Question about Bernina Activa 130
Monofilament thread nesting up underneath
Bernina Virtuosa 150 Top thread is monofilament, bottom is regular thread.....I've adjusted to all sorts of tensions and cannot get it to work! Trying to machine applique using hem stitch and the top thread creates a nest underneath the fabric and the bobbin thread isn't catching....please help! I've rethreaded, and tried just about everything I can think of.
  • 1 more comment
  • melrose1113 Mar 12, 2009
    Yes, it sews fine with regular thread
  • Wayne5 May 11, 2010
    will it sew with regular thread?
  • David Shaub May 11, 2010
    Try turning the spool around. The mono thread will pick up a twist and the bobbin won't be able to catch it.
    New Friend:
Should I load a second or a cotton thread in the bobbin for the bottom?
Posted on Jan 09, 2013
    Problem Solver:
  • 6 Answers
Mono thread can develop a memory and curl itself around things. I hate the stuff.
Posted on Mar 13, 2009
How to successfully use monofilament thread on Janome Horizon 7700
Generally, it is better to use monofilament in the top, not in the bobbin. There is also a problem with tension so our instructor had us tape a paper clip vertically about midway between the spool pin and the first thread guide on the top of our machine, set the spool behind the machine in a small cup and ran the monofilament through the paper clip and threaded as normal.
May 12, 2017 | Janome Sewing Machines
Is there a special type of monofilament thread to use?
I would suggest that you don't use this thread, it is too fine for the tension device on a domestic sewing machine, and they just don't like it. Too strong, too fine. Its best used in industrial blind hemming machines, if you look at RTW trouser hems you'll often see monofilament utilised here.
Feb 23, 2015 | Elna Quilter's Dream 6003Q
Bernina virtuosa 150
Make sure you are turning the flywheel the correct direction.
Jul 15, 2014 | Bernina Virtuosa 150
The bottom seam is very loose
Try adjusting your tension to a lower number. Don't make large adjustments all at once. Also, using some spray air, clean out debris and threads from under the bobbin. Good luck!
Jan 13, 2014 | Bernina Virtuosa 150
How to fill a bobbin on Virtuosa 150
Put the thread spool on the vertical spool holder with a sponge pad underneath. Wind the thread off the spool and through the small wire thread guide next to the spool holder. Take the thread across the top of the sewing arm to the tension unit just next to the gap in the case through which the thread is normally threaded - the tension unit looks like the top of a shiny screw without the slots in it. Wind the thread in a clockwise direction around the tension unit once and pull the thread with a bit of tension until it slips into the sprung gap around the underside of the shiny part. Slip the end of the thread through one of the holes in the bobbin and, preferably, wind a few turns on, then push the bobbin onto the bobbin winder shaft at the right-hand end of the top of the machine. Turn the bobbin clockwise by hand a few more times to make sure the thread is 'locked' onto the bobbin and then just push the lever adjacent to the bobbin winder to the left. To wind the bobbin, you then press the foot controller and either stop when you've got enough thread on the bobbin or let it stop automatically when full. Make sure you dont go so fast that the spool rattles-around on the spool holder otherwise this could spoil the way the bobbin gets filled.
Sep 28, 2011 | Bernina Virtuosa 150
I tried to use a double needle on my Bernina 160. The top stitching looked ok, but underneath the thread was straight and you could pull the bottom thread right out. I've heard the bottom is supposed to...
When you thread the top thread, ALWAYS RAISE the presser foot so the thread will seat completely in the tension disk. If this doesn't improve the stitch, try tightening the top tension. If it is too loose, the bobbin thread will lay on the surface of the fabric. When the top tension is tightened, it will pull the bobbin thread up into the fabric.
Feb 03, 2018 | Bernina Virtuosa 160
Sewing Machines Logo
231 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
