Question about ValuSoft Lets Ride Silver Buckle Stables for PlayStation 2
I can't save my game
I've tried and i can't figure out how to save my game. is there some trick or what? please help me!!!!!!!!!
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 69 Answers
First see how much space the game takes up, then see how much free space the memory card has
Posted on May 07, 2009
Microphone Problem MSI / Realtek
disable your internal mic, go to start--type computer management--go to drivers-- sounds and audio-- right click, and disable the one you dont use.
Jun 18, 2013 | MSI Microstar GE60 0ND-257US 15.6" Gaming...
Tip
Sony PSP Tips and Tricks
<ul> <li>The PSP is the hottest little handheld around right now. The PlayStation Portable Handheld system is very impressive and plays great games, music and movies. Additionally, the system does have a few tricks as well. Here are a couple of things you can try, some are fairly simple. Please note you must be careful with some of these tricks and they will be marked by a <b>*</b> before the "<i>how to</i>" area. Due to the price and the sensitive LCD screen always use caution when trying anything below.</li></ul> <i>While these tips are listed here, please do not attempt them if you are uncertain about any aspect of them. </i><br /> Jam to Tunes Using Your Car Stereo System Speakers <ul> <li> Use the following instructions to play your PSP games and movies with your cars audio system. <br /></li></ul>You will need a <i>FM modulator</i>, a cable with a <i>male stereo 1/8" headphone connector</i> at one end and <i>split left and right RCA connectors</i> at the other. The red wire with the 'in' line fuse goes to your car battery or switch. The ground wire grounds to the frame. Set the car's CD or tape deck to the FM frequency that is on the modulator. The frequency is usually 88.7 or 89.1. Plug the RCA connectors from the cable into the RCA jacks on the modulator. Plug the headphone end of the cable into the PSP. Turn on the PSP with the volume set at half way. <br /> The PSP's sound goes through your car's antenna. No extra wires are needed nor are any other adjustments. Your games, music and movies will now play through your car's stereo speakers. Please note: take care when trying this and make sure you know how to use the modulator and know the right way to hook up the wire to the fuse box and ground wire. If this is not done right, this can damage or even short out the PSP. This one is for parents!<br /> Changing the Save File images <ul> <li>Whenever you save a game, one or two pictures are created on your memory stick: ICON#.PNG - the 144x80 icon displayed when you select your saved file. The #, normally 0, may be higher if a game places multiple saves in one folder. PIC 1. PNG - the 480x272 background that's displayed when you cursor over your save or game disk. Knowing this, you can customize your save icons and backgrounds by simply replacing them with new . PNG files. However, make sure that you keep the new file less than or equal to the original file's resolution, or the PSP will cut off sections to make it fit.</li></ul><br /> <ul> <li> First Connect your PSP to your PC. Then locate the save file you want to change. All saves are located in the <b>PSPSAVEDATA</b> folder, divided into separate sub folders to keep necessary files together. Once you've found the save icon you want to change, add .ori to the end of the file name, in case you ever want to change it back to the original. Resize the image you want as you're save icon to 144x80 and save it as a .PNG named ICON#.PNG - "<i>where <b>#</b> was the number found on the file you renamed</i>". Then move the new picture into your save folder.</li></ul><br /> <br /> <ul> <li>Now, whenever you see your save files on your PSP, its icon will be the picture you changed it to. Use the same method to change PIC 1.PNG files to your own custom pictures, but remember that the resolutions must be at most 480x272. *Please note this is a bit complicated and could result in losing all saves if not done correctly. <i>This tweak is really for those who have knowledge of using these types of files. Please use caution when attempting this or have someone that knows how to work with these files help you</i>. </li></ul> Choosing a Background Color and Keeping it the Same <ul> <li><b> </b><img src="mike_alozie_1.jpg" />The PSP will change colors of the background screen every month automatically. You can pick a color that you like and have it stay that way. Simply go into the settings and select the month that has that color, when it changes, reselect the month. Note: Your date will always be wrong, but if color and style is your concern, this simple tweak does the trick.</li></ul>
on Apr 23, 2011 | Video Game Consoles & Games
I have a saved game of Pokemon Crystal on Playr.org but when I go to load it, a screen comes up saying "This Game Pak is only designed for use on the Gameboy Color"
Hello, I've had the same problem and been able to go around it somehow. Before I load my save, there is a second or two of in-game screen, then It shows "nintendo" and then "the game pak is only designed for gameboy color". During those seconds, QUICKLY click Save Game and do it multiple times. Some save files will still be with the odd message, while other will run perfectly. I suggest you save your game multiple times and very often, then you can test If then are running correctly, and delete the corrupted ones, or load an old one. Good Luck
Apr 21, 2011 | Nintendo Pokemon Crystal
Xbox 360 save and freeze problems
I'm not entirely sure what could be causing this problem, but I figured you'd appreciate any input.
If your discs are scratched, this can certainly cause some problems, so make sure that's not a factor.
You said you tried playing without a hard drive. How about formatting the hard drive/memory card? That could possibly do the trick.
The disc lens could be dirty, and for that you can find a lens cleaner. If none of those help, it could be that your hardware is simply damaged. If that's the case, then you'll have to ship it out for repairs.
I hope this was of some help :)
Nov 29, 2009 | Microsoft Xbox 360 Console
Replaced battery in memory pack still can:t save games,is ther a trick or instructions I might not know about PLEASE HELP
Memory packs only work with a handful of games which don't have the function to save data on a cartridge, such as Rayman 2 The Great Escape. They're only useful if you own one of those games.
May 06, 2009 | Nintendo Video Game Consoles & Games
How do i save a game on Super NES
Kong Kollege. You talk to the Grandma Kong and she'll let you save your game. Available after the second level on the first map.
Had to go back and play the game, I couldn't remember what it was!!!
Now I have to play it more! Darn you!
-Kaptain Jake :P
Feb 15, 2009 | Nintendo Donkey Kong Country 2: Diddy's...
Professor Layton & The Curious Village - Error
Hi, Sexylegz01 this is only thought, you know when we have to save the game. By over writing a saved file. What about going back to the last file, that you saved before you got to the Ferris Wheel bit. And carrie on from there. Hopefully that might do the trick. Let me know if it worked's Thanks Pitstop. Hope it works.
Jan 06, 2009 | Nintendo Professor Layton & the Curious...
Can't figure out how to save a game on Drawn to Life SpongeBob
erm...when you press start it can ask if you want to quit..click yes and it might automatically save. i dont have the game but another game of mine does that.
Dec 28, 2008 | Nintendo DS Console
E boot.bpb launching problem
I believe it should go into the game150 folder. Otherwise you may have made an error in the backup process. Download unlimited, properly formatted games for psp at www.everything4psp.com they also have game backup software. Support Rich
Aug 10, 2007 | Sony PlayStation Portable (PSP) Console
ValuSoft Lets Ride Silver Buckle Stables for PlayStation 2 Logo
233 people viewed this question
Top ValuSoft Video Game Consoles & Games Experts
James Wishart
Tom Chichester
MegaByteMe
MegaByteMe
Are you a ValuSoft Video Game Console and Game Expert? Answer questions, earn points and help others
