Question about Behringer EUROPOWER EP2500 Amplifier
Have Beringer Europower PMH 1000
Cannot get any sound thru the speakers and the unit makes a clicking sound and the led's flicker continously.
  • 57 Answers
The clicking could be the protection relays kicking in and out.
Check your speaker cables for short circuits.
Also make sure that the load you are applying to it does not go below the minimum impedance which i believe is 4ohms on this unit.
Posted on Mar 28, 2009
All light blinking
Fix the short. It appears the 15 neg supply supplies the LEDs. If you need the service manual try: http://www.eserviceinfo.com/index.php?what=search2&searchstring=behringer+pmh+3000
Jan 27, 2014 | Behringer PMH3000 - EuroPower 2 x 400W...
Beringer pmp4000 no sound out and lights flashing
Sounds like you have blown one or more of the outputs. You need to take it to a repair shop.
Jul 24, 2012 | Behringer Pmp4000 Europower 1600-watt...
Beringer PMH 660M has very low power output to speakers and when the volume in increased the output pops in the speakers and goes completely dead, everything else works ok and the lights stay on
could possibly be the volume switch, try changing the switch with one that you hardly use to eliminate the problem. any further probs just let me know. hope this helps
Feb 16, 2012 | Behringer Music
Need schematics for europower pmp518m
Hello
I've with me the schematics for Behringer Europower PMP-3000 -PMP 1280 & PMH 518. If any one will suit for your set, inform me. OK.
Dec 28, 2011 | Audio Players & Recorders
Behringer europower pmp1000, mixer unit, has all leds lit ,is responding to mic. input, bur is not producing any ourput to speakers, can you advise please.
ALL LED's should NOT be lit all the time. If thsy are, there is a failure in the power supply.
plug headphones into the 1/4 inch main output jacks on the top... you will only hear sound in the left side headphone for each. This would verify the preamp is working.
Jun 25, 2011 | Behringer Europower Pmp1000 Powered Mixer...
None of the channels work. Most of the LED lights work. Im going thru the beringer mixer for power but using another mixer.
If you plug into the PA input or inserts of this unit, that DISCONNECTS all the mixing channels within this unit and none in this unit will work. That is how it is supposed to work.
If you wish to use another mixer as well as the channels in this, I suggest you run the other mixer into one of the stereo channel inputs OR the CD inputs, although the CD are NOT balanced inouts and subject to higher noise level.
Feb 01, 2011 | Behringer Europower Pmp5000 Powered Mixer...
Hello! I have a Behringer EUROPOWER PMH 1000. But the power board burnt source. What do I will acquire another, or fixable?
Often teh power supply fails because of other problems. Unless the board has flame damage the parts that are defective can be replaced... Getting some of the parts that are special can take time. Most of the components are available at many sources however. The SPS400 power supply can be repaired.
Here is link to schematic that should have the SPS400 as well as the rest of the PMH1000 on it.
http://elektrotanya.com/behringer_pmh1000.pdf/download.html
Jan 18, 2011 | Behringer XENYX 2442FX Mixer
Behringer EP2500 amplifier channel crackling noise
Got asilimar problemwit a behringer europower pmh 3000.
my
The Right channel began to crack up and drizzle now it seems completely dead.
Changed the cables both of input and seapkers , still the problem stays the same. Any suggestion before brigning for a month at the repair shop? And get out with a 200-400$ bill ?
Apr 28, 2009 | Behringer EUROPOWER EP2500 Amplifier
Europower Beringer PMH3000 power turns on then turn off?
when you turn on the AMP and the red light comes on give the amp 2 seconds and turn it back on the red light should turn off. That is what I do with the amps at my church and it works for me, I hope that this works for you too.
Mar 25, 2009 | Behringer EUROPOWER EP2500 Amplifier
Behringer EUROPOWER EP2500 Amplifier Logo
603 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
