Question about Canon NP 6050 Copier
I was having problems with dark spots on the copy of as it was being printed, I was told to replace the glass, and I did, and today I am still having the same problem, it looks as though the copier itself is printing some areas darker than others, and the parts that are printing darker usually comes up in a straight row, noe the whole word, but certain lettering in the word, and then everything in sequence below that, their is also a fluttering noise comming from inside of the copier an the back. in the top or middle panel, sounds like a roller is rubbin up against something.
  • 100 Answers
This is a very mechanical machine that does require a good tech to see it every once in a while. the fluttering is most likely the fixing unit rollers. This machine if not used alot can flatten the fixing roller and cause a noise like you describe. Plus corona wires need changed when this happens to the quality. It not a DIY fix, sorry.
Posted on Mar 10, 2009
Prints and copies coming out with dark spots
Please replace the cartridge /toner with a new one and see what you get.
Jan 31, 2012 | Canon iR1510-1670
My copies are not very dark
Is the problem only with copies? Does the machine also print light?
If is it copy only, remove the glass and clean the lamp and mirrors in the scanner.
If it is both copy and print, then you should clean the laser shield glass and replace the developer.
Jul 28, 2010 | Sharp AR-M455N Copier
Canon mf 6540 copies come out uneven
Did you clean beneath copy glass ( adf copy glass and platen )?Did you clean scaner also?
Clean the laser unit.
Not genuine toner isnt best solution.
Try to print something.If the print is OK, then the problem is in copy glass and scaner.
Jul 02, 2010 | Canon ImageClass MF6540 Copier
Broad dark line on right edge of copied papers
If you have the black line on copies and scans but printing from P.C is fine, then your scanner is broken.
Contact your printer manufacturer for a replacement or repair.
May 12, 2010 | Office Equipment & Supplies
Getting a dark line on the copy pages. Need a new
Mite be a problem with your doc feeder. Are you using a doc feeder? If so raise up the doc feeder and place an orgnial on the big glass instead of feeding the orginal thur the docfeeder. Does the line disappear? If it does then the **** glass the small glass used by the docfeeder has a mark on it or dirt. Is your machine a printer also? Does the print have the mark/line on them also. Do any of your machine's internal reports have line on them Meter Read print outs etc.
Apr 25, 2010 | Kyocera Mita Office Equipment & Supplies
Gestetner DSC 232SP: I purchased this copier used and it had printing ok. My color copies are coming out horrible. they are displaying a white line in the same area on page after page. Even after I ran a...
The white line or lines are NOT caused by the fuser. A defect "line" in the fuser would cause the symtom of the print rubbing off the page but not blank lines on your copy. First we need to separate your copy quality issues. This machine uses 4 drums, 4 developer units and a transfer belt. Most copy quality issues will reside in 1 or more of these units. Lets start with a few questions. 1)Are your copy quality issues ONLY on color copies? or are the black and whites poor too? 2) Are you running copies only thru the document feeder or have you made any copies from the glass?
Are you printing on the copier from your computer?
Dec 04, 2009 | Gestetner DSc232sp Copier
When printing dark line down copy
A line down the copy can come from a dirty document scanner lens.
Usually white out or wet ink will smudge on the document scanner. Opening the document cover check the scanner for a dirty glass. Some document feeders have the white roller on top of the small glass window. They have delicate plastice retainers that hold the roller on both ends. Extra care needs to be taken if this roller is removed.
Clean the roller and the glass with wet towel. Shine a flashlight on the glass to see if there are anymore black marks on it.
Use the finger-nail to run across the glass and make sure no debris is on it. Even a spot can make a line on the copy.
Also, a bad fuser roll can cause a black line on the copy. A defective drum unit can cause a line on the copy as well.
If all else fails place a Xerox service call for this problem.
Oct 22, 2009 | Samsung Office Equipment & Supplies
DARK SPOTS
Are the dark spots random and moves location with every copy or are they at exacly the same place on every copy? Random you will need to remove the drum/toner and use a blower to clean the inside of the machine,failing that replace the drum unit.If the spots don't move clean the top glass.Let me know
May 21, 2009 | Sharp AL-1641CS Laser Digital Copier
Copies are dark
No. It would most likely be the opposite.
The stripes could be caused by contamination of the dev roller, fixing rollers or marks on the drum.
You could also clean the laser ****-glass.
Apr 10, 2009 | Canon IMAGERUNNER 6570 Copier
Dark edges
It depends... never use a Reman cart in these machines... only use sharp...especially if the machine is under warranty.
Does this happen when,
Using the Doc Feeder
When making copies from the Glass
Or when you print from a computer (assuming you print from a PC)
If you print something and this happens then it is inside the machine
Probably toner or developer dumping...
Take a few pieces of large white paper and cover the entire glass surface... make a copy is the line there? If so see the answer above... if not then close the top and make a copy with no paper on the glass... is that black line there.. If so then your top needs adjustment...
One more test
If you make a copy using the doc feeder, this black line only occurs when making copies with the doc feed, clean the **** glass, and try again...
Oct 25, 2008 | Sharp AL 1215 Black and White Copier
Canon NP 6050 Copier Logo
116 people viewed this question
old marine
old marine
