Question about Bissell 16943 Powerlifter Wet/Dry Vacuum
Bissell Steam Cleaner Model1694.Where to put soap?
I want to know how to use the machine. Need to know where to put the detergent.
  • 6,784 Answers
The detergent will have to be poured directly into the water tank by using the measuring cup that is attached to the back side of this unit. I have a manual for you that you can print out as well.
Click here for your manual.
Posted on Mar 10, 2009
Bissell cleanview carpet cleaner
There are a few things that can cause a Bissell carpet cleaner to not dispense water. First thing to check is the belts if your machine is a Pro Heat. The flat belt goes around the motor shaft and the pump. As the motor runs it spins the pump. This is a stretch belt and stretch belts should be replaced at least once or twice per year to work properly as they will lose elasticity even if the machine has never been turned on. The first thing to check is to see if water will spray from the upholstery tool. If it sprays but you still get no water at the floor jets then check and clean the jets to insure they are not clogged. Getting water from the upholstery tool means the pump is working ok. If not, make sure the water tank and soap tank are not empty. Even if the water tank is full make sure the soap tank is full too. I would suggest NOT putting any soap in the soap tank because that is what causes most of the problems. Put plain tap water in the soap tank and try the machine again. Hold the trigger down giving it plenty of time to flush out any air bubbles and/or soap from the pump and the lines. If you still can't get any water from to the floor jets the most likely problem is the heater is clogged with mineral deposits or soap gunk. When a machine sits in the closet for months the soap in the lines coagulates and will clog things up. Which is why if you want the machine to work for a long time NEVER put soap in it. To do a better job of cleaning put your soap and hot water into a sprayer and use this solution to pre-condition the carpets. Pre-conditioning gives the soap and hot water a chance to dissolve the gunk in your carpets, then use fresh hot water in the machine to flush the soap and dirt from your carpets. Your machine will last longer and your carpets will be cleaner and stay clean longer because you rinsed out the soap. If you try this method you will be amazed how much cleaner your carpets will be.
If you need to clean the heater you will need to separate the handle assembly by removing all the screws. First make sure the machine is unplugged. You'll have to figure out which screws need to come out, it's not too tough. The heater is inside the handle. Look at how it comes apart so you will know how to put it back together. The heater is the silver metal thing with wires and hoses. Remove the screws that hold the cover on being sure not to lose any of the tiny red gaskets. Remove the cover and clean the soap or mineral deposits from the heater core, put the cover back on and put it back together and it should work fine. To keep it from getting clogged again simply make sure you use soft water if minerals were the problem and never put soap in the machine.
Oct 22, 2013 | Vacuums
My bissell steam cleaner will not spray any water or soap how do I correct this problem
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
kjgtllgj
Aug 23, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Our Bissell Proheat Carept Cleaner 1699 is not dispensing any soap; only weater is running thru the cleaner. We are using the Bissel cleaning soap, not an off brand. Any suggestions would be appreciated?...
Hi Paul,
I just want to make sure that you still would like help with your Bissell. As you may see from my profile, when I help someone out, I always spend considerable time answering questions, taking pictures, and really making sure that you know how to fix the problem. Before I spend so much time doing this, I like to follow up and make sure that A. there's a real customer I'm answering, and B. that you haven't already fixed your machine. If you'd like me to walk you through this troubleshooting, please just add a comment here on the repair page.
Thanks,
Chris Jones
Apr 11, 2010 | Bissell 1699 ProHeat Clear View Upright...
I have a bissell steam cleaner. the hand piece
heatman101
a
Sep 26, 2009 | Bissell 1699 ProHeat Clear View Upright...
Where do i put the shampoo in my bissell proheat turbo carpet cleaner?
On these machines there is usually a small container on the back of the machine below the handle.
Pull it out and fill all the way up with the proper soap.
Goodluck
Sep 15, 2009 | Bissell 1699 ProHeat Clear View Upright...
Filling the cleaner
cleaner goes in little tank on side. Hot water only no soap goes in the big tank in middle
Jun 25, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell steam cleaner model 9300 not putting out soap
heatman101
,b..,
May 14, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell 16943 Powerlifter Wet/Dry Vacuum Logo
451 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
