Question about Weather King 12AJA4801AH Air Conditioner
I have a Rheem ac unit for a trailor. The wiring
I have a Rheem ac unit for a trailor. The wiring for thermosta has been broken. How do I rewire it?
  • Ken Bledsoe May 11, 2010
    Do you have 4 wires?
  • Perry Putnam
    Perry Putnam May 11, 2010
    Are the wires at the T-stat or at the outside unit? Do you have gas heat, heat pump or what?
  • 478 Answers
Red goes to rc/rh
White to W
Green to G(fan)
Yellow to y
If a common it's usally blue or black
Posted on Mar 12, 2009
Replace contacts in ac rheem 060jaz split system were is reset switch
Get wiring schematic check wiring and the restet is turning breaker on and off to unit. Furnace included. Start checking for 24v . To contractor and through pressure switches. 208-230 volts in unit. Beaware
Sep 06, 2013 | Heating & Cooling
THERMOSTA WIRE BROKEN IN 2
What is the model number of your unit?
Jun 26, 2013 | Washing Machines
My rv furnace want start up i changed ac units new don't have the relay box build in it how do i rewire the furnace ?
Shooting from the hip here, but look at both the new and old wiring diagrams. Chances are that the new unit has terminal leads that would connect to the old units' relay/control box and you simply need to install the old box on the new A/C by connecting to the correct terminals. beyond that, you can build your own relay setup if you understand wiring diagrams. If you don't know wiring, I'd recomend taking to an RV shop, as you can damage either the A/C or the furnace or both if wired incorrectly... Hope this helped!
Mar 26, 2013 | Heating & Cooling
No left turn/brake light for trailer
In the Uk nearlly all trailor socket wiring is done from the rear light wiring of the towing vehicle so I suggest checking the wiring back from the trailor connection socket and also socket, it could be a broken or cut wire. Also will probably find your vehicle a control unit fitted the trailor socket which could also the problem. Find the pin outs for your turn signal on the socket and connect a bulb across this connection and the common earth to check its not a fault on your tralior.
May 26, 2012 | 2005 GMC Sierra 1500 Hybrid
Rewire a boat trailor
go to the local parts house and buy a wiring kit. it will tell you what colors go to what side and makes it pretty easy....cost bout 30. bucks
Jul 02, 2010 | GMC Sierra 1500HD Cars & Trucks
Rheem heat Pump model number RQPMA049JK Hunter Programmable thermostat When hooked up to thermosat with wiring code in manual it heats in cool mode.There is no setting on the thermostat to reverse...
does it not have a reveres switch at the bottom of the unit or if its the programmable type you must program both for heat and cold and the auto temp in the head will change when it needs to. However these are tricky to set up so if you want a step be step procedural let me know and I will give it to you plus there color codes. to boot.
Apr 11, 2010 | Heating & Cooling
I have a intertherm model 9007590 AC unit. The condensing unit was changed to a unit that has a common wire and a y terminal and the old condenser unit had three wires at condensing unit. I can't get it to...
the unit with3 wires was set up as a dual transformer the new unit is single transformer system. it needs to be rewired at thermostat,furnace,and ac
Jun 27, 2009 | Heating & Cooling
WIRING
why did the wiring burn?Id have the heat exchanger inspected before rewiring.better to be safe.
Sep 17, 2008 | Intertherm P3RA-048K Air Conditioner
Weather King 12AJA4801AH Air Conditioner Logo
135 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
