Question about Panasonic BL-C30A Network Camera
My BL30C will work wireless for some time then goes off line
I have used different routers the wireless will work from 10 min to 2 days but will eventually disconnect. The only way back up is to power cycle the camera. presently using D link DIR-615
3 Suggested Answers
Shuttle83
  • 1139 Answers
SOURCE: BL-C30A Can not access via web after a few days
Your cameras are losing conncetivity because of the air link being compromised this could be due to unintentional jamming (blocking of the wifi signal)or Resetting of the beacon (beacons can be set to broadcast at intervals) They are needed for the wifi devices to know that they are still a part of the network. These are more then likely your problem
Posted on Sep 27, 2007
ajinkyapai
  • 126 Answers
SOURCE: problem with comp
yes u can disconnect the ethernet port to pc.or check wther it is connected via wifi
Posted on Aug 12, 2009
Presario cq61 goes offline
Things That Affect Wireless Router Signals
1. Many wireless routers are using the same wirelesschannel. Many manufacturers choose channel 6 as the default. Change to anotherchannel.2. Analogue video senders used to send audio and video toother TVs in the home.3. Microwave ovens emit interference in the 2.4GHz band.4. Wireless speakers and console controllers can causeinterference with the wireless router.5. Bluetooth devices, newer Bluetooth devices can jump todifferent frequencies if there is a connection problem.6. Power cables located near the wireless router can causedropouts and speed reduction.7. Fish tanks will cause massive Wi-Fi shadow on the otherside of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflectwireless signal away your computer.9. Building materials will block wireless signals such asplasterboards with metal foil, reinforced concrete walls and floors. Alsoobjects near the wireless router such as metal filing cabinets and otherelectrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performanceby 25% when it is close to the wireless router.
Jun 08, 2012 | Computers & Internet
I have a Belkin F7D1401 wireless modem router and every 2 mins I am unable to access the website, I have to referesh the page 5-10 times then the website appears otherwise it says Connected to hotmail
Try a firmware upgrade:
http://en-au-support.belkin.com/app/answers/detail/a_id/4618/~/f7d1401au-basic-wireless-modem-router---firmware-update
good luck,
Majdi
Dec 27, 2011 | Belkin Basic Wireless Router
I recently got an ipod touch, and i connected to the belkin wireless router with it and it was working fine. Then, all of a sudden, one day, it says there is no wireless network from it. How do i make...
WIRELESS ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regard ,
Milan
Jan 08, 2011 | Belkin (F5D72304F5D7000) Router
My Belkin Wireless router has always only one or no bars of connection and my internet is always running slow or cant connect. The router is in the next room near the phone line with one single brick wall...
WIRELESS SECURITY ISSUES
Sep 22, 2010 | Belkin (F5D9230-4) Wireless Router...
Suddenly my wireless will not stay connected. I get online and in less then five mins. , as I try to go to a different website, nothing happens. Using firefox, will show loading then go to server timed...
Go into your "router" configuration under wireless, change the channel it operates on. It is possible some new electronic in your house or neighbor is causing signal interference on that channel causing you to drop your connection periodically.
Feb 03, 2010 | Gateway MX3560 Notebook
Router disconnects all wireless PC's every 5 mins for 10 secs
Login to the router via lan cable and set the timeout to a higher number. It might be called something different like Lease time or the like. Basically the router needs to release devices from time to time and it sounds like that setting is too high or too frequent might be a better way to word it.
Change that and that should do the trick.
Jul 30, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Wireless connection doesn't stay
change the router belkin have major problems like this, go for a sagen or other makes you will find cheaper models work much better and get a better range also
Apr 16, 2009 | Acer Aspire One PC Notebook
NEtgear RP614 cannot connect after a electricity shortage in our home :(
Reset the router to factory default. Usually done by unplugging the router hold in the reset button and plug in the router wait 30 sec. release reset button Wait 30 more sec. and unplug router again. Then reset your computer to obtain ip address automatically in network properties. Next shut down your computer, router and modem. First re-power the modem, give it time to boot (about 2 to 3 Min. for Cable and dsl or 7 to 10 min for satellite), next re-power the router, again give it time to acquire it's info (about 2 min.) then start your computer and try to access the Internet, all should be well...
Good luck, and have a great day...
Tim
Mar 23, 2009 | NetGear WNR834B RangeMax NEXT Wireless-N...
Wirless going down randomly
Hello ajestrella,
If your connection is a DSL, I think you need a "Micro Filter" to be connected to your phone lines. This will eliminate the disconnection or unwanted signals that causes you network to go off or disconnected. You can request this device from your telephone company.
Mar 11, 2009 | NetGear WGR614 Wireless Router
Panasonic BL-C30A Network Camera Logo
105 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
