Question about Palm Treo 750 Smartphone
Daylight Savings Time
How do I synchronize my phone w/ the new daylight savings time?
  • 173 Answers
I am not sure if this is available for your version since I do not know who your carrier is. But you need to check on Palm.com and check under software updates and see if there is a patch. usually they have patches which you can uprade your phone with and hat will update yor time
Posted on Mar 10, 2009
I used your instructions to "reset" clock. I did but I have same problem with time. The PROBLEM is how to advance time to adjust to "daylight savings time"? Roy
The phone should automatically adjust to daylight savings time when the phone is powered off then back on again. As the phone reboots, it reconnects to the cell carrier's servers and requests the local time. The server's should have already accounted for daylight savings time, therefore, giving the correct time to your phone.
Mar 13, 2011 | Cell Phones
Samsung Impression :Daylight savings time moved all the appts
This is the second Samsung phone I have had that did this. The A707-Sync had the same problem. I called Samsung tech support and they told me to disable the auto-update feature for daylight savings. Not a great solution, but the only one I got.
Nov 02, 2009 | Cell Phones
My clock went back one hour on Sunday 10/25, need to get it to move ahead one hour.
The clock program for Daylight savings Time is programmed for the old "third Sunday in October" changeover. The new changeover is the first Sunday in November. The program probably cannot be updated. If there is no button or setting to disable automatic change to Daylight Savings Time you can set the time manually and then change it manually to Daylight Savings on November 1 for the time to be correct.
Oct 26, 2009 | Emerson Smartset Clock Radio
Palm Treo synchronize calendar daylight savings time
You need to go to your phone carrier support page, or to Palm.com and download the daylight savings time update.  You SHOULD keep network time checked unless you don't want to pull the proper time from your carrier, such as when you are out of town.
Mar 24, 2009 | Palm Treo 700w Smartphone
Problem with camera, camcorder, time settings
I can help with the "new time zone detected" problem.
To stop thos, you go in setting, near the end (option number 10 on my model) there is "auto update for time", just put it OFF.
Hope it helped.
Nov 14, 2008 | Dual Electronics CECT P168 Cellular Phone
I beleive there might be a firmware upgrade for the processor, but other than that there is nothing you can program to accomplish that.
Oct 27, 2008 | NorStar T7316E Corded Phone
Change the time on the magellan roadmate 1212?
I was in same situation with a magellan roadmate 1212. From what I can tell, the "daylight savings" is not what many of us may be accustomed to... that is, that it means that the location you are at follows daylight savings as happens with Windows or many other devices.
I bet those in Arizona never had a problem becuase they don't follow time zone... let me explain....
The daylight savings seems to state "are we currently under daylight savings time?" if we say yes (as you would normally state in your Windows computer setting (that would determine when daylight starts and stops and adjust pc time accordingly), the magellan 1212 instead will "ADD" one hour to the time stated by the Satellites regardless on whether it is summer ... or not.
So, if you happen to live in a time zone that follows "daylight savings" and you currently are under "daylight savings" time, then set it so in the "time zone".
So, there are two things you have to do:
/menu/user options/system settings/time zone/
1)Set your time zone
2)If currently under Set/unset the daylight savings set button to yes and manually move to no when not on DLS.
The explanation I found in MagellanGPS website is below, but never mentions what is the meaning (I should say effect) of the "daylight savings" button checkmark.
Magellan GPS receivers are not able to set the Time manually. In order to have the correct time set on your Magellan GPS receiver, you must set the proper time zone you are located in (ie Pacific, Central or Eastern). Once the time zone is set the exact hour and minute will display as information is received from the satellites. The following information will assist you on setting the time zone on your Magellan GPS. For Outdoor Triton series 200, 300, 400, 500, 1500 and 2000
  1. From the map screen press Menu and select View
  2. Select profiles and press Enter
  3. Select hiking and press Enter
  4. Press the Page/Go To key once and scroll down to select time zone
  5. Press Enter to select your time zone and Enter again to confirm.
  6. Press ESC repeatedly until you return to the map screen.
Note: Make sure Daylight Savings is adjusted accordingly. For Vehicle Navigation series Maestro and RoadMate 1200-1430
  1. From the map screen select Menu
  2. Select User Options
  3. Select System Settings
  4. Select Time Zone
Aug 29, 2008 | Magellan RoadMate 2200T GPS Receiver
Clock and calander on Win 98 won't keep proper time or date
2 possible solutions
1. Replace the CMOS battery that is on your motherboard.
2. The time zone you have set may not be correct. Please read microsofts article below:
Thanks to the Energy Policy act of 2005, we live in an age where the Federal Government has decided to change even time once again.
Here are the settings for the new daylight savings time that begins in calendar year 2007:
Current (2006 and before) daylight savings:
Daylight savings starts at 2:00 A.M. on 04/02/06 (first Sunday in April)
Daylight savings ends at 2:00 A.M. on 10/29/06 (last Sunday in October)
2007 Daylight savings:
Daylight savings starts at 2:00 A.M. on 03/11/07 (second Sunday in March)
Daylight Savings ends at 2:00 A.M. on 11/04/07 (first Sunday in November)
Microsoft released an update for the change in Daylight Saving Time (DST) that goes into affect next spring in the United States due to the Energy Policy Act of 2005. The update also addresses some changes in other time zones. The update will be included on Microsoft Update, Automatic Update and WSUS starting December 12, 2006 for Windows 2003 and Windows XP. Windows Vista will already include the newer time zone data.
That’s nice for folks running Windows XP, Windows server 2003, or who are about to purchase Vista. What about the rest of us? Microsoft has provided a knowledge base article KB#914387 to cover the subject. I’ve read it and understand it, but I seriously doubt it will be much help for the average user, or a number of IT professionals either, for that matter. Windows 2000 Professional is already in extended support, and Microsoft no longer supports any of their earlier operating systems. If you are running one of these earlier systems (like I am), you probably figure you will have to manually change your computer clock twice a year starting in 2007. That’s not necessarily true.
There is a way that the average user can handle this situation and still have the computer automatically change time for daylight savings. The method involves downloading and installing two very small free programs in your computer. It will work with Windows 95, Windows 98, Windows ME, Windows NT 4.0, Windows 2000, Windows XP, and Windows 2003(server). Here are the steps to follow: 1. Open your browser and go to:
http://www.karenware.com/powertools/powertools.asp
2. Scroll down until you find the program named ‘Zone Manager’, and left click on it.
3. Scroll down to ‘Download’ and download Zone Manager and save it to your hard drive (a folder named ‘downloads’ might be a good place) in a location you can easily remember. If you do not already have Visual Basic Runtime v 6.0 installed on your system (you will need it to run Zone Manager) you can also download and save it to the same location on your hard drive from this same page.
4. Close your browser.
5. Be sure you are logged on as an administrator privilege account if your system requires it to install programs.
6. Open and install Visual Basic Runtime v 6.0 on your system (if you already have VB 6.0 installed on your system, ignore this step). Reboot your computer.
7. Open and install Zone Manager on your system.
8. Reboot your computer.
9. Go to Start | Programs | Karen’s Power Tools, and select Zone Manager by left clicking your mouse.
10. On the lower left of the page, left click the button named ‘Edit Zones’.
11. Under the tab for Windows Built-in Time Zones, find your local time zone and left click on it to display the built in Windows settings.
12. Left click the ‘New Zone’ button to create your new custom time zone, type in what you want for a name, and be sure the box is checked to ‘Enable Daylight Savings Time’. Set ‘begins’ for the second Sunday in March, and set ‘ends’ for the first Sunday in November.
13. Review your settings to be sure they are correct, and then left click the ‘Save Zone’ button, followed by the ‘Save All Changes and Close’ button.
14. You should now be back on the main program page. Here, you left click the ‘Save Shortcut to Zone’ button followed by the ‘Exit’ button.
15. You now have a new desktop icon labeled ‘Activate…..’ that looks like a red box with a white K in the middle of it. When you double left click it with your mouse, your computer will be changed over to the new custom time zone you created.
If you followed the instructions above, you now have installed your new custom time zone that will change your computer time for you in 2007 to accommodate the new Daylight Savings Time settings. You will have spent about 15 or 20 minutes, and you didn’t even need to become a programmer.
If the government ever decides to change things again (They wouldn’t ever do that again now would they?), you just open the Zone Manager program again, create a new custom time zone with the proper settings following the steps above, and delete the old custom time zone.
If you like the Zone Manager program and play around with it a bit, you will find it also has a time synchronization feature that will allow you to synchronize your computer clock with one of the precise atomic clock servers around the world. You left click on the ‘Set Time’ button on the main program page, select the time-server near your current location from the new page that opens, and then left click the ‘Synchronize’ button on the upper right. It should only take about a minute or less even on a dial up connection.
Aug 05, 2008 | Computers & Internet
Emerson Research SmartSet Clock Radio
There is a solution for this already. You can reprogram the clock to use the new DST settings.
See http://www.fixya.com/support/t137304-daylight_saving_time_issues
Mar 10, 2008 | Emerson SmartSet CKS1850 Clock Radio
Palm Treo 750 Smartphone Logo
79 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
