Question about Eureka Smartvac 4870 Bagged Upright Vacuum
It is not clear how to access the front spool on a Eureka 'Boss - smartvac' 4870K vacuum cleaner, when replacing the belt. Trying to force the flimsy black plastic lever attached to the shiny silver spool where the front end of the belt appears as if it should go, would cause breakage.
  • 33 Answers
The shiny spool is the mechanism that stops the brushroll (brushroll control). The belt only slips around the brushroll, and the motor spindle.
Posted on May 19, 2009
Eureka 4870 upright vacuum cleaner needs powercord replacement
If it's not too badly damage you can wrap it with black electrical tape
Oct 20, 2014 | Eureka Boss SmartVac Pet Lover Bagged...
Vacuum starts then stops
It sounds like a break in the cord or a loose connection at a plug. If the cord is self winding then it could be contacts on the spool too.
Nov 22, 2013 | Electrolux Eureka Boss SmartVac Vacuum...
How to replace the belt on a 4703 Electrolux vacuum
Instructions for changing the belt are found on page 20 of the manual (4700 series). A downloadable, printable manual is found at the below site.
Mar 09, 2011 | Electrolux Eureka Boss SmartVac Vacuum...
4870 roller part number
I know the belt number
Eureka Part Number: 61110B (Replaces 61110, 61110A)
And the roller i think: Genuine Eureka Brush roller part number 61250-3 for Eureka The Boss/Smart vac/smartvac ultra 4800 series vacuums including models 4870 and 4880
Hope this helps you.
Jan 03, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
My Eureka The boss Smartvac Model #4870 roller brush won't turn even on the highest setting and the belt smells hot. we took the belt off. How can you tell if it needs replaced?
Just by what you explained I can tell that it needs to be replaced. The belt doesn't have to be broken to need replacing, if it is stretched and worn then it will slip on the motor shaft and not turn the brush roll and get hot. Here is a link to the belts you need and the manual which has instructions:
Bissell 4870 Belts
Owner's Guide (3,666K download)
Dec 11, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
I have a Eureka 'The Boss Smart Vac'. The beater
Yes, you need to replace the belt. You should actually change this belt every year. Here is a link to the belt you need and the manual which has instructions:
Eureka The Boss Smart Replacement Belts
Dec 09, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka the Boss SmartVac just turned off and won't turn on
Make sure it is not the electrical outlet that has tripped. If not then you basically have 3 choices. Cord, switch, motor. A service tech. should be able to diagnose.
Jul 25, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Can't figure out how to get the belt around vacuum motor shaft
I am assuming you are referring to the beater bar belt. You will either find a release lever on each side or a small screw and bar restraining the bearing that holds the bar in place. Removing whichever of these you find will allow you to install the new belt. Clean up the dirt accumulation on the bearings while it is apart.
Dec 31, 2008 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka Smartvac 4870 Bagged Upright Vacuum Logo
226 people viewed this question
Top Eureka Vacuums Experts
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
