FixYa.com
Tags:
Q-Logic 4GB FIBRE CHANNEL PCI- EXPRESS HBA  Storage Controller
Slow File Transfers with 100 MBit Network
By M0nica L - usenet poster
I have a Novell 4.1 Server on a 100 MBit network using Cogent EM/PCI
card. I use 4-4GB Baracudda Drives and a Q-Logic PCI SCSI Card. The
file transfer rate to a DOS Client is 2.8 MBytes/sec the first time and
no more than 4.0 MBytes/sec any additional time. This transfer rate
seems incrediblly slow. The PERFORM3 numbers are 6-7 MBytes/sec. These
two machines are the only things on the network. Is this number the
best I can expect or is something wrong. Anybody out there have a
similar setup or some other numbers?? I have tried a Windows/NT Server
3.51 with the same hardware and the numbers are even worse clocking in
at no more than 1.7 MBytes/sec. Any ideas would be appreciated.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
Charlie
Charlie - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
THE ONLY THINGS IN THE NET ..
33% only on a congested full used network, not on an empty lan. At our lan
which is often very quiet, I am able to get 1000k/s (perform3) over 10
Mbit. He and we're only a bunch of students :)
My guess us that at 100 Mbit/s the net isn't the only thing bottleneck
anymore. Maybe it is possible to get more than one client using perform3
and see if how much the server can get on the net. I think that 6-7 MB with
perform3 is quite ok.
Greetz,
Sjoerd
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Cato
Cato - usenet poster
Rating: 0%, 0 votes
(Vernon D. Smith) wrote:
Let's try some arithmetic here. 100 Mb/sec works out to 12.5 MB/sec.
Although I don't know the Cogent card right offhand, I assume it to be
a CSMA/CD using the same media access as traditional Ethernet. That
would mean you're getting about 33% of the theoretical bandwidth,
which turns out to be about right. Frankly, I don't see the problem.
Roger Kresge, Master CNE/CNI Internet:
Inacom Information Systems Compuserve: 71023,447
Lancaster, PA
Can you Help with these Storage Controllers problems?
Storage Controllers
compaq presario 6000z
may processor that uses amd... Answer This...
Storage Controllers
Installing
I have a Lexmark 1200 that i... Answer This...
Storage Controllers
how do i use a memory stick
please give me explicite... Answer This...
Storage Controllers
probleme
je ne peux pas telecharger le... Answer This...
Storage Controllers
SWEEX 4 PORT USB 2.0 & 3...
Hi there, I have this... Answer This...
Repair Service
Find Storage Controller Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
