Question about Samsung SyncMaster 913V 19" Flat Panel LCD Monitor
Samsung SyncMaster 913v picture rotated 90 degrees
I bumped the keyboard between the qwert keyborad and numeric pad and the image rrotated 90 degrees. how do i return ig to normal
  • Robert Miller II May 11, 2010
    Have you tried pressing the following key combinations: ctrl+down, ctrl+alt+down, ctrl+up, ctrl+alt+up?
  • 14 Answers
Please press Ctrl-Alt and your arrow keys until the image is straight!
Posted on Apr 06, 2009
Windows Vista w/Samsung 19" monitor
Used to be CTRL and ALT and one of the directional arrows in xP (the numeric pad ones)
If you have a video card like Nvidia, and say Vista is the OS, try going to Control panel / Nvidia Control panel (or whatever your GFX card is) and the option to rotate is in there)
Jan 27, 2011 | Computers & Internet
Samsung syncmaster 913v gives message ' not optimum mode"
The 913V has a native resolution of 1280x1024. If you use a higher resolution than that, you'll get slightly blurry text. If you use a lower resolution, then images will be slightly choppy around the edges.
To get rid of the message, set your resolution to 1280x1024.
In Windows XP, you do this by right-clicking on the background (desktop) and selecting "Properties" to bring up the display properties.
Select the tab marked "Settings" and look for a "Screen Resolution" slider. Move that slider to the right until it displays "1280x1024" and hit "OK"
Oct 03, 2010 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung lcd 913v self test ok, no image when vga connected
This problem often occurs in samsung SyncMaster LCD monitors.
The solution is open your look for the LCD monitor power supply module (which have PCB connector to the AC power), on that board look for capacitors, now look for broken one which upper part is bloated, like the image below:
If you find a damaged capacitor as in the picture then you should replace it with the same value.
Jan 22, 2010 | Samsung SyncMaster 913V 19" LCD Monitor
Samsung SyncMaster 913V it's displaying red lines
Sometimes this happens when the pins on the vga connector are bent. You can either try to straighten them (very carefully with tweezers) - be sure to check both ends, or try a new cable.
Apr 06, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Syncmaster 913v color problem
Appears to be something in the connection. Check the video cable and pins on the video connector. Also verify the color settings have not been changed on the monitor. There should be an area where you change the RGB levels.
Feb 14, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
The display on my samsung monitor is sideways
press the select botton on your monitor. find the MORE and adjust the rotation and parrallelogram...
Jan 06, 2009 | Samsung SyncMaster 175V 17" LCD Monitor
Syncmaster 913v
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very easy and simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Oct 26, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung Monitor image rotates 90 degrees
Use ctrl+alt+ up Arrow key (you can also use use ctrl+alt+ left/right Arrow key)
Good Luck
Mar 27, 2008 | Samsung SyncMaster 240 T 24.1" Flat Panel...
Samsung SyncMaster 913V 19" Flat Panel LCD Monitor Logo
199 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
