Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
I set the cycle and push start and the breaker kicks off
The dishwasher is plug in with my garbage disposal so I unpluged it and retried the dishwasher and still had the same problem.
  • 81 Answers
It could actually be the breaker itself. If not, there is a "short" in the machine. The likely place for the short is the water inlet solenoid valve which is replaceable. If not there, then you need to call the repairman.
Posted on Apr 24, 2009
Dishwasher LD-1420T1 tripping power in the house?
Okay, this could be tricky because depending on who installed it, they might have wired into it. Check your garbage disposal and if you have anything else plugged in nearby, check that wiring too. Some installers have a nasty issue when it comes to hard wiring. They don't like doing it. So instead of hard-wiring your garbage disposal, they'll cut it in to your dishwasher. If your garbage disposal or anything else is wired to your dishwasher the load on the washer and the current the washer is using is too high. That's going to trip your breakers. You should probably contact an electrician and have them check the breaker box to make sure it's wired correctly. You may need to upgrade the breaker or have the dishwasher circuit upgraded. If it's an old house, it could be anything but first, check to see that nothing is wired into your dishwasher. You can tell if you have a few switches in the same outlet and turn them off. If your garbage disposal won't work and the DW won't either, then you have a wiring issue. That's the easiest way to start.
Apr 06, 2014 | LG LD-1420T1 Dishwasher
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
Dishwasher fills up with water put wont go into wash cycle and wont drain
your drain hose is probably plugged to the drain especially if it goes through the garbage disposal first,remove drain hose from dishwasher at the disposer and see if its plugged,if so unplug obstruction,then start it and put hose in sink and press drain/cancel and see if it drains now
May 12, 2012 | Hotpoint Dishwashers
Whirlpool quiet partner 1 won't drain all the way suddenly
Hello.
HERE ARE TOOLS NEEDED AND INSTRUCTIONS ON HOW TO SOLVE THE DRAINING PROBLEM BELOW.
(A) Clean cloth(s)
(B) Wrench (if necessary)
Whirlpool brand dishwashers come in black, brown, stainless steel or white finishes and a variety of sizes as well. Most Whirlpool dishwashers are energy efficient, and many have features such as a sanitizing rinse, enhanced sound effects, large capacity tubs and adjustable shelves and racks. However, none of these features will help users much if the dishwasher is not draining. While this issue may require professional repair, some troubleshooting steps may help determine if there is a relatively simple cause for the problem.
1 Verify that the Whirlpool dishwasher has not lost power due to a power failure or motor overload. Wait a few minutes to see if the motor automatically resets and resumes operation. Reset the circuit breaker or fuse if necessary.
2 Press or select "Start" to resume the cycle if the dishwasher was stopped mid-cycle. Choose a new drain cycle if necessary to remove excess water from the unit.
3 Turn off the dishwasher and unplug it from power. Examine the connection between the dishwasher and the garbage disposer, usually located underneath the kitchen sink. Make sure the disposer knockout plug was taken out between the two.
4 Run the garbage disposer in the kitchen sink to remove potential blockages.
5 Remove objects that may be blocking the drain on the dishwasher. Clean out the drain hose at the rear of the dishwasher.
Thanks.
Nov 06, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
How to clean out pump drain on DU1050XTPQ1
Hello.
(A) Wrench (if necessary) (B) Clean cloth(s)
Thanks.
Nov 05, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Bosch Dishwasher (SHE44C05UC) won't turn on
Just had the same problem, same model. Found the wiring below the front cover fried. So now I'm checking to see if anyone else had this happen.
Jan 13, 2010 | Bosch 24 in. SHE44C05UC Stainless Steel...
Breaker kicks off
you have a blockage in your pump or in your drain line. remove the kick plate on the low front of the machine. Then remove the drain line and the pump. Inspect it all for blockage. Also check the drain under the sink and the garbage disposal if you have one for a blockage.
If there is no blockage there then you have a more serious problem which is the main motor itself.
At this point, un less the dishwasher is under warranty you will need to get an estimate before you have it repaired as you may find that a replacement is a better solution for you. good luck with it.
Oct 24, 2009 | Bosch SHU9925UC Built-in Dishwasher
I've got a GE dishwasher, a GSD2800. It's giving a C4 code and it just won't drain the water. I turned the breaker to it on and off, shut off the water supply and tried to cycle it but no luck. I can...
If this is a new install where there was no dishwasher before. Or if your garbage disposal has been replaced. Then the plug in the garbage disposal inlet for the dishwasher drain may still be in place. You will have to disconnect the dishwasher drain and see if the inlet is clear. If not the garbage disposal will have to be removed, the plug punched out and then reinstalled. Good Luck!
Jul 24, 2009 | General Electric GSD2400NWW Built-in...
My gargabe disposol won't turn off.
sounds like the wall switch needs to be replaced.
Apr 05, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Not draining
Did you remove the plug in your disposal so the dishwasher can drain???
May 30, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
75 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
