Question about Konaki DV6 PLUS Digital Camera
Konaki DV6 Plus Battery Pack?
Where can I find a replacement battery pack for a Konaki DV6 Plus?
  • starrcruise Mar 15, 2009
    I also need the charger.  Mine basically had to be taken apart to work.  The battery does not seem to be holding a charge for very long.  Thanks.
2 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: Camera won't charge
The camera manual will tell the battery type. If you do not have the manual then the makers web site customer support is the place to go. The same applies to the charger - if it does not supply enough current then the battery will never be fully charges.
Posted on Jul 24, 2007
geek63640
  • 15 Answers
SOURCE: Driver/software
I'd contact the support team @ Konaki and request the drivers, because most of the links on their web site do not work at all: support@konaki.com
Posted on May 19, 2008
How to unlock the memory card
I think you have an SD card, there is a little tab on the side that locks it on or off, see pic, you just need to move this up or down to be in the correct position
Sep 25, 2012 | Konaki DV6 PLUS Digital Camera
Tip
Sony NP-BG1 battery|Cheap NP-BG1 digital camera batteries
New,1100mAh, 3.60V, Li-ion, Sony Battery Pack
  • Chemistry : Li-ion
  • Voltage : 3.60V
  • Capacity : 1100mAh
  • Dimension : 41.90 x 35.40 x 8.10 mm
  • Color : Black
  • Brand : Sony Digital Camcera Battery
Replacement SONY NP-BG1 Digital Camera Batteries, Li-ion SONY NP-BG1 Battery Pack
on Jul 20, 2010 | Cameras
I have a protax dv6 camcorder, it takes a li-ion qlr0509 bat. i need a bat and charger?. Can you help. Thank you
I ordered a new battery from Deals Only Web Store. I believe they also carry chargers for 12.00
Jun 09, 2010 | Konaki DV6 PLUS Digital Camera
I have a Canon SD1000 battery pack issue.
I have a Canondigital ixusi which had the same problem and I purchased three new batteries, but found that all of them showed the "replace battery pack" message when fully charged. I have solved this problem by cleaning all the terminals on the batteries and in the camera very thoroughly with alcohol and Q-tips. Even though the terminals look completely clean, there must be a slight film which is preventing good contact. The contacts in the camera are spring loaded and I suspect they are not making a very good conection to the battery so any contamination is making a high resistance to the flow of electricity. Hope this helps - it worked for me.
Aug 10, 2009 | Canon PowerShot SD1000 Digital Camera
Sir my sonyDSC-40 Camera dot't power on. In power butten pressing time only one time bliking green LED.
Turn off the camera, remove the battery pack. Allow the camera to remain without power for 30 seconds. Reinsert the the battery pack. Turn on the camera.
Please make sure the Battery is fully charged before performing this steps.
Also try changing the Batteries of the Camera. "AA" NiMH, "AA" Alkaline, "AA"
Nickel-Metal Manganese are the compatible Battries for the Camera. Hope it works!
Dec 01, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Set up settings won't stick after camera is turned off
yes on the ex-z75 Casio camera there is a internal battery right under the front cover by the speaker wires this battery is a 3.6 volt battery that is soldered on the board. the only what is to make a make shift battery pack and solder it on to the prongs. I do this with out any guarantee that because it is not factory default and they do not sell the battery to any one. most of the time they will tell you the main board has to be replaced. if the main board has to be replaced it is 85.00 plus shipping from my shop but if soldering a 3.6 battery pack works then it would be 40.00 to replace the battery.
May 29, 2008 | Casio Exilim EXZ75 Digital Camera
Driver/software
heres the link to their main website , go to DOWNLOAD on top of website , and follow it from there , good luck , AJ
http://www.konaki.com/product.html
May 19, 2008 | Konaki DV6 PLUS Digital Camera
Battery replacement
Apart from taking it to a shop for a battery re-build, if you are savvy enough, you can re-build the battery by taking the old battery pack and the protection circuit board out with a soldering iron, keeping the plastic frame and replace the pack with a similar one that you can buy on ebay for less than US$10. Just search "Lithium Polymer 380mAh" and that is the one that gave mine a second life. WARNING: Do it at your own risk, don't hold me liable if you lose a finger or more from mishandling the potentially explosive Li-ion battery pack. Good luck!
Feb 08, 2008 | CHE-EZ v:u Digital Camera
Camera won't charge
It could be the batteries but my bet is the charger is bad. If you have access to another charger try using it instead. I just had a similar problem a month ago where my charger pretended to work but never really put much of a charge on the batteries.
Jul 24, 2007 | Konaki DV6 PLUS Digital Camera
Konaki DV6 PLUS Digital Camera Logo
82 people viewed this question
Top Konaki Cameras Experts
Are you a Konaki Camera Expert? Answer questions, earn points and help others
