Question about Toshiba Satellite A135-S4437 (492411122905) PC Notebook
Real dark screen on Toshiba A135-s4437
My screen on my Toshiba A135-S4437 has gone very dark, it can only be viewed with a flashlight or bright lamp dirrectly on it. Do I need to replace my entire screen to fix this? Is there maybe and easy solution to this I could repair myself?
Thank you
    Scholar:
  • 82 Answers
First I would check to make sure that the contrast/brightness buttons on the laptop weren't accidentally changed, making the screen dark. Also, try with and without the battery and power supply. Otherwise, unless it is actually the screen that is defective, it is usually a power converter replacement, which is a small circuit board, usually under the plastic cover directly under the monitor, which supplies power to the monitor. You may want to take it to a shop as they can isolate the issue easier.....
Posted on Mar 10, 2009
Toshiba tv goes black
the lamp has gone basicly there is a back light that lights the screen if this bulb goes you cannot see anything but it is all still there only way to fix this is to get a new lamp but sometimes the lamp is on a circuit board and the price is more then the tv is worth
Apr 29, 2012 | Toshiba Televison & Video
Display Shows on External Monitor, but very faint
one of two causes : inverter board damage ( Replace it) or backlight lamp damager (also replace it).
May 09, 2010 | Toshiba Satellite A135-S4527 Notebook
Screen is black but computer works perfect.
When this happens it means the back light needs to be replaced. The back light is a light bulb that lights up the screen from behind the LCD display.
Sep 07, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba satellite a135 monitor goes black
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S2386 Notebook
Blank Display, using exernal monitor, can see display info w/flashlight, display flashes light at startup
May 03, 2009 | Toshiba Satellite A135-S4407 Notebook
Cannot show laptop image on external monitor via Svideo connector
If you want to use your TV as an external monitor, you have to connect them via VGA (top) or DVI (bottom) cable.
Which connections does your Philips monitor have?
Jan 05, 2009 | Computers & Internet
Screen Brightness gone too low on toshiba satellite 1110 laptop
Hello Tim,
Sorry to answer u by this news :
this problem u have happening by 2 cases ..
1st Case :::: that's maybe ur screen lamps is broken ..so u can see the data but very dark or no Back-light .. so u will need to replace the screen..or advanced option but with expret person to change the lamps from another broken sceen,,
2nd Case ::::: The high-voltage board..it's small board built below the screen to give the screen the right voltage to light on .. so u will need to replace it also ..or Advanced option also but with expert electronic person to check it ..
best luck.
Dec 01, 2008 | Toshiba Satellite 1115-S103 Notebook
Toshibba laptop a135-s2276 ,my mother bords smd chip does not work so display of screen does not appear
The problem is well known witht this model Toshiba - the problem is the fan stops working and then hence shuts down to prevent overheating - it does not take long once the laptop is hot. Without replacing the fan just reboot the laptop until you hear the fan start again on reboot.
Oct 15, 2008 | Intel Motherboard
Toshiba Satellite  A135-S4437 (492411122905) PC Notebook Logo
143 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
