Question about Reddy Heater-30-55,000 BTU Variable
Can not start propane heater.
Stopped working and will not restart. Will fire when the ing button is depressed, but when released quits. New tank, spark fires. Suggestions?
  • 181 Answers
The thermo couple is bad.install new on and all will be well.give me the model number and i'll try to get you a part number
Posted on Mar 17, 2009
Honda 3000 will not restart
hello this is a common thing what you do is drain all the gas out of tank and carberator take off the cup and drain it to becarfull because the jet may fall out take a dry rag and stick it in the tank and have a flat face screw driver are something to clean the tank put fresh gas in it and it should fire right up if not take out the spark plug but leave it hook and pull the string to see if you getting fire if not it is your coil that is bad if you see rust on the coil where the fly wheel is take a sand papper and sand it real good now when you put it back on set your screws and then take a dollar bill put it between the flywheel and the coil thats the space you need so it would send fire tighten your screws and that should do it if not buy you a new coil if it is giving fire some time you still have to chang your spark plug i hope i helped you have a bless day
Dec 19, 2012 | Honda Pressure Washer PSI 3000
Car won't fire
check your fuses as a start then check relays and then fuel pressure because the filter could have only 1000 miles on it and have problems with it and it could also be the coil pack died on it .
Jul 02, 2012 | Hyundai Sonata Cars & Trucks
Bike has a spark and cleaned out carb will not start, put fuel in plughole would not fire, it just stopped when going on road, charged battery, so it turns over well, checked valve in petrol tank vaccum...
if you have good blue spark and it fires when fuel is added externally , then the problem is fuel flow through the carby
have the carby professionally overhauled or get a new carby
make sure that the gasket to the manifold / head is in good condition
May 06, 2017 | Honda Runner Pure Jet Motorcycles
Petrol strimmer,, spark at plug,, petrol & 2
I have a flymo 430 petrol strimmer and cannot start it. ive cleaned the filter, put in new plug it went first time and then stopped and wont start again the plug seems to get wet all the time any ideas
Jul 03, 2011 | McCulloch Heavy Machinery
I have a Fire Sense Patio heater, it worked for awhile and no it will not light. You hold done the button it ignites and as soon as you let go of the button it goes out.. It is not the propane tank, we...
sounds like the regulator is vapor locked. turn everything off, tank, any switches on unit itself, any valves.everything. now disconnect the gas tank. let sit in the sun for a bit, so we cant get you going quicker. start at to tank, reconnect that. now follow the manufactures specs for operation.
Mar 15, 2011 | Fire Sense 02411 Standard Patio Heater...
I have a spc-40 heater i can not get it to stay fired up i press the fuel button and it does lite but after 15 to 20 i release button and it goes out what do i need to do to make it work again
Ensure all your connections are tight and not leaking. I would shot off the tank using the valve on the top. Disconnect it, then re-connect it. Once connected, ensure the fan on the unit starts to turn. Then you can slowly open the valve, give it a good 4-5 turns to ensure it is open. They try the ignition sequence again.
Feb 28, 2011 | All-Pro Propane Garage Shop Heaters - All...
Have a Reddy Heater RCP275 propane gas heater. If able to light - the heater will burn for 1-5 min. but then goes out. Sometimes burner will not light at all when the red pilot button is released. At times...
Sounds like the igniter needs to be replaced. It is normal for a heater to run five or so minutes that means the thermostat is working. then restart when the temp calls for heat but if the igniter does not work it will not light up again.
Jul 27, 2017 | Heating & Cooling
Reddy Heater-30-55,000 BTU Variable Logo
153 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
