Question about Candy CPCA270FFK Bottom Freezer Refrigerator
Fridge and freezer not working, compressor starts but keeps cutting out after about only 5 seconds.noticed compressor very hot(is this normal).
  • Candy Master
  • 3,361 Answers
Replace the start relay on the compressor.
Unplug it until you get the part or it will cause the compressor to fail.
Posted on Mar 10, 2009
LG model LFX21960ST. No cooling in either fridge or freezer. The compressor comes on for about 7 seconds when first turned on and then will cycle on for a few seconds every few minutes. The fan in the...
There could be a loss of freon(unlikely but possible), the start capacitor for the compressor is bad (most likely) or the thermal cut off switch on the compressor is cycling from the hot compressor.
Mar 28, 2017 | LG Refrigerators
Belling bk29 fridge freezer. freezer working but fridge not working. compressor running, thermostat set to 5, light working ok, defrost switch off.
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Sep 08, 2011 | Refrigerators
I have a Kenmore model 106.58964700 that both the freezer and refrigerator stopped working. The service technician said it was the start relay (Sears part number 2319792). I replaced the part with one...
Daleb870, Compressors on referigators run hot to the touch. You are experinceing a couple diffrent issues. First off 0 and 36 is a very ideal temp. The compressor and tubing are most likely hotter than normal as it was trying to cool down a fridge that was house temperature. After the fridge runs for a while and the load on the fridge is equalized the tubing will not be quite as hot. It and the compressor will still be very hot to the touch. The compressor its self right aroung 130f. But its normal.
Sep 01, 2011 | Refrigerators
Freezer is holdling temperature but fresh food compartment hot.
Top of Form
The blower fan also must work. if not there wont be cool air blown. If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
Jul 07, 2011 | GE Refrigerators
The fridge/freezer is making buzzing noises that go on for 10/15 seconds every 5 minutes or so. Both fridge and freezer have heated up to 49 and 26 degrees through the night. Help!
ur compressor is trying to start but the safety is turning it off may have a bad compressor but try this first might get it working again -(safety click sound) disconnects power when compressor gets to hot or is drawing to many amps--stuck--comp gets hot unplug unit and clean with a vacuum carefully under where comp and fan are this is the condenser area after cleaning or 1 hr plug in and check for start and that condenser fan is working may be reason for overheating-if still not working compressor needs service
Nov 04, 2009 | Maytag Freezers
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Fridge freezer not working after power cut
If the fan motor is running at the compressor you should first replace the compressor start relay.
If the fan motor at the compressor is not running replace the defrost control.
Feb 21, 2009 | Freezers
Compressor very hot + water leaking
This is not normal. The coolant charge is low which means it leaked out some where. Return it.
Dec 22, 2008 | Sub-Zero 650 / O Bottom Freezer...
Buzzing and low temps
sound like a compresser relay/overload ,uplug the refigerator remove back cover, remove relay that is on the compressor and check it by shaking it , it should not rattle. if it does replace it..
Aug 10, 2008 | Frigidaire FRS26R4A Side by Side...
ARB2214CB - Condensor is Noisy
It sounds as if the thermal limit on the compressor is cutting off power to the compressor when it gets too hot. There could be 3 reasons for this. One, the compressor is just bad...should be covered under the 5 year sealed sytem warranty (if its less than 5 years old of course) if this is the case. Two, the thermal overload and start relay assembly is bad. They are mounted directly to the compressor (big round black thing) and can be changed for about$14 in parts (unplug the unit before replacing!) Three, the fan that runs in the bottom near the compressor that cools the compressor and condenser is jammed or not rotating for some reason. It should run any time the the compressor is running. If it doesnt, it need replaced or the compressor will do exactly what you are describing. Hope this helps!
Oct 22, 2006 | Amana ARB1905C Bottom Freezer Refrigerator
Candy CPCA270FFK Bottom Freezer Refrigerator Logo
190 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Cesar Quant
Cesar Quant
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
