Question about GE (PSS26MSRSS) Side by Side Refrigerator
It stop working and everything in it defrost the repair man said it's the mother board now the warranty is out and i'm stuck with a non working fridge.I am renting one from rent to own because i can't afford to go pay 1300.00 for another one.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
Did he check the heater and the defrostthermostart if did is the board
Posted on Apr 06, 2009
Tip
GE refrigerator non defrost issue with Mother Board
This procedure will define the issue with a non defrost issue in all GE refrigerators controlled by a Mother Board.
Description of Non Defrost.
Are you noticing a drop in temperature in the refrigerator and or a frosting of the lower rear back panel of the freezer. This would indicate a non defrost issue. There are four reasons for this to ocurr.The four reasons will be adressed in the instrutional video I have posted below.
The tech has set up in the back ground a G.E. freezer section to demonstrate an actual scenairo.
Click on the link http://www.youtube.com/watch?v=BrSQz-5F1hs
You will need the print to the Mother Board.....The Mother board controls all aspects of the unit. Because you have a defrost issue do not think that it is because of the mother board. Most of the time it is just the defrost heater that is bad. If the defrost heater is bad remember to always change out the defrost thermostat also. Note the print....you can check all aspects of the unit from here....
click on the link http://fixitnow.com/wp/2006/06/29/ge-arctica-refrigerator-troubleshooting-tech-sheet/
Please consider giving this procedure a four thumbs up on our rating!
Using FixYa and this procedure has saved you a minimum of $225.00!
Thank you for using fixya!
Keith
on Mar 19, 2011 | Refrigerators
Hi there I have a jenn air fridge jc2228pehb I have had expense and problems and the repair man told me that I need a new motherboard that tells the fridge to defrost. The freezer is getting frosty in...
That would be the first $500.00 defrost control board I have ever heard of in my life! Look if you want to do this yourself I will give you step by step directions. Click Here=> JC2228PEHB Control Panel
Once there see parts labeled 8 and 12? Number 12 is your=> Adaptive Defrost Control
No one has a photo for this part=> 67002163 Adaptive Defrost Control Board and here is your auto damper=> 12571701 Auto Damper
Click Here for Repair Clinic's version of that board, again no photo=> 67002163
I like their 1 year return warranty. I have the service manual and will instruct you on how and what to do so you let me know and I will go through this with you. Oh almost forgot to mention your model has no mother board! Thanks, Sea Breeze
Mar 14, 2011 | Refrigerators
I have a GE side-by-side refrigerator/freezer that's not maintaining cold temperatures. I was told to replace the defrost thermostat which I did and it seemed to work for about a week or so. But now it's...
If the refrigerator isn’t cooling at all the motherboard is a good possibility burnt marks or not. If the fans are not running it could be a defective fan, motherboard or both. Take a look at this page http://www.appliance-repair-it.com/refrigerator-fan-motor.html
If the refrigerator isn’t defrosting properly, after a few days the freezer coils will get blocked out with heavy frost. There are four things that will cause this, defrost thermostat, defrost heater, evaporator thermistor and the motherboard. This page should help http://appliance-repair-it.com/GE-refrigerator-repair.html
Jul 17, 2010 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
I want to know my mother board is in warranty or
ASUS Motherboard ( Purchased after Nov 1,99 ) do have 3 years Warranty.To Confirm whether your Product is under Warranty or not, you need to check directly with the Seller.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 19, 2009 | ASUS P5PE-VM Motherboard
Stops cooling ice melts and leaks water on the floor
That model refrigerator uses the mother control board for deciding when defrost is to take place. It has no defrost timer or Adaptive Defrost Control like other refrigerators. This sounds like *********** board part number WR55X10942 is malfunctioning. The board decides most functions of your refrigerator. Until the board is replace I do not believe the problem will resolve itself. Thanks, Sea Breeze
Sep 26, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
Fridge never stops
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 11, 2009 | Kenmore 53082 / 53084 Side by Side...
Defroster cycle stuck
Unfortunately GE has been having a problem with the main mother boards on your model refer, the mother board controls the defrost cycle and there is not reset for it, you may have a bad board.
Mar 17, 2009 | GE GSS20IEM Side by Side Refrigerator
Norcold RV Refrigerator
It sounds like the relay could be stuck closed on the electric side of the board. This would not allow the element to stop working. Sometimes resetting the board will fix this problem if it is still under warranty they will cover both the board or the resetting.
Aug 07, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
102 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
