Question about Car Audio & Video
I have a power acoustik LX2-1000 amp. for the life of me i can not get it to work when i hool it up the red protect light comes on and wont go off. i thought maybe it wasnt grounded good enough so i ran a new ground to the chasis of my truck and nothing.
  • Anonymous May 02, 2009
    i have the same amp and the same thing is happening to me i dont know that to do.i tried every thing i even hoked up the ground to my battrery and nohing......i am thing may be i blew out the channeels or some thing.....i guess it is a bad *** amp though..lx2-1000 2 ohm stable
    Problem Solver:
  • 4 Answers
Check the fuses and make sure there are no wires touching. Thats all i know for an amp. If you're positive its hooked up right with good wiring the only other thing i could think of is the amp is fried. sucks..
Posted on Mar 10, 2009
My power acustik 1200 watt amp is on protection mode how do i fix it
Check that no speaker wires or some other wire come off, If they all look okay, There is a internal problem with the amp, It will have to be taken in for repair,
Oct 30, 2012 | Power Acoustik Car Audio & Video
Power acoustik bafm2000/1d no power coming from channel
HelloAny one channel circuit of the amplifier has any sort of trouble, the amp will go to protect mode. It may be a direct short in it he output circuit. This is the common fault for these type of amps. A through check should be done to find out the reason. You must have sound knoledge in electronics, and experience to do this work by yourself. In most cases, unlike TVs, amps circuits are quite complicated and user cannot do it by themselves. OK.
Dec 19, 2011 | Power Acoustik BAMF2000/1D Car Amp
Red light keeps flashing..
my kicker was doing the same thing, and come to find out the power was loose,
1.check power connection,
2. check ground
3. check remote wire.
4. check that your amp isn't mounted on -metal-
5. check your fuses onboard the amp,
6.check you speaker wire
7.check your rca jacks
8. check that your gains aren't too high for the wattage
May 12, 2009 | Power Acoustik PS2-1250 Car Audio...
Protection light just blink on and off
check that your ground wire is connected properly to both your amp and body of vehcile you may need a thicker earth wire
Mar 23, 2009 | Power Acoustik LT-980/2 Car Audio...
The red light is on but there is power to the unit. no visible
If the red light is the protect LED, the amp probably has shorted output transistors. To eliminate other possible causes, read through the following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Nov 25, 2008 | Power Acoustik SL2-2000 Car Audio...
Amp Not working!
If the amp goes into protect mode, it's likely due to shorted output transistors. To eliminate other possible problems, read through the following page:
If the problems are not with the wiring, follow the link at the bottom of the page to the Amplifier Repair Primer page.
Sep 20, 2008 | Power Acoustik TS620-2 Synchronized...
Protection Mode? amp wont start
With your multimeter set to DC volts and the black meter lead on the ground terminal of the amp, touch the red lead alternately to the B+ and remote terminals as the amp shuts down. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is dropping too low.
If the voltage remains near or above 12v, disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Nov 29, 2007 | Power Acoustik LT960 Car Audio Amplifier
Red light
It sounds like the output transistors have failed. Disconnect everything from the amp except for the B+, ground and remote and turn the amp on. If it goes into protect, the amp is in need of repair. If you want to repair it yourself, email power acoustic for the schematic.
Oct 02, 2007 | Power Acoustik LT-980/2 Car Audio...
Protection light on
i had one of these amps, if you don't have a good ground, the protection light will come on.
May 09, 2007 | Power Acoustik TS1440-2 Car Audio...
Car Audio & Video Logo
129 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
