FixYa.com
Tags:
Compaq PC Microphone  Microphone
How fast is PC-PC null modem connection?
By Brad - usenet poster
: hi. thanks. i looked at both the paper and online manual
: pages for interlnk.
: it says that host must be running DOS 6.0 or later, but both of
: my 286 PCs run DOS 5.0.
I run PC-DOS 5 on my machines. I used the INTERxxx programs from MS-DOS
6.22 and it worked correctly.
-- PRR
-- Jim Van Nuland, San Jose (California) Astronomical Association
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
Hart
Hart - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Greetings,
Bull chips. A '286 is more than fast enough to run full-bore 115kb/s
assuming the standard (16 byte?) FIFO. This is still not 20-30kB/s.
A parallel connection is needed to get 512 - 1Mb/s (64 - 128kB/s).
--kyle
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Green1
Green1 - usenet poster
Rating: 0%, 0 votes
Your 286 will be unable to keep up with even the modest 11 Kb/s speed of a
full-bore serial port. You might try a network connection instead.
# __ __ Eric Ewanco
# IC | XC eje @ world.std.com
# NI | KA Framingham, MA; USA
Solution #3
Not Rated (0)
jessie25
jessie25 - usenet poster
Rating: 0%, 0 votes
On 11 May 1998 21:33:16 GMT, Tomoyuki Tanaka put finger to keyboard
and composed:
I use Diskedit (Norton Utilities).
- Franc Zabkar
Solution #4
Not Rated (0)
kcw573
kcw573 - usenet poster
Rating: 0%, 0 votes
You use DEBUG (part of ms-dos) or a sector editor.
MerciYvan Make something idiot-proof, &
Internet: someone will invent a better idiot!
Solution #5
Not Rated (0)
Janice
Janice - usenet poster
Rating: 0%, 0 votes
i messed around with "procomm.dir" a bit and it looks like i'll
be be able to do it.
how do you edit a binary file like that in DOS?
i don't know an easy way to do this even in Unix.
(i'd prob. use sed or tr.)
Solution #6
Not Rated (0)
Lizzy
Lizzy - usenet poster
Rating: 0%, 0 votes
That's because PROCOMM.DIR is really a binary file and if you use any
editor to _add_ characters in the middle of the file, the directory
won't load properly. It's been so long since I used Procomm
(although I still have an original registered DOS version on the 360K
floppy from Datastorm) that I can't tell you whether anyone ever
patched it successfully to handle high-speed modems with 38400 or
higher port rates.
I do know that the original Procomm did _not_ have support for the
16550 UART, which could be another and more important limitation for
you. Look for COMMO, a shareware comm program. It will run on any
DOS-based system you're likely to have, even from a 360K floppy. It
can handle high-speed modems just fine including properly supporting
high-speed ports (16550 UART and above) and rates that are much
higher than 115,200 bps.
Ronald Dailey, San Bernardino, CA, USA,
Inland Computer Users (ICU) BBS: (909)825-4042
Standard Disclaimer: I speak and write for myself, alone.
Can you Help with these Microphones problems?
Compaq PC Microphone (Black or Beige)...
microphone for a compaq...
I need to purchase a microphone... Answer This...
lap microphone problem
I am able to hear people speak... Answer This...
how to turn off laptop...
how to turn off laptop... Answer This...
internal notebook (presario...
my internal mic does not work -... Answer This...
HP says no 'mic in' sound...
I have the presario F756 NR... Answer This...
Repair Service
Find Microphone Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
