Question about Dell Dimension 8300 PC Desktop
Dell 8300 screen can barely be read
Recently when I power on my Computer the screen can barely be read. I have changed monitors with the sane result. I am thinking that I need to replace my cmos battery. Any ideas?
  • donnoll Mar 10, 2009
    ok will do
  • 135 Answers
- Check the Video card of the computer.
You'll needing to open the cover of the CPU.
Try to remove the video card on the mother board of the computer, check the video card if hot or clean the card, maybe there are dirt and dust to it. then reinsert the video card to the computer then check the monitor if you got the same problem.
Note: Make sure that your computer is off while doing the steps.
Posted on Mar 10, 2009
  • 170 Answers
I would suggest another video card, the CMOS battery would not have anything to do with the screen.
  • David Fitch
    David Fitch Mar 10, 2009
    I f this helps please rate it accordingly,
    Thanks David
Screen images are too tall and thin.
Try to Get the New updated driver from Nvida web
Nov 30, 2009 | Dell E173FP 17" LCD Monitor
Problem with Dell 2100FP LCD monitor
Unplug monitor form AC outlet, wait for few minutes and plug again.
Check cable attache to PC.
Hope this trick will work.
Sep 30, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
My dell desktop screen says AutoAdjust and then
install graphic drivers from following link
then cherck ,.
If you still face problem then when you power up the computer pressF8 key then enter in enable vga mode. then change screen resolution to 1024*768
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_8300&os=WW1&osl=en&catid=&impid=
Jun 25, 2009 | Dell Dimension 8300 PC Desktop
After i tried a better graphics card no screen to look at to
See if the serial cable is properly plug in both side Monitor and computer
Jun 24, 2009 | Dell Dimension 8300 PC Desktop
Dell E173FPc monitor. Screen is black, power button color cycles
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any
surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective.
What are the results please?
Feb 24, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell 1702FP 17" shows nothing after Radeon HD 2600 put in.
Is the card plugged into the (PCI/AGP) slot correctly? Did you disable the onboard video in the bios? Also be sure to check in windows device manager and check for the graphics card to appear there.
Dec 24, 2008 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Computer monitor screen is blue
Can you access the bios set up.
If the bios setup is running evrything is ok except the hard disk.
To find out if there is any problem with monitor just put off the monitor and disconnect it from the cpu. Then turn it back on. If the no signal message is coming, then monitor is ok.
Your hard disk is the main suspect
If the same blue screen comes then monitor need repairs.
You may also try with another monitor on your computer to see the results. If the sane happens it is the hard disk
Dec 18, 2008 | Acer 22" X223w LCD Monitor
No display.
http://support.dell.com/support/edocs/monitors/2005FPW/En/setup.htm#Using%20the%20OSD
Make sure the proper input is selected
1: D-SUB for Blue VGA cable
2: DVI-D for White DVI cable
The option selected should be indicated on the power save screen.
If changing the input select and rebooting the computer have no effect an no video from the computer is ever displayed, then the monitor is in need of repair.
Jun 30, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Vertical lines on LCD monitor
You have capacitor problem in power supply, if many lines then replace the bigest cap and find anymore that needs replacing. Its an AC filter problem.
Sep 14, 2007 | Dell E173FP 17" Flat Panel LCD Monitor
Dell 2001FP always in sleep mode.
I have a dell ultrasharp and at first it would not come on at all. Open it up and found loose connection on plug connectors 3 pin. Soldered and would come up but blinks in and out sometimes take longer than other times. Big Capacitor when open up Power supply was leaky. Check for bad caps
Sep 08, 2007 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell Dimension 8300 PC Desktop Logo
66 people viewed this question
Alun Cox
