Question about Dishwashers
Hello expert, We are having a new kitchen floor laid and the contractor moved the Whirlpool dishwasher out to lay the floor under. Since it was replaced into it's normal under the counter spot, green "clean" light flashing in succession with a brief stop then starts again. Not really bothered as long as it worked, but of course it doesn't work - What do you suggest?? P.S. Had a problem app. 2 years ago when someone backed into the control panel, also ceased working and repairman charged exorbitant to "supposedly" replace computer board
  • 463 Answers
Someone grabbed the control panel and knocked it around or flexed it whist moving it in and out of your counter.
Either the PCB board behind the little buttons flexed and cracked, or the ribbon cable that connects the PCB board to other componets inside there has puled loose...
Posted on Mar 10, 2009
Pump running continuously, Yes there was a drain pack, have emptied water, float switch clicks when moved with screw driver. Only one red light shows ( last cycle - pots ) what else can I do... James
What type of dishwasher do you have? Has your kitchen floor flooded? If it has. The tray under dish washer isn't water tight. Moisture creates some unusual problems. Some of newer dish washer the there control panel under the top of door this also create problem especially if the switches are on the top of the door. Another moisture problem. I have repaired a new Electrolux dish was three times in less than 6 months. The floor would flood from the Maytag side load washing machine. The Madam of the house didn't tell me that the washing machine flooded the kitchen floor. No window in the door and sometime fill water solenoid would stick and fill the tube. When they open washing machine door, 12 gallons of water would spill. So I fix both of them. GB...stewbison
Aug 21, 2011 | Asko Dishwashers
I found a little electric switch laying on the floor after construction on kitchen. dishwasher will start but will not run after about 30 sec
Strip back down and inspect, look for unconnected terminals near anything which moves.What is the model number? That would help diagnosis
thanks for the vote
Feb 03, 2011 | Kenmore Dishwashers
I have an LG Dishwasher model LDF9810ST. Error code E1 keeps showing (Water Leakage Problem) NO water problems anywhere to be found. I have a hard time shutting down the machine. It has had a new MAIN...
Are you draining the unit in the basement or under the kitchen sink?
If you are draining the unit to the floor you will need a new drain hose with a syphon breaker. This drain hose is factory installed on all new LG dishwashers.
The part # is AEM69493801
This is a known issue and may be covered under your factory warranty.
Depending on where you live a factory service tech may be in your area.
Could you explain the second problem further...Hard time shutting down?
Shoot me a E-mail @ omaharox@msn.com.
I am a LG factory service technician not a sub contractor.
Mike
Jan 08, 2010 | LG LDF9810ST Built-in Dishwasher
Whirlpool Gold Quiet Partner Dishwasher - Leaking!
Hello Summers2Go! We are terribly sorry to hear of your concern with your Whirlpool Dishwasher. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, reviewer name (Summers2Go), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 18, 2017 | Whirlpool 24 in. GU2500 XTP Built-in...
Small burner of dual surface(right front) stopped working.
Does yours have the (small large burner switch)? If so, try switching it back and forth. It could be defective or your small burner element is bad.
Mar 11, 2009 | GE Spectra JBP78 Electric Kitchen Range
Puddle on the floor, 36" diag. SW of Dishwasher door after cycle
TO MUCH SOAP RUN A FEW TIMES WITH OUT ANY AND STOP USE THE PACK OF SOAP
Dec 03, 2008 | Whirlpool 24 in. DU1055XTPS Stainless...
Kenmore Dishwasher installation
taking astab at this but your kit floor has been replaced and to close to counter now????, your either shimming up counter or removine the floor from under d/w
Mar 11, 2008 | Whirlpool 24 in. GU1500XT - Multiple Color...
Whirlpool dishwasher.
reach inside your d/w and jiggle the mushroom shaped float switch located on floor of d/w. should move freely up and down if its stuck up(or something lodged under it your unit wont fill with water
Feb 28, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
63 people viewed this question
Top Dishwashers Experts
