Question about Plantronics - Bluetooth Headset Plus Base & Headset
220 Plantronics Head Set. How do I start the paring mode?
I hold down the on switch/button but it just turns off.
  • 3 Answers
Firstly make sure your blutooth is visible on your mobile phone. Now hold the on button and keep it held until your phone finds the paired device then press ok on your phone when it finds your handsfree device following your code.
Posted on Mar 10, 2009
Trying to connect Plantronic 220 headset to Pantech phone. Can't find the right option on the phone to engage the bluetooth device. I think the headset needs to be flashing red/blue to pick up device and...
1.First switch on the bluetooth in mobile phone.Keep the headset switched off.
2.Now press the call button for 2 seconds if you are paring this headset for first time,If this head set is aired already with another mobile press for 8 seconds until the headset status indicator begins to flash blue then red
3.Now search the bluetooth by your mobile device.It detects and you can pair it
Thank You
Nov 10, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Can you say if Plantronics 220 is compatible to work with blackberry 9630?
Hold down round button on earbud for 5-6 seconds until it flashes alternating red and blue. Then set your device (Phone/PDa) up for connectivity by allowing it to be discovered...Once your phone is in discovery mode, it will search and hpefully find the earbud.
Jun 20, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Trying to pair my HTC EVO to plantronics explorer 233 Bluetooth headset
Had the same problem and called Plantronics. They reminded me about putting the earpiece in "Discovery Mode" by holding down the button when turning it on until it flashes blue/red. Then have the EVO scan for bluetooth devices. It found mine right away.
Jul 01, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Head set not pairing with sony erricson k750i
The solution for paring the explorer 240 is found in the bottom of the product page for the embedded link on the User Guide Link. I have also provided the instructions below. I hope this helps
How to Pair Your Phone With Your Headset for the First Time
1 Turn on the Bluetooth feature on your phone.
For most phones, select Settings/Tools > Connections >
Bluetooth > On. See your phone’s user guide for more information.
2 Turn the headset on.
Turn on your headset by sliding the Power Switch toward the microphone. Wait until the indicator light flashes red then blue.
If you don’t see the red then blue flashes, turn the headset off, then turn it on again. Press and hold the Call Control button until you see the red then blue flashes that indicate pairing mode status.
3 Set your Bluetooth phone to ‘discover’ to locate the headset.
This usually involves going to ‘setup’, ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add a device’.
4 Once available headsets are listed, select your headset (for example 2XXPlantronics or 3XXPlantronics). If prompted for a passkey, enter 0000.
When pairing is successful, the indicator on your headset flashes blue. Your phone will also confirm when pairing is complete.
John M
May 06, 2010 | Plantronics Explorer 220 Bluetooth Headset...
How do I put a Plantronics Explorer 232 in paring mode so I can connect it o a cell phone
Hold it in for three seconds or more to flash purple and enter discovery mode.
Once it's paired it will flash blue.
Default code is 0000.
Feb 22, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Plantronics 222 problem please help!
Make sure it is fully charged then hold the button down and don't let go till it flashes blue/red. You will see it turn blue first but still hold down the button till like I said it flashes blue/red.
Aug 22, 2009 | Plantronics Explorer 220 Bluetooth Headset...
I cant pair my explorer 230 to my new phone?
The head set is still set to the old phone, hold down the call control button until it starts flashing red/blue. then it will be ready for your new phone to find it. (remember if you didnt change it the password will be "0000"
Apr 10, 2009 | Plantronics Explorer 220 Bluetooth Headset...
How do I pair plantronics explorer 233 to a new phone after its been paired to another phone
to pair your bluetooth first, turn the bluetooth feature on your phone to on.
Next, hold the call button on your bluetooth until the light begins flashing blue and red, this means it it in paring mode.
Third, find the 2XXplantronics device in your bluetooth options. Select this divice and enter the passcode (0000).
You are now finished and the bluetooth is paired.
Mar 05, 2009 | Plantronics Explorer 220 Bluetooth Headset...
How to turn my plantronic explorer 220 on discover mode
  • TO SET IT ON DISCOVERY MODE YOU HAVE TO START WITH IT OFF. YOU CAN TURN IT OFF BY HOLDING DOWN THE CALL CONTROL BUTTON- THAT'S THE BIG ONE ON THE FACE OF YOUR BLUETOOTH, UNTIL THE BLUE LIGHT TURNS RED. RELEASE THE BUTTON AS SOON AS YOU SEE IT TURN RED. iT SHOULD BE OFF, YOU CAN WAIT A SECOND OR TWO TO SEE IF IT FLASHES BLUE AGAIN, IF IT DOES JUST HOLD DOWN THE CALL BUTTON AGAIN TIL RED THEN QUIT. ok IT'S OFF, SO WITH IT OFF YOU PRESS AND HOLD DOWN THE CALL CONTROL BUTTON 5 SECONDS IF IT IS THE FIRST TIME PAIRING. iF IT IS NOT THE FIRST TIME YOU HAVE TO HOLD IT DOWN FOR EIGHT SECONDS AND IN BOTH CASES THE LIGHTS SHOULD FLASH RED THEN BLUE( OR VISE VERSA.) BACK AND FORTH. aT THAT TIME IT IS IN DISCOVERY MODE AND YOU HAVE LIKE 60 SECONDS TO SET YOUR PHONE ON DISCOVERY AND MATCH THEM UP. i JUST WENT THRU THIS ABOUT 20 MINUTES AGO, i FOUND THAT EXPLINATION ON pLANTRONICS WEBSITE FOR MY MODEL, 220.
Jan 04, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Pairing LG Shne cu720 to Plantronics Explorer 220
Try holding down the button on head set untill the phone reconizes
Jan 01, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Plantronics - Bluetooth Headset Plus Base & Headset Logo
343 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
