Question about Microsoft Windows Vista Ultimate Edition
Printer has started printing black pages
My all in one has will now only print black pages. I have done the cleaning cycle a few times but does not help. It prints all colors on the cleaning cycle.
  • 63 Answers
Hi
seems like the option "print black and white" in printer properties has been enabled.
kind regards
RAhUL_hunk
Posted on Mar 10, 2009
Epson WF-7620 will not print black.
I had a similar problem on my 3640 and had to run the clean cycle about 20 or so times. If you feel you are capable, you can also remove the print head and do a manual clean. YouTube has a few videos on how to do it. I have done this to one of my printers with very good success.
Apr 26, 2016 | Epson WorkForce WF-7620 Wireless Color...
No print on the page even though the printer appears to be printing.
The print head is either plugged or daamaged. If you print infrequently say less than a few times a week the ink actually starts to dry inside the print head. if this is mild then a few (but sometimes a few dozen) cleaning cycles will get it printing again. The cleaning cycle can be acessed bybeither the printing manager or by the printer properties through the conrrol'panel or from the all programs/start menu. On a real bad print head it can take a dozen or more cycles before you see any printing at all. once it starts usually a few more cycles will have it printing normally or printing at least. If it is real bad you basically will have two choices. One is tomreplace the printer or manually clean the print head using vinegar. The peintee is not out of ink so don't rush out and replace the ink carts. If they were empty the printer would detect the low level and not do anything. Cleaning the print head just needs a roll of paper towel and some ordinary vinegar. You just wet the towel with the vinegar and gently rub the bottom of the print head. The vinegar disolves the dried ink. So you wipe and change the tpwel until it comes clean. At this point you may need to ru one cleaning cycle but normally it will now print just as good as day one. This is the shop trick to revive ink jets. If you can do it, the worst that happens is your house smells like pickles and you just saved yourself buying a new printer.
Apr 30, 2012 | Canon MP610 Photo All-In-One Printer
I have a Brother MFC-6490CW that my husband purchased for me somewhere between one and two years ago. I just recently decided to use it, and the black ink would not print. I thought the original...
Power purge the machine:
Hold down the menu key. While still holding the menu key, unplug the machine and plug it back in. Do not let go of the key until the machine reboots and the screen says "maintenence". Hit the following keys: 7, 6, 4,black start. The machine will then go into "power purge" or deep clean mode for about 5-7 minutes. When complete hit: 99 to get out of maintanence and reboot. Be sure to have extra ink cartidges on hand as it does use up a lot of ink but this process works the best every time when the printer wont print
Feb 25, 2011 | Brother MFC 6490CW InkJet Printer
About a month ago, I bought new cartridges for my Epson NX400. It will print every color but the black ink on the test pages and on the things I print out. However, I have only printed one page since I got...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
Nov 25, 2010 | Office Equipment & Supplies
We just print black pages but the color cartridges run out. Do you use them for black printing?
No, but every time a printer is started  and after every 5 hours of printing(whatever you print) all the printing heads go thru a cleaning cycle - this cycle uses ink = your color inks are used a little at a time so the cartridges run out.
Normal behaviour.
Jul 20, 2010 | Canon Office Equipment & Supplies
My printer doesnt print out color, only black..
3 things will cause this. Either you are simply out of color ink, the print head is clogged or your driver is set to print only grayscale or black and white.
You can run the cleaning cycle a few times to see if you start to get it printing colors. If you printed a bunch of color stuff the last time you used it and it has set for a week or more (sometimes less) then the ink can dry and block the sprayed ink. The cleaning cycle helps clean it off and restore printing.
You can also look at the print settings from the start - then printers and then right click on your printer and then look at printing preferences. There should be a setting that says print color or gray scale or auto. It may also show you the status of the ink, if they are empty or not.
Usually after all this you will find it just needs quite a few clean cycles and away it goes.
Apr 24, 2010 | Brother MFC 420CN All-In-One InkJet...
I have a Brother MFC 240C printer that will not print black ink. I just changed all the cartridges. All the other cartridges print. I ran the clean cycle many times. No error messages just blank paper.
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 17, 2010 | Brother MFC 240C All-In-One InkJet Printer
Brother 420CN printer will not print black ink. Have replaced the cartridge and after several cleaning cycles, it still will not print properly. Test Print shows colors are fine but black ink is hit and...
Good Luck
RK
Dec 20, 2009 | Brother MFC 420CN All-In-One InkJet...
Black won't print
I have this same model printer and had this same problem. I solved it by running the cleaning cycle repeatedly (30 times or more). It nealy drained the black cartridge, but they're cheap compared to a new printer ($100 for the mfc240c that replaced it). Press the ink button to the left of the display. Select "test print" and "print quality from the menus, then hit print. After printing, the display will ask if quality is ok. Press 2 for no. It will ask if the black was ok, press 2 for no, if the color looks ok, then press 1 when it asks if color is ok, then press 1 when it asks to start cleaning. In a minute or so, it will beep and tell you to press start. Once the sheet prints again, repeat the same sequence. I didn't even wait for the display, I would just press 2,2,1,1, each time it printed. At first the black section was blank, the one dash appeared, then two or three. I gradually gained on it until I had most of them working again, then let it set overnight and ran a few more cycles the next day and it finally all started working.
Jun 22, 2008 | Brother MFC 210C All-In-One InkJet Printer
Black ink not printing
Fix ink cartridge
I had same problem. I must have ran the clean cycle more than 30-50 times over a period of days. That never made any difference. I was about to toss the whole thing but figured I would try one more thing. If it didn't work I would be in no worse shape. Here is what I did.
Took an almost empty black cartridge and inject a lot of 100% Acetone to dilute ink. Left some black in it since I didn't want to think it was empty. Inserted this cartridge and ran the cleaning a few time. IT WORKED. I used my word processor program and filled a page with large bold font characters and printed a page or two. Each page cleared more nozzles. After doing this cleaning/printing a number of time, I put in the full good cartridge. Ran the cleaning a few time to eject any of the Acetone diluted ink. Ran the printed page a few time to remove more of the diluted ink.
Everything seems to work now.
Apr 20, 2008 | Brother MFC-5440CN All-In-One InkJet...
Microsoft Windows Vista Ultimate Edition Logo
46 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
