with the air. Then there is two fork prong in the upper cover, Its off white/clear. Hold that in and turn off then back on the machine. This will cause the printer head to move into visable range. Use the can of air and blow in the area the print head hides in. This should get it unless its glued in place by the ink. Try also blowing uder the head as it moves by.
Aug 11, 2008 | Brother MFC-640CW All-In-One InkJet...
Lexmark X1185
it does not take much to dirty up a printer even a little dust, try blowing a can of air, if that doesnt work the printer perferences might have changed either you have to thick of paper or not thick enoughtacording to your printing preferences or the page set up next time you go to print check the page setup
Jun 25, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Error 3 paper Jam, but there is no paper jam
Don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Someone replied to my problem, i tried it and it fixed 1st time. Also seems to of worked for others
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through!! and hey presto it worked for me, everything printing fine now.
hope it works, let me know, Garty
Mar 27, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Lexmark T630
I would suggest pulling the toner out and paper tray and using compressed air to blow out all ereas of the printer. If that does not work then you will have to remove the 2 screws at the back of the printer and with the two tabs at the top remove the backa nd look for paper jammed inside.
Feb 27, 2008 | Lexmark T630 Laser Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
316 people viewed this question
old marine
old marine
