Question about Dell Latitude 100L Notebook
How to boot from cd if i cant change the boot sequence.
Hi does any body know how to boot from cd wthout changing the bios. I need ti install a password recovery programme as i have lost the password but cant as they all need access to the bios to change the sequence.
  • pinkkelly26 Mar 10, 2009
    already tried that and it does not work as i dont get the cd boot option.
  • pinkkelly26 Mar 11, 2009
    how do format with out the hardd drive in when i take it out it wont do anything just loads and tells me there is no hhd,
    Problem Solver:
  • 13 Answers
ONE MORE TIME!
GO HERE:
http://web.archive.org/web/20041106044148/qasimtoep.tripod.com/dell/dell.html
Don't be scared of the little ol' 24C02 non-volatile RAM chip that is used to store the passwordsand tags - there's one on EVERY stick of RAM!! (yup - that little ***** 8 pin job)...
PAY ATTENTION HERE: THE INFO AT THE ABOVE MENTIONED SITE IS INCORRECT! THEY ARE SHOWING A PICTURE OF THE CHIP, AND TELLING YOU TO SHORT PIN 3 TO PIN 6.
WHAT YOU WANT TO DO IS TO SHORT PIN 6 (SCL - clear) TO PIN 4 (VSS - ground), AND THEN APPLY POWER FOR 1 SECOND OR LESS. THIS WILL CLEAR THE CHIP, AND YOU'RE GOOD TO GO! - DONE IT MANY TIMES!
FYI: This process does NOT damage the chip in any way! Follow the instructions on obtaining the DELL "DST" CD, and with it, you can re-load the chip with whatever you like!
GOOD LUCK!
Posted on Jul 08, 2009
    Problem Solver:
  • 17 Answers
Click F8 when ur computer starts....then 3-4 options occure like BOOT FROM IDE DEVICE, BOOT FROM APTMA CD-Rom etc... select ur cd rom device to boot from cd...
Posted on Mar 10, 2009
  • 463 Answers
As soon as you see the BIOS splash screen press <F12> a couple of times and pray.
Pick boot device from list that appears on screen.
(hopefully)
  • 2 more comments
  • Rob
    Rob Mar 10, 2009
    The problem is most all Dells use one of two keys at bios boot time:
    F2 gets you into the CMOS Setup
    and
    F12 gets you into the "Boot Device Chooser" menu.
    Some dell laptops DO NOT have the F12 capability. Sounds like you may have one of those laptops and/or that capability has been disabled.
    If you can get to Safe mode, try no password at all for the administrator password and pray like hades.
    Regarding manually "fixing" the BIOS password problem you are having: (from elsewhwere on the web -- many, many responses just like this one)
    _______________
    If you can prove ownership then Dell will happily help.
    Otherwise you have to corrupt that eprom (or replace it)
    There is no other option that I know of.
    Follow-up question from Anonymous on April 18th, 2005- 02:34 GMT
    thank you for the information
    do you know where I could find fairly detailed instructions on finding and corrupting the eprom
    and if u could explain corrupting the eprom?
    Answer from kumquat on April 18th, 2005- 02:42 GMT
    Do a search on this site for "d600 eeprom" then read all that you find. Also look at all the threads I've also commented on already.
    That should explain most of the theory.
    The website which had pictures etc. has been taken down.
    I don't know where the chip is on your laptop, so you'll need to find it on your own.
  • Rob
    Rob Mar 10, 2009
    and
    _______________
  • Rob
    Rob Mar 10, 2009
    Here's another thought... If you're only concern is using the laptop itself, and you don't care about the data on it, pull the HDD out, format /s with FAT32. Then copy the i386 directory over to the disc you just formatted. Put disk back in laptop. Boot...
    you'll get C:\ at boot time.
    Run C:\i386\WINNT.EXE
    Have your serial no for the product you plan on installing at the ready.
  • Rob
    Rob Mar 11, 2009
    You will USE another machine / external HDD enclosure / whatever to format the drive and copy the files. You may have to get a bit creative...
Cant start acer 5920
Hi Dear,
Check the mention below instruction to solve you problem.
1. Is the boot sequence in BIOS set to boot from CD or DVD, if not I would suggest you to go to BIOS and change the boot sequence to boot from CD and try to boot from the CD
2. Is the computer custom built or OEM built?
3. What is the model number and who is the manufacturer of the computer?
4. Have you made any changes to the computer by installing any new software or hardware?
5. Since when are you unable to boot the computer normally?
6. You need to get Windows Vista DVD to perform further troubleshooting either to scan the computer or to perform repair install, I would suggest you to contact the computer manufacturer to obtain vista DVD.
Thanks
Sep 07, 2012 | Acer Aspire 5920-6423 Notebook
I have acer aspire 3000+ and cant change bios setup to boot first from cd rom and erecovery doesnt work
Why can't you change the bios setup to change the boot order or boot sequence?
Also you can change the boot order or boot sequence temporarily by just rebooting the laptop then watch the screen for which key it says to hit to change the boot sequence or boot order, then hit that key when you see the message.
May 08, 2012 | Computers & Internet
I tried to install windows 7 on my HP Pavillion DV9, but it's not booting from CD-ROM, i tried using a USB CD-ROM, but it's still not booting. pls I need assistance.
Try to check if the windows 7 disc that you are using is not just an upgrade disc. Make sure that it is a bootable disc. Try to use other bootable disc to test. Also make sure that the boot device priority is set CD/DVD drive.
Hope this helps.
Jun 06, 2011 | Computers & Internet
How to enter in bios to boot change sequence in ProLiant ML 530
Press F10 during post boot if you have smartstart installed in the partition. If not, you need to boot from SmartStart CD.
May 08, 2010 | HP Compaq ProLiant ML530 Server
I have LG E500 and I want to instal XP. I cant make changes in bios like boot sequence, so I cant boot from cd and therefor I cant instal XP. What should I do?
I don't recommend downgrading your laptop from Vista to XP but...
According to manual, pressing F2 during boot sequence takes you to BIOS and then you can change
the order of the boot sequence in the BIOS. From the manual:
"...set passwords, change the booting order, and add new peripheral devices to the machine."
If you can't find boot sequence in BIOS setup, talk to a support rep online:
http://ca.lgservice.com/index_b2c.jsp
You may need to use a different server if not in CA.
Jul 08, 2009 | LG Computers & Internet
Boot sequence. I want to boot CD first
No,you don't need to disable quick boot,All you need to change is the boot order.But to boot from CD all you need to do is press F12 while the system is booting up.
Mar 17, 2009 | MSI 865PE Neo2-S Motherboard
In win set up
Hi!
You need to change the boot "boot from cd" to Boot from HDD"
You do that in the bios
So start the installation again, and when your pc starts to boot, get in to the bios and change the boot sequence to HDD
Good luck
Nic
Mar 04, 2009 | ASUS P4XP-X Motherboard
NO BOOT OPTIONS FROM CD
simple if you need to format your system then insert the windows xp cd in a normal mode and go to installation and it will ask for the an upgrade or fresh installation select fresh installation no need to enter bios this reboots your system via cd and let youformat your machine.
Feb 17, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
How install new bios
After updated your bios, did you check the boot sequence?
it might have been changed. Go in to the bios again and check so the boot setting is pointed that your pc starts from your HDD.
If you trying to reinstall the OS you should change tye boot to start from you cd-drive.
Good luck to you
If you find my answer helpfull, dont forget to vote
Dec 12, 2008 | Intel Motherboard
Disk boot failure prompt
hi, SInce u do not have a HDD u will need to boot up from cdrom, for that in the BIOS 2nd options,change the boot up sequence first to cdrom , second to any other disk.. let me know
Dec 17, 2007 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Dell Latitude 100L Notebook Logo
461 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
