Question about Dell Latitude D520 Notebook
My dell latitude d520 was working fine and now when I am on my screen starts running lines from left to right across the screen and then goes blank or black and sometimes comes back on and sometimes it dont
  • Anonymous May 18, 2009
    I have a similar problem, sometimes the screen goes black and didn't return usual, This happens when I installed the intel video driver, eg, a driver downloaded from intel's site, The solution is download the dell video driver, eg, download from dell's site. Since then my d520 never had the same problem again.
    Dell manufacture its own motherboards, then they implement how they like, including some changes ¬¬. That's why the original intel driver has problem with this motherboard.
    I hope that can help you 2 :)
  • christian Abong May 11, 2010
    i hope can help you,
    there's a problem hardware of your laptop optional problem( video, LCD)
  • 201 Answers
If you tap the back of screen and it goes on and off chances are its loose ribbon cable ,
every time you open and close lid , it will tug on it a bit, if the light goes off then inverter problem
Posted on Jul 19, 2009
How to clear lines on dell d520 screen
If they are lines on the screen, test the GPU with an external display before ordering a new screen.
Oct 15, 2015 | Dell Latitude D520 Notebook
Screen not backlit
The inverter is probably going out. They're cheap and easy to replace. EBay usually has them for around 10 bucks. Just search for Dell D520 inverter. It sits behind the screen bezel and just plugs in. There's screws around the screen behind the little bumpers. I believe it's 4 across the top and 2 on the bottom corners. Then just pry the bezel off by pulling between the screen and the bezel. Hope this helps!
Oct 30, 2012 | Dell Latitude D520 Notebook
My dell laptop has horizontal lines across the screen
Last one I had with this it was the connection from the compute base to the monitor. difficult to chk and hard to fix yr self. hv it tested. cheers
Aug 04, 2012 | Dell Latitude D520 Notebook
Dell d520 hibernates, won't wake up
When you get access, go into power options, select hibernate top right, and uncheck the box to the left to disable it, this will free up more disc space and get rid of microsoft worst idea.
Jul 20, 2012 | Dell Latitude D520 Notebook
Dell latitude d520 starts with battery but not with ac adaptor
It could be a bad adapter, a short that drags everything down when plugged in.. could be a short inside the computer doing the same thing.
Borrow an adapter to see if you get the same result, if a friend or shop will help you with that.
A digital VOM could tell you if the right voltage is being put out by the adapter. Read on it, if it's supposed to be DC voltage and you get AC, the adapter is bad.
Oct 02, 2017 | Dell Latitude D520 Notebook
I have a dell latitude d520 and when i turn it on it starts with the dell screen and then a black screen with a little white line top left and then nuffin iv tryed to do wat shibuda says do with the...
Have you tried an external monitor to see if the screen is faulty?
The fact that the DELL screen comes on shows that the bios is running. Try pressing F2 to get into the bios and reset to defaults.
Feb 20, 2011 | Dell Latitude D520 Notebook
D520: 2 lines across the screen. The lines disappear if you flex the lid, suggesting something loose or cracked inside. How do I open the lid?
to open the lid you need to remove the rubber stops to access the screws.
once the screws have been removed you can gently remove the bezel (the plastic suround).
you can now access the screws on the side of the screen to release the screen from the hinges.
you can now bring the screen a little forward the access the video cable.
Once here make sure the video cable is secure.
Honestly !! I dont believe this will solve your problem as most times when lines appear on the screen, it usally indicates the screen is on the way out
Jul 17, 2010 | Dell Latitude D520 Notebook
My Dell D520 is not charging, but instead running on AC power... Right now it has 3% battery left, but it is not charging, instead it is working on AC power, like it does when it has 100% power... Please...
Make sure that you are using the correct AC Adapter. Dell usually supplies two different ones. They look very much the same. The difference is the amps. One is meant to be used in their port replicator. Look in the BIOS and make sure you have the setting correct for charging the unit.
Apr 26, 2010 | Dell Latitude D520 Battery PC Notebook
Dell d520 monitor goes blank while booting up(goes blank when starting windows). Everything boots up(I can hear the audio in the background)except its a black screen. I tried all safemode possibilities but...
just had this experience myself on a smasung monitor. I originally thought of power management but Samsung assure me it is a monitor sync problem and have yaken it away. Theyhave replaced the monitor. So conclusion is that your monitor is also in need of repair
Aug 19, 2009 | CMS PRODUCTS 80GB 7200RPM NB HD SATA-DELL...
How to Get a good Dell Latitude D520 Laptop
it sounds like you did the right thing, i would search google for "Dell D520 keyboard", you should find many places at different prices, if you havent bought from the site before, try reading some customer feedback, and also, the cheapest may not be the best, look for a good return policy and or warranty for the item. if this helps pleas give a fixya rating thanks
Jul 19, 2009 | Dell Inspiron 1420 Notebook
Dell Latitude D520 Notebook Logo
470 people viewed this question
Alun Cox
